How Do You Calculate the Distance Between Two Ships Using Angles of Depression?
  • Context: MHB
  • Thread starter Thread starter xyz_1965
    Ships
The distance between two ships, P and Q, can be calculated using the angles of depression from an airplane at point R, which is 3500 feet high. The angle of depression to ship P is 48°, resulting in a distance PD of 3151.41 feet, while the angle to ship Q is 25°, yielding a distance DQ of 7505.77 feet. The total distance between the two ships is the sum of PD and DQ, equaling 10,660 feet when rounded to the nearest tenth.
  • Understanding of trigonometric functions, specifically tangent.
  • Knowledge of angles of depression and their application in real-world scenarios.
  • Familiarity with basic geometry concepts, including right triangles.
  • Ability to perform calculations involving feet and rounding to the nearest tenth.
  • Study the application of trigonometric ratios in real-world problems.
  • Learn about the properties of right triangles and angle relationships.
  • Explore advanced topics in navigation and maritime distance calculations.
  • Investigate the use of software tools for geometric calculations, such as GeoGebra.
Mathematicians, engineers, pilots, and anyone involved in navigation or maritime operations who needs to calculate distances using angles of depression.
xyz_1965
Points P and Q are in the same vertical plane as an airplane at point R. When the height of the airplane is 3500 feet, the angle of depression to P is 48° and that to Q is 25°. Find the distance between the two ships. Round the answer to the nearest 10th of a foot.
Solution:
From R, I will drop a perpendicular to a point I call D. The distance between the two ships is PD + DQ.
To find PD:
tan (48°) = 3500/PD
PD = 3500/tan (48°)
PD = 3151.41 feet
To find DQ:
tan (25°) = 3500/DQ
DQ = 3500/tan (25°)
DQ = 7505.77 feet
Distance between the two ships:
PD + DQ = 3151.41 + 7505.77
PD + DQ = 10, 657.18
Rounded to the neatest 10th of a foot, I get
10,660 feet.
Is this correct? I hope so after all this work.
Mathematics news on Phys.org
Are you clear on what "angle of depression" means? Since the angle of depression, the angle down from a horizontal to the line from R to P, is 48 ° the angle RPD is 90- 48= 42 °. Similarly the angle RQD is 90- 25= 65 °.
