What is the Young-Laplace equation and its relationship to surface tension?
The Young-Laplace equation describes the relationship between surface tension and pressure differences across a curved surface. Surface tension, represented as a scalar ##\gamma(\mathbf{r})##, generates a force along a bounding contour ##\mathcal{C}##, calculated using the integral ##\displaystyle{\int}_{\mathcal{C}} \gamma(\mathbf{r}) \mathbf{n} ds##, where ##\mathbf{n}## is a unit vector. Young's law relates the three surface tensions involved in the equilibrium of different phases, specifically through the equation S(la)cos(θ) + S(sa) = S(sl). Understanding these concepts is crucial for analyzing forces at interfaces in fluid mechanics.
  • Understanding of surface tension as a physical property
  • Familiarity with Young's law and its implications
  • Basic knowledge of vector calculus, particularly unit vectors
  • Concept of pressure differences in curved surfaces
  • Study the derivation and applications of the Young-Laplace equation
  • Explore the implications of Young's law in multi-phase systems
  • Learn about the role of surface tension in fluid mechanics
  • Investigate the mathematical representation of tensor quantities in physics
Students and professionals in physics, fluid mechanics, and engineering who seek to deepen their understanding of surface phenomena and the mathematical relationships governing them.
Shreya
Why does surface tension seems to have direction in these images? Isn't it a scalar?
S=Fl/Av
It is correct that surface tension is a scalar ##\gamma(\mathbf{r})##. If you have a surface ##\mathcal{S}## containing a bounding contour ##\mathcal{C}## between two different phases, the surface tension force exerted by one phase on the other is ##\displaystyle{\int}_{\mathcal{C}} \gamma(\mathbf{r}) \mathbf{n} ds## where ##\mathbf{n}## is a unit vector tangent to ##\mathcal{S}## but orthogonal to ##\mathcal{C}##.
In your diagram (Young's law), a force balance is being done on a tiny mass element at the lower left corner. Keep in mind that there are three different interfaces.
The images are not illustrating surface tension; they are illustrating forces arising from surface tension.
In the same way, tension in a string is an intensive state of the string, not a force. It results in forces at the ends.
ergospherical said:
surface tension force exerted by one phase on the other is ∫Cγ(r)nds where n is a unit vector tangent to S but orthogonal to C.
Thank you erogospherical and haruspex! It makes sense now!
Can you explain what you mean by a contour?
And what is Young's law ? (I haven't studied it yet)
Like pressure and rope tension, surface tension is a 2nd order tensor quantity, with bi-directional character. The scalar we call surface tension is just the magnitude of this tensor. Physically, surface tension acts within a free surface, and acts perpendicular to each arbitrary curve or line within the surface.
Thank you Chester, I get it now ! 🙏
- the word contour, in that context, is just a fancy word for a curve :)
- Young's law gives the relationship between the three surface tensions; can you deduce it?
ergospherical said:
Young's law gives the relationship between the three surface tensions; what is it?
S(la)cos (theta) + S(sa) = S(sl), right?
I actually have studied it, but the name of law was not specified
Tangent to surface would mean 2 directions. So why do we consider a particular direction here. i e how do i know which one of the two to choose?
Posts #2 and #6 both mention that the force is in relation to a given line element within the surface, and acts orthogonally to it within the surface.
Thank you all 😊 🙏 for helping me understand.
And it helps me to remember the units [force/length] in this context. The force "supplied" by the tension across that line element is proportional to the tension "times" the length of the small element.
And the other very useful relationship in this context is the Young -Laplace equation for curved surfaces:https://en.wikipedia.org/wiki/Laplace_pressure
Thank you, hutchphd! I had actually learned this, but the textbook didn't mention the name.
  • · Replies 18 ·
  • · Replies 22 ·
