How Do You Calculate Dissolved Oxygen Content for Catalytic Oxygen Removal?
  • Thread starter Thread starter Dean04
    oxygen
To calculate dissolved oxygen content for catalytic oxygen removal, a detailed understanding of catalytic reactor modeling is essential. The experiment involves using hydrogen and a platinum catalyst to deoxygenate water, with measurements taken using a vernier dissolved oxygen sensor. The user seeks an equation to compare theoretical designs with experimental results, emphasizing the need for clarity on the system's parameters. It is suggested that resources on Chemical Reaction Engineering be consulted for comprehensive modeling techniques. Accurate modeling will facilitate the comparison of theoretical and experimental outcomes effectively.
Dean04
As part of my project I am taking part in an experiment which involves the catalytic removal of oxygen through the use of hydrogen.
Is there an equation to calculate the dissolved oxygen content so that I can compare the experimental results to theory
Thanks
You're going to need to provide more detail than this. Put yourself in our place. There is virtually no context for answering what you are asking.
Chet
Likes Dean04
Chet
Apologies for such a vague thread. I'll try my best to explain in more detail. My University dissertation is the " Design of a Compact Deoxygenating System for Offshore Seawater injection"
There is an experiment involved which verity's the deoxygenation of water though a catalytic process. The water is fed through a test tube along with hydrogen until it meets the catalyst which is platinum on alumina pallets and then finally into a beaker. The dissolves oxygen content is measured through the use of a vernier dissolved oxygen sensor. This is repeated with the water at different temperatures and flow rates.
Once I have designed a deoxygenating system I want to compare my design with the experimental results in order to prove it actually works. However, as my design is just in theory and not real life I am looking for an equation in which I can use the parameters in my proposed design to calculate the dissolved oxygen content and compare it with the experimental results. My design will have the same principle as the experiment in the fact that the use of hydrogen and a catalyst will remove the oxygen levels.
Hope this is more clear.
Thanks,
Dean.
You are trying to model a catalytic reactor that removes oxygen from water by reacting with hydrogen. The hydrogen is in the feed to the reactor. Is it bubbles or is it also dissolved in the water? Your main question is, "how do I model such a catalytic reactor." Is this correct?
Chet
Bubbles and yes that's correct
The basics of how to model catalytic reactors is beyond the extent of the material that we can conveniently present here. You need to get yourself a book on Chemical Reaction Engineering.
Chet
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
9K
  • · Replies 27 ·
