Distance in Electric versus Gravitational potential energy
The discussion revolves around the comparison of electric potential energy (EPE) and gravitational potential energy (GPE), focusing on how distance affects each type of potential energy. The original poster expresses confusion regarding the contrasting behaviors of EPE and GPE as distance changes, particularly in the context of attractive and repulsive forces between charged particles and masses.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the differences in equations for GPE and EPE, questioning why GPE increases with distance while EPE decreases. They discuss the implications of oppositely charged particles and the nature of attractive versus repulsive forces. Some participants attempt to clarify the local versus global perspectives of GPE calculations.
The discussion is ongoing, with participants providing insights into the mathematical relationships between GPE and EPE. There is an exploration of how potential energy behaves in different contexts, and some participants offer clarifications regarding the assumptions made in the original poster's understanding.
Participants note that the equations for GPE and EPE are derived from different principles, and there is an acknowledgment of the limitations of using local approximations for GPE when considering larger distances from the Earth's surface. The conversation also highlights the need to understand the implications of positive and negative values in potential energy calculations.
califauna
Consider the equations for electric potential energy:
and gravitational potential energy:
GPE=m*g*h
In the case of GPE, the potential energy increases as the distance between the two objects increases. This makes sense (to me), as the greater distance between the Earth and an object for example, the greater distance there is to fall and thus more kinetic energy to build up. No problem.
With electric potential energy however, distance has the opposite effect, with potential energy decreasing as the distance between the two charged objects increases.
In the situation of two oppositely charged particles, why do we not consider the charges to be 'falling' towards each other like in the gravitational example, and thus the potential energy will be less the closer together they are when the potential is measured?
GPE and EPE are constantly being used as analogous examples, but the equations used to calculate them don't seem to be analogous at all to me, at least in the case where the charges are attracted and move towards each other.
Hi,
You are right that these two don't look similar at all. That's because you picked a rather local version of the GPE -- one that doesn't work on a scale where the Earth isn't flat any more.
For force from gravity, Newton came to $$ F_g =-{G m_a m_b\over r^2} $$ and the accompanying potential $$ U_g = -{G m_a m_b\over r} $$ and that's more or lesss exactly the same as the expression you started with !
Well, to be able to compare the two, you should consider the potential energy of oppositely-charged particles. If q_a and q_b are both positive, or both negative, then they repel each other, unlike gravity, which is an attractive force.
So if q_a is positive, and q_b is negative, then \frac{k q_a q_b}{r} is a negative number. As r gets bigger, it becomes the negative of a smaller number, which means that the potential is greater. Suppose k q_a q_b = -1. Then with r=1, the potential is -1. With r=2, the potential is -1/2. And -1/2 > -1.
BvU said:
Hi,
I don't know what you mean by local version.
The positive negative is the one I am considering already but its more that one I can't understand. The positive positive situation pretty much makes sense to me.
So, if the negative value is decreasing as the distance decreases, does that mean that infinitely far away means infinite negative potential?
The potential increases with increasing r, but the absolute value is decreasing, and goes to zero as r goes to infinity. Once again, suppose that k q_a q_b = -1 for example (in whatever units). Then
  1. When r=1, U = -1
  2. When r=2, U = -0.5
  3. When r=3, U = -0.33
  4. When r=4, U = -0.25
  5. etc.
Those numbers are increasing, because they are becoming less negative. The absolute values are decreasing: 1, 0.5, 0.33, 0.25, .... In the limit as r \rightarrow \infty, U \rightarrow 0
On the surface of the Earth you have, for a mass m: $$
U_g(R) = -{G \, m_{\rm earth} \,m\over R}$$ with ##R## the radius of the earth. A few meters higher, say h meters higher, you are at a distance ##R+h## from the center of the Earth and then the GPE is $$
U_g(R+h) = -{G \,m_{\rm earth} \, m\over R+h}
$$ The difference is $$
U_g(R+h) - U_g(R) =\left (-{G \, m_{\rm earth} \, m\over R+h}\right ) -\left ( -{G\, m_{\rm earth} m\,\over R}\right ) = {G\, m_{\rm earth} \,m\over R} \left ( 1 - {R\over R+h} \right )
$$and if we define $$
g = {G\, m_{\rm earth}\over R^2} $$ (the numerical value is 9.82 m/s2 -- sound familiar ?)
and we know that with h/R << 1 we can write ##1/(1+ h/R) = 1 - h/R## to a very good approximation, then we get your GPE ! :$$ {\rm GPE } = U_g(R+h) - U_g(R) = m\,g\, h$$
(under the condition h << R, i.e. that you can ignore the fact that Earth is not flat -- which is what I meant with 'local' : it only works if you stay close enough to the ground :smile:)​
  1. When r=1, U = -1
  5. etc.
Ok, so as the distance increases the value gets closer to zero, and this means the electric potential energy is increasing. So why when we calculate the gravitational potential energy using the formula GPE=m*h*g, does the negative value get further away from zero as the distance above Earth increases? Eg. if the potential energy at 1 meter above the surface is say -1 joules, then at 10 meters it will be -10 joules. Working it out that way, the greater the height the more negative the result, but working it out using the formula where you divide by distance, provided by BvU above, Ug=(-G*mamb) / r, the number doesn't get more negative but rather gets closer and closer to zero.
As others have pointed out, the formula U = mhg is just an approximation to the formula U = -\frac{GMm}{r}. If you are a small distance h above the surface of the Earth, and R is the radius of the Earth, then -\frac{GMm}{r} is appoximately -\frac{GMm}{R} + \frac{GMm}{R^2} h. The quantity -\frac{GMm}{R} is some constant, U_0, and the quantity \frac{GM}{R^2} is a constant, g. So the formula for potential energy near the Earth is approximately given by: U = U_0 + mgh. People just write U = mgh because U_0 is a constant, and constants don't make any difference in potential energy, only the change in potential energy with distance.
But if you write U = mgh, that's a positive number, so it increases with h.
  • · Replies 23 ·
  • · Replies 17 ·
