DISCRETE: A-ø=? (A is defined)
  • Thread starter Thread starter MelissaJL
    Discrete
In the discussion, participants analyze two statements regarding the set A={ø,1,2,{1,2},{3}}. The first statement, A-ø=A, is confirmed as true because removing the empty set from A does not change its contents. The second statement, A-ø={1,2,{1,2},{3}}, is deemed false since it misinterprets the difference between A and the empty set. Clarification is provided that A-{ø} results in the set without the empty set, which does not affect the overall set A. The conclusion is that statement (g) is true and (h) is false.
MelissaJL
Suppose A={ø,1,2,{1,2},{3}}. Determine if each statement is true or false. Give a brief justification for your answers.
(I finished the majority of them except for the last two)
g) A-ø=A
h) A-ø={1,2,{1,2},{3}}
The definition of difference between two sets.
Let A and B both be sets. Then A-B={x: x\inA and x\notinB}
So basically one of the questions is false and the other is true. Immediately I want to say (h) is true just because A has an empty set in it but after thinking about it I think (g) is true.
This is because we are trying compare what is in the empty set that A also contains... but the empty set has nothing in it so there is nothing to take from A. Therefore A-ø=A. Is this right? If it's not can someone explain to me why?
I'm getting quite conflicted as to which one I believe is true. Help understanding which is true would be greatly appreciated. :)
g) A-ø=A
Think about the difference between A-ø and A-{ø}. ø (which has no elements) and {ø} (which has one element ø) are two different things. That might help.
Thanks, so (g) is true and (h) is false. If (h) were to be true then it would be A-{emptyset}={1,2,{1,2},{3}}?
Yes, A-{ø}={1,2,{1,2},{3}}. A-ø=A. You were right.
Thank you so much :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
19K
