Direction of Forces on an Euler Spiral Path | Intuitive Explanation
  • Context: High School
  • Thread starter Thread starter thinkagain
    Euler Forces Spiral
The discussion revolves around determining the direction of forces acting on an astronaut with a jetpack traveling along an Euler spiral path while attempting to change direction quickly. Participants explore the implications of thrust direction, speed, and radius of travel in relation to the astronaut's maneuvering capabilities.
  • One participant describes a scenario where an astronaut aims to change direction 90 degrees while maintaining speed, questioning the optimal thrust direction for rapid maneuvering.
  • Another participant emphasizes the need to define the problem clearly, focusing on momentum change and the relationship between force, momentum, and time.
  • Several participants suggest that the astronaut could take a circular path or an Euler spiral path, with varying opinions on which would be faster and under what conditions.
  • Some participants argue that the quickest way to achieve a 90-degree turn might involve firing thrusters backwards while allowing for a finite velocity at right angles to the original direction.
  • Concerns are raised about the adequacy of thrust to achieve the desired maneuver, noting that insufficient thrust would leave the astronaut with forward velocity upon reaching the target line.
  • There is discussion about the implications of combining deceleration with turning, particularly in the context of an Euler spiral, and whether this would yield a more efficient path.
  • One participant expresses uncertainty about the optimal path and suggests that the problem is interesting and complex, indicating that the solution may not be straightforward.
Participants do not reach a consensus on the optimal path or thrust direction for the astronaut's maneuver. Multiple competing views remain regarding the effectiveness of circular versus Euler spiral paths, and the discussion is characterized by uncertainty and exploration of various scenarios.
Participants express limitations in their understanding of the mathematics involved, and there are unresolved questions about the specific conditions under which different paths would be optimal. The discussion includes assumptions about thrust capabilities and the astronaut's initial conditions.
  • #61
haruspex said:
P√2 = F t45. Suppose we try some other strategy for time t45. Let the 45 degree direction be the y direction. If for any part of the time we direct some of the available F in the x direction then during that time Fy < F. Thus the integral of Fy over time t45 will be less than P√2, and we will not have achieved the desired result.
A.T. said:
I think haruspex's explanation qualifies as proof. If you need expansion on it, you should pinpoint exactly which point of it you want expanded.
As an alternative consider the reference frame where the astronaut was initially at rest. Here he has to accelerate from 0 to some speed along the 45° line as quickly as possible. Still not obvious?
Thanks for persevering, chaps. I think I have it now.
  • #62
So is the 45 degree angle the optimum direction of thrust then? Thanks!
  • #63
For the equal speed constraint, not for the fixed turn space constraint .
  • #64
I see, so we still don't have an answer for that one then?
  • #65
As I posted, that would make quite a hard problem. In all likelihood, there is no analytical solution. Certainly out of the scope of a homework forum.
  • #66
I just figure after all that, if you can't make the turn quick enough you all stop thrust until you can make the turn by gradually redirecting to the y so you just barely have no x just in time and all y thrust at the boundary. If you have more than enough thrust you start all y direction until you have just enough time to all x up to the boundary and shift 90 degrees at the exact moment you cross, which in my simple mind... the latter resembles an inverse Euler spiral.
  • · Replies 27 ·
  • · Replies 157 ·
11K
  • · Replies 18 ·
  • · Replies 24 ·
