Divergent Sequence Homework: Determine Convergence
The discussion revolves around determining the convergence or divergence of the sequence defined by an = {nn / n!}. Participants explore the behavior of the sequence as n approaches infinity and question the sufficiency of their reasoning and calculations.
  • The original poster attempts to analyze the sequence by comparing the growth rates of the numerator and denominator. They express uncertainty about the use of limits and whether their approach is sufficient. Other participants suggest examining inequalities and factoring to clarify the relationship between the terms.
Participants are actively engaging with the problem, offering hints and suggestions for refining the original poster's reasoning. There is a focus on ensuring clarity in the mathematical expressions and exploring the implications of the inequalities presented.
There is a mention of the need for precision in quantifying the terms involved in the sequence and the implications of the factorial in the denominator. The discussion reflects a collaborative effort to dissect the problem without reaching a definitive conclusion.
titasB
Determine whether the sequence is convergent or divergent
an = {nn / n! }
an = ( n . n. n ... n ) / 1 . 2 . 3 ... n )
⇒ an =n [ ( n . n. n ... n ) / 1 . 2 . 3 ... n ) ]
⇒ as n → ∞ , an → ∞
This is further confirmed by finding the values for the first 6 terms : 1, 2, 4.5, 10.67,26.04,64.8...
I'm not sure if this is sufficient however. Can we explain this using limits? If so wouldn't that give an indeterminant form? Of course the factorial on the denominator will always be smaller than nn but can this be shown using limits? Any help would be nice :)
Hint: Can you show that
$$\frac{n^n}{n!} \geq n$$
So something like this:
we can see the expression in the brackets approach infinity since the numerator is much larger than the denominator so,
∞ ≥ an ≥ n
and since n → ∞ this gives : ∞ ≥ an ≥ ∞
and so, an → ∞ as n → ∞ by squeeze theorem ⇒ the sequence is divergent
I think you need to be more precise. How many ##n##'s are there in the numerator of your second expression? Can you quantify "the numerator is much larger than the denominator"?
Consider factoring as follows:
$$\frac{n^n}{n!} = \left(\frac{n}{1}\right) \left[\left(\frac{n}{2}\right) \cdots \left(\frac{n}{n-1}\right)\left(\frac{n}{n}\right)\right]$$
Now look at the factors enclosed in the square brackets. Each factor is ##\geq 1##, so the product in the square brackets is ##\geq 1##. What can you conclude?
nn/ n! ≥ n
titasB said:
nn/ n! ≥ n
Right, now the rest of the argument works as you stated. The inequality shows that as ##n \to \infty##, the larger expression ##n^n / n!## must also diverge to ##\infty##.
Awesome thanks so much!
  • · Replies 34 ·
