Disadvantages of Non-Inverting Summing Op Amp
The discussion highlights the disadvantages of using a non-inverting summing operational amplifier (op-amp) compared to an inverting summing op-amp. Key points include that non-inverting summers do not connect input resistors to a virtual ground, leading to undefined input resistance unless all other inputs are grounded. The inverting summer offers constant input impedance, which is crucial for precision in applications like center of mass calculations. The AD706 op-amp is mentioned as a suitable component for implementing a two-stage design that combines both inverting and non-inverting configurations.
  • Understanding of operational amplifier configurations
  • Knowledge of input impedance concepts in circuit design
  • Familiarity with the AD706 op-amp specifications
  • Basic principles of summation circuits in analog electronics
  • Research the differences between inverting and non-inverting amplifier configurations
  • Explore the design and implementation of summing amplifiers using the AD706 op-amp
  • Learn about the implications of input impedance on circuit performance
  • Investigate two-stage op-amp designs for enhanced functionality in signal processing
Electronics engineers, circuit designers, and students studying analog signal processing who seek to understand the functional differences between non-inverting and inverting summing op-amps.
Poptart
Hi,
I was wondering what the disadvantage of using a non-inverting summer was rather than using an inverting summer. I was told that inverting summers are better, but not why they are.
I ask because I'm making a circuit that performs a center of mass calculation:
(V1 + V2) - (V3 + V4) = Vout
(V1 + V2 + V3 + V4)
and the IC that does the division step requires that the denominator is greater than the numerator, so using a non-inverting summer on the denominator seems to make the most sense to me.
Thanks in advance :)
The main advantage that comes to mind for using an inverting summer is that the input impedance is constant compared to a non-inverting.
Okay. Does that noticeably affect the output? What kind of precision can I expect with using one versus using the other?
You could use 2 stage op-amp design to get the job done with an inverting summer.
The second stage would simply be a unity gain inverting amplifier.
Oh, excellent. Such a simple solution and works perfectly since the AD706 I'm using for the weighting sum has two op amps on the chip as it is.
I'd still like to know what the functional difference is between the two summers is, but that's more of a curiosity thing than a necessary question :) Thanks a ton to both of you
The only thing that I can think of is exactly what Averagesupernova has already mentioned.
For a non-inverting summer, the input resistors do not connect to a virtual ground. Thus a current flows in each input resistor that is a function of the voltage at all inputs.
This makes it impossible to define the input resistance for anyone input unless all other inputs are grounded.
That makes sense. So then (last question) that reasoning wouldn't apply to a non-inverting amplifier, correct? Since it only has one input tied directly to the op amp's positive terminal, a non-inverting amplifier is just as good as an inverting amplifier? Intuitively it seems to me like it would be, otherwise an inverting unity gain amplifier would need to follow it to achieve the same result (but I'll be the first to admit that my intuition's not perfect).
Thanks again :)
Thanks again :)
The non-inverting input of the operational amplifier will still need a path for DC to ground. This is usually obtained through the signal source, but nonetheless if this isn't the case, or be it that the source requires a certain load impedance, the circuit will require another resistor from the input to ground.
Non-inverting amplifiers and inverting amplifiers have both their disadvantages and advantages.
The preference to one or the other will depend on the specific design you are trying to achieve.
  • · Replies 33 ·
