Direct solution for two unknowns in two equations
  • Context:
  • Thread starter Thread starter IanfromBristol
    Unknowns
2 replies · 2K views
IanfromBristol
I am writing a computer program to solve a physical problem which at some part involves the following two equations and two unknowns;
(1) \[ C_1(x^4-y^4) + C_2x = Q_1 \]
(2) \[ C_1(y^4-x^4) + C_3y = Q_2 \]
C1, C2 & C3 are coefficients which can readily be calculated and do not rely on knowing the values of X or Y. Q1 and Q2 are known values (effectively boundary conditions). I've tried substitution and elimination but end up with a much more complicated expression which looks to be a quartic equation. I know I can solve this iteratively and it does converge quickly and is stable. However, is there any method that can solve it directly and thus avoid the iterative approach?
Mathematics news on Phys.org
topsquark said:
I see no way to avoid the quartic. There is a method to do this to get an exact answer (here) but I'd stick with approximation. It's much easier to work out.
-Dan
Hi Dan, I took a look at that solution for the quartic and you're not wrong the iterative method (i.e. approximation) is far easier to work out!
Ian
