Divergence of product of tensor and vector
The discussion revolves around the mathematical operation of taking the divergence of the product of a second rank tensor (dyadic) and a vector. Participants explore the application of the product rule in this context and clarify definitions related to divergence and dot products.
  • One participant expresses uncertainty about applying the product rule for divergence to the expression ∇.(T.V), questioning the validity of the formula ∇.(T.V) = (∇.T).V + T.(∇.V).
  • Another participant clarifies that the first term on the right-hand side is a scalar, while the second term is a tensor, leading to confusion about the applicability of the product rule.
  • A participant provides a detailed expression for the divergence, suggesting that ∇.(Tv) can be expressed as ∂i(Tv)i = ∂i(Tijvj) = (∂iTij)vj + Tij∂ivj, and asks for confirmation of its validity.
  • There is a discussion about the definition of the dot product of a tensor and a vector, with some participants asserting it is a contracted product.
  • One participant emphasizes the importance of clarifying definitions of divergence and dot product as used in the context of the discussion.
  • Another participant suggests that the divergence of a tensor can be expressed in terms of the covariant derivative, indicating that the Leibniz rule applies.
  • Further contributions explore the implications of using different definitions of divergence, particularly in the context of hydrodynamics and tensor algebra.
  • One participant attempts to clarify the notation and expresses uncertainty about the interpretation of the divergence operation in relation to the tensor and vector product.
Participants do not reach a consensus on the correct application of the product rule for divergence in this context. Multiple competing views and interpretations of the definitions and operations involved remain present throughout the discussion.
Participants note that the definitions of divergence and dot product may vary depending on the source material, which could affect the interpretation of the operations discussed. There is also mention of the need for clarity regarding the type of derivative operator being used (covariant vs. partial).
praban
I am new to tensor algebra. I have an expression involving a 2nd rank tensor (actually a dyadic) and a vector. I want to take divergence of the product
i.e. ∇. (T.V)
However, I am not sure if the simple product rule would work here. If I use that
∇. (T.V)= (∇.T).V + T. (∇.V)
However, the first term in the rhs is a vector but the 2nd term is a tensor. So, it seems this product rule is not applicable here. Can someone tell me what is the correct way?
thanks,
PB
Sorry, there was a mistake in my post. The 1st term in the rhs is a scalar (because div T is a vector and vector. vector =scalar).
I don't completely understand what you want to do. Is the first period a dot product? Then what is the second period? If Tv is a vector, then how about this?
$$\nabla\cdot(Tv)=\partial_i(Tv)_i =\partial_i (T_{ij}v_j) =(\partial _i T_{ij})v_j+T_{ij}\partial_i v_j.$$
Thanks, Fredrik. The first dot i.e. the one after ∇ is for the divergence and the second dot is dot product. Is your formula still valid?
Praban
How do you define the dot product of a tensor and a vector?
It's not the dot product, it's the contracted product of a dyad and a vector
\mbox{contraction of} \left(\bar{\bar{T}}\otimes\vec{v}\right) = \left(\sum_{j}T_{ij} v_{j}\right) \vec{e}_{i}
Yes, Dextercioby - it is the contraction.
Is the formula given by Fredrik valid in that case?
thanks
If \triangledown _{a} is the derivative operator on your smooth manifold then by definition of the derivative operator, the Leibniz rule is valid: \triangledown _{c }(T_{ab}v^{b}) = T_{ab}\triangledown _{c}v^{b} + v^{b}\triangledown _{c}(T_{ab}). Apply it however you like.
I don't even recall how "divergence" is defined in this context. Praban, you may want to clarify what exactly the expression you posted means. But almost certainly, the answer to your question is going to be yes, you can use the product rule. But the details of the proof is going to depend on what exactly you meant.
I think he may be talking about something like \triangledown ^{a}(T_{ab}v^{b}) = v^{b}\triangledown ^{a}T_{ab} + T_{ab}\triangledown ^{a}v^{b} but without further clarification from the OP one can only make assumptions :p. In physics books anyways the term "divergence free" is used for higher order tensors than just vectors to characterize things like the fact that \triangledown ^{a}T_{ab} = 0 for the energy momentum tensor and that \triangledown ^{a}T_{abcd} = 0 for the Bel - Robinson tensor etc.
Sorry for the late reply. Let me be more specific
I have ∇.v (1) i.e. divergence of a vector v.
then v is expressed as v=T.v0 (T is a tensor and v0 is another vector. The book I am using
- Happel and Brenner - Hydrodynamics does say that the T and v0 can have dot product and end result is a vector).
so, eq. (1) becomes ∇.(T.v0) (2)
My problem is with eq. (2). simple product rule gives
∇.(T.v0) = (∇.T).(v0) + T.(∇.v0) (3) (if it is correct)
however, LHS is a scalar (since divergence of a vector is a scalar)
1st term of RHS is a scalar (divergence of T is a vector and its dot product with another vector is a scalar). 2nd term of RHS - there is a problem it is going to be a tensor, which is not correct.
Obviously there is something wrong with my understanding. Can someone help?
p.s. here tensor is actually a dyadic
It's still not clear to me how this author defines "dot product" and "divergence". Can you post the book's definitions?
No, no, the 2nd term in the RHS is also a scalar. It's a double contracted tensor product between T and Grad v_0, see the post 10 by WBN using the fancy notation of (riemannian) differential geometry.
Dextercioby,
Thanks. Now I think I have understood. So, in my notation it would be
∇.(T.v0) = (∇.T).(v0) + T.(∇v0)
where dot in the 2nd term in the rhs is double contraction of tensors and ∇v0 is the gradient of the vector v0 (which is a tensor).
Fredrik,
the dot product here is same as contraction as written by Dextercioby in post 6.
The book I mentioned uses the standard definition of divergence of a dyadic.
Does that mean that the ∇ is the covariant derivative, or is it a partial derivative operator defined using a coordinate system?
Usually hydrodynamics is done in a Galilean geometry, so that the x's have one type of index, either upper, or lower, the nabla is defined as \vec{e}_{i}\partial_{i} and with it the divergence and gradients of tensors of arbitrary degree.
Yes, Fredrik, Dextercioby is right.
Praban
Still not sure I get it. Is this the correct interpretation of the notation?
$$\nabla\cdot(T\cdot v) =\nabla\cdot\big((T^i{}_j e_i\otimes e^j)\cdot(v^k e_k)\big) =\nabla\cdot(T^i{}_j v^j e_i) =\partial_i (T^i{}_j v^j).$$ In that case, the next step is a rather trivial application of the product rule and the linearity of ##\partial_i##.
$$\partial_i (T^i{}_j v^j) =(\partial_i T^i{}_j)v^j+T^i{}_j \partial_i v^j.$$ We also have
$$(\partial_i T^i{}_j)v^j =(\partial_i T^i{}_j e^j)\cdot(v^k e_k).$$ The second factor is ##v##, and the first one is what I would guess that ##\nabla\cdot T## means.
Not sure what to make of the term ##T^i{}_j \partial_i v^j##. I suppose that we could generalize the dot product notation so that this is equal to the dot product of T and something. That something would be ##\partial_i v^j e^i\otimes e_j##. I suppose it makes sense to denote that by ##\nabla v##. With these notations we have
$$\nabla\cdot(T\cdot v)=(\nabla\cdot T)\cdot v+T\cdot\nabla v.$$
i.e. ∇. (T.V)
thanks,
PB
The first term is correct, and is a scalar. The second terms is not correct. It too, of course, is supposed to be a scalar, and is given by the double dot product: \vec T:(\nabla \vec V)
See Bird, Stewart, and Lightfoot, "Transport Phenomena"
  • · Replies 16 ·
