Distance between compact subsets
  • Thread starter Thread starter Ocifer
    Compact Subsets
7 replies · 4K views
Ocifer
Let A,B be two disjoint, non-empty, compact subsets of a metric space (X,d).
Show that there exists some r>0 such that d(a,b) > r for all a in A, b in B.
Hint provided was: Assume the opposite, consider a sequence argument.
N/A
I've tried a few different characterizations of compactness, but neither one has led me anywhere particularly useful. I'm missing something such that the teacher's hint isn't helping me much.
If I assume the opposite,
Assume that for all r>0, there exists some pair (a,b) such that d(a,b) <= r
I sense that I am supposed to reach a contradiction regarding the property that any sequence in a compact A or B should have a convergent subsequence. But how do I show that I would reach such a contradiction. Can anyone give me a push in the right direction?
N/A
Make some sequences. Assume d(a_n,b_n)<=1/n for all n. Now pick subsequences.
Do you mean:
Assume, by way of contradiction, that for all r>0, there exists some pair (a,b) such that d(a,b) <= r.
Let {a_n}, {b_n} be sequences in A and B respectively.
I'm unclear on your next assumption. Are you using n to index the sequences as well as to bound the distances with 1/n, or was that an unintentional typo? If not, why may I /should I make that assumption?
If I assume that for all r>0, there exist some pair such that d(a,b) <= r , that allows me to at least construct two sequences in A and B respectively having the property:
d( a_1, b_1 ) <= 1/1
d( a_2, b_2 ) <= 1/2
and so on, is that what you meant? I hope I'm understanding you correctly.
If I am trying to show that this property implies there is no convergent subsequence, how does it help. It doesn't tell me about the distances between each of the elements of the {a_n} sequence and the {b_n} sequence, does it?
Another intuition I had which I'm trying to formalize, but I thought I would run past the forum is this. If I assume that for all r>0, there exists an (a,b) such that d(a,b) <= r, would this not imply that the two sets share a limit point? Since they are compact they must each contain their limit points, and then they would not be disjoint? Can I reach my desired contradiction in that manner?
The second route. If a_n has a limit point a and b_n has a limit point b, what's d(a,b)?
Here goes my full attempt:
Let (X,d) be a metric space. Let A and B be non-empty, disjoint, compact subsets of (X,d).
Then there exists an r>0 such that d(a,b) > r for all a in A, b in B.
Proof:
Assume by way of contradiction that for all r>0, there exists a pair (a,b) such that d(a,b) <= r.
Under this assumption, we may construct the two sequences in A and B respectively, having the property that:
d(a_n, b_n) <= 1/n , for all n in the natural numbers.
Claim: If we consider this sequence of distances, its limit is 0.
Subproof: For any ε > 0, there is an n in the natural numbers such that 1/n < ε . It follows that for any ε > 0, we have some N(ε) such that if n >= N(ε), | d(a_n, b_n) - 0 | < ε .
And so the sequence of distances has limit 0.
From this it follows that the limit of {a_n} is equal to the limit of {b_n}. So A and B share a limit point, and since both contain their limit points, the sets A and B cannot be disjoint. This is a contradiction, and so it follows that there exists some r>0 such that d(a,b) > r for all a in A, b in B.
Is this okay?
Proof:
Is this okay?
The idea is fine. I'm not sure the proof really measures up. Skip to picking convergent subsequences and suppose d(a_n,b_n)<1/n and a_n->a and b_n->b. Use d(a,b)<=d(a,a_n)+d(a_n,b_n)+d(b_n,b) using the triangle inequality. Can you show the right side converges to 0?
The right hand side terms should all go to zero in the limit as
d(a, a_n) --> d(a,a) = 0
d(b, b_n) --> d(b,b) = 0
and
d(a_n, b_n) --> 0 using the definition of a limit of a sequence in metric spaces, and the fact that d(a_n, b_n) < 1/n for all n.
I think I have it now, thank you for your help.
