Displacement (Answer Key Error)
The discussion centers on an error in the answer key regarding the displacement of an object described by the position function s(t) = (2/3)t^2 + 4t^2 + 6t + 2. The correct calculation for displacement after 3 seconds involves evaluating s(3) and subtracting s(0), leading to a final position of 62. Participants clarify that the answer key incorrectly states displacement as simply s(3), which is misleading. The confusion arises from a potential miscopying of the equation, but it is confirmed that the answer key is incorrect. The conclusion emphasizes that the answer key should not be trusted based on the calculations presented.
Qube
The position of an object traveling in a straight line at time t is given by s(t) = (2/3)t^2 + 4t^2 + 6t + 2.
What's the displacement after 3 seconds?
Displacement is final position minus initial position.
Displacement at 3 seconds is s(3) - s(0).
s(0) = 2. Note the constant term!
s(3) = 18 - 36 + 18 + 2.
s(3) - s(0) = 0.
Interestingly enough, my key claims displacement is simply s(3).
I'm guessing this is an error (and not on my part)!
Can you explain how 2/3 * t^2 = 4*t^2 + 6*t + 2?
Likes 1 person
Sorry, replace the second equal sign with a plus sign. I've corrected it in the OP.
OK, can you also show how you're getting s(3)? Because, if the equation is s(t) = (2/3)t^2 + 4t^2 + 6t + 2, then at t = 3, the current position is 6 + 36 + 18 + 2. Which is equal to 62. If the equation is s(t) = (2/3)t^2 - 4t^2 + 6t + 2, then at t = 3, the current position is 6 - 36 + 18 + 2, which is equal to -10. Not sure if you're copying the equation wrong or what...
I think I did copy the problem wrong, but I know there was a constant at the end, which makes the answer key unequivocally wrong, correct?
Okay, I found it!
http://i.minus.com/jW4oBtV2mWi3O.png
http://i.minus.com/jbrSQnX1kxCiGG.png
Well, it definitely seems like now there is an error in the answer key. So, yes, I would not follow it.
Likes 1 person
  • · Replies 38 ·
  • · Replies 20 ·
