Dividing by m to make conclusions for m=0
  • Level: Graduate
  • Thread starter Thread starter A.T.
72 replies · 8K views
A.T. said:
there is an infinite number of relationships between ##x## and ##y##, that satisfy the proposition. For example:
$$R_2: \hspace{10 mm} x =\begin{cases} y & m \neq 0 \\ 3y & m = 0 \end{cases}$$
Your objection in the previous thread was that ##x = 3y## doesn't satisfy the proposition for all ##m##, but that is irrelevant, because ##x = 3y## only comes into play for ##m=0##. The relationship ##R_2## as a whole does sastify ##mx=my## for all ##m##.
This is true, but now x and y aren't independent real numbers. That's why the theorem doesn't apply. Suppose e.g. that you make x and y functions and make the claim that mx(m)=my(m) for all m≥0. (This is what MrAnchovy suggested and then deleted, because he felt that it was off topic, but now it seems that it isn't). Now we can't just choose m=1, because that would prove x(1)=y(1), not x=y. All we can do is this: Let m be an arbitrary non-negative real number. If m≠0 then the assumption implies that x(m)=y(m). If m=0, the equality just says 0=0, and gives us no information. So the conclusion is that x(m)=y(m) for all m>0. If we let ##x_+## and ##y_+## denote the restrictions of x and y to the positive real numbers, the conclusion is that ##x_+=y_+##, not that ##x=y##.
DaleSpam said:
Neither of the proofs used division by m in their reasoning. They are not subject to that criticism.
The proof referred to in the original post did as you confirmed:
DaleSpam said:
I claim that given "##mx=my## for all m" you can simply divide out the m and get ##x=y##
... and I think we are all agreed that the operation of dividing out the m (and therefore that proof) is invalid when ## m = 0 ##. You have now presented a new argument at the crux of which is this statement:
DaleSpam said:
the only values for x and y which satisfy the proposition “##mx=my## for all m” are the values ##x=y##.
against which I provide a counter-example:
$$ x =
\left\{
\begin{array}{ll}
y & \mbox{if } m \ne 0 \\
0 & \mbox{if } m = 0
\end{array}
\right. $$
$$ x =
\left\{
\begin{array}{ll}
\end{array}
\right. $$
I think it's clear that what DaleSpam meant here is that if we want to assign values to x and y that make "mx=my for all m" a true statement, we have to assign the same value to both x and y. I would interpret x and y as variables that represent real numbers, since nothing else was explicitly stated. If that's the intended interpretation, then DaleSpam isn't wrong (at least not about this).
A counterexample to such a statement should assign values to both variables, not just describe a relationship between them. It looks like you would use something like this: x=y=1 when m≠0, and x=0, y=1 when m=0. But if x and y are variables that represent real numbers, this isn't an assignment of values. It's an infinite number of assignments (one for each m). So it's not a counterexample to the claim that DaleSpam made there.
If we interpret x and y as variables that represent elements of some other set, e.g. a set of functions, then things are certainly different. But I don't think that's the intended interpretation.
A.T. said:
I always understood it like that, even when “for all ##m##” wasn't stated explicitly. Unless stated otherwise, I assume no constraints on the value of ##m##.
"For all m" doesn't mean that there are no constraints on m. In fact, there can be constraints on m in the form of defining the admissible set membership for m. What "for all m" means is that, whatever the set of admissible m is, the relationship holds for every single member of that set.
Personally, I was taking the set of admissible m to be all real numbers, but my proof works for all admissible sets which include at least one non-zero number, and Fredrik's proof works for all admissible sets which include the number 1.
A.T. said:
Unless stated otherwise, I assume no constraints on the value of ##m##. So I assume that the last ##x=y## means "##x=y## for all ##m##". Is that correct?
I don't know what "##x=y## for all m" means since m is not in the expression ##x=y##. To me, it doesn't make any sense to append the "for all m" to that, but I suppose that there is no harm in doing it (although it seems strange and I certainly see no need to do it either).
$$ x =
\left\{
\begin{array}{ll}
\end{array}
\right. $$
These do not satisfy the proposition. If x depends on m as described then the pair x=5, y=5 does not satisfy the proposition because x=5, y=5 does not exist for m=0.
DaleSpam said:
These do not satisfy the proposition. If x is a function of m as described then the pair x=5, y=5 does not satisfy the proposition because x=5, y=5 does not exist for m=0.
No, in my counter-example if m = 0 then x = 0 (and y can take any value, 5 if you like). The proposition is ## mx = my ##, which is satisfied by ## 0 \times 0 = 0 \times 5 ##.
We are running into problems because, despite A.T.'s wishes, and Fredrik's efforts this thread has not proceded with anything like mathematical rigour. We need to go back to the starting point and note that x and y are not independent variables free to take any value in R, they are real valued functions x(s) and y(s) over some unspecified domain S. So when we write mx = my what we are asserting is that for all s in S and all m in R, mx(s) = my(s) is a theorem.
DaleSpam asserts that if mx(s) = my(s) for all m in R and s in S [Theorem 1] is a theorem then x(s) = y(s) for all S [Proposition 2] is a theorem. I provide a (better) counter-example which is consistent with Theorem 1 but contradicts Proposition 2 as follows:
$$ x(s) =
\left\{
\begin{array}{ll}
y(s) & \mbox{if } m \ne 0 \\
1 + y(s) & \mbox{if } m = 0
\end{array}
\right. $$
You are correct, I had intended x and y to be real numbers. But your proof actually works if x and y are elements of any vector space. Since the set of functions is a vector space, it works there also.
The problem comes that they are trying to treat x and y as functions in choosing the admissible set of x and y and then as something else for evaluating ##mx=my##. Whatever set they choose for x and y they have to treat them consistently, and your proof works for x and y in any vector space.
You are correct, I have not been rigorous at all and have assumed that people would understand what was in my head without my explicitly writing it down. Obviously a poor strategy for communication. My apologies for that.
I am not sure how to write it rigorously, but Fredrik's proof holds for x and y elements of any vector space over some field and m an element of any subset of that field that contains the multiplicative identity, 1.
$$ x(s) =
\left\{
\begin{array}{ll}
\end{array}
\right. $$
As written x is not a real-valued function over S. It is a set of many such functions, one for each m. The real-valued functions over S is a vector space and Fredrik's proof holds for them.
Just so that I can keep track, are you still asserting that your orginal proof including division by m where m = 0 is valid? Are you still asserting that {m = 0, y = 5, x = 0} cannot be a solution to mx = my? Or is Fredricks proof the only one that you now support?
If that is the case, note that Fredricks proof started with the assumption "I would interpret x and y as variables that represent real numbers, since nothing else was explicitly stated." and stated "If we interpret x and y as variables that represent elements of some other set, e.g. a set of functions, then things are certainly different." so I don't think that you can state without proof that it holds for for a vector space of functions.
Looking at it another way, if ## mx = my ## is to be interpreted as a theorem schema ## mx_m(s) = my_m(s) ##, then when m = 0 we have the theorem ## 0x_0(s) = 0y_0(s) ## from which it is impossible to conclude that ## x_0(s) = y_0(s) ## and therefore also impossible to conclude that ## x_m(s) = y_m(s) ## is a theorem schema.
A.T. said:
MI would like to hear a mathematicians opinion, on whether you can apply something, that you derived by doing this:
gm=ma
g=a
to a situation where ##m = 0##.
This is allowed both in math and physics. You are right that m/m is not valid operation for m=0 but the singularity is removable. The correct mathematical operation is
[itex]a = \lim\limits_{m \to 0} \frac{m \cdot g}{m} = g[/itex]
We don't know anything about the nature of the singularity; in particular if m = 0 => a = 0 there is a jump discontinuity and the limit is not defined.
I think that they are all valid, but this thread is too confused to chase down so many different proofs. Let's stick with Fredrick's, and its associated generalizations.
It seems clear to me that it does, but let me try to formalize it.
For ##x,y \in V## where ##V## is a vector space over field ##F## and for ##1 \in S \subseteq F##.
Given: ##mx=my, \forall m \in S##
##x=1x## by identity element of scalar multiplication in ##V##
##1x=1y## since ##mx=my, \forall m \in S## is given and ##1 \in S##
##1y=y## by identity element of scalar multiplication in ##V##
therefore ##x=y## by transitivity of equality
Since the space of functions is a valid vector space, ##V##, over the reals, ##F##, then the proof applies.
I think that the proof could even be further generalized to apply for S with any non-zero element, but the notation would be unnecessarily cumbersome, something like ##S\subseteq F| k \in S | k\ne 0##
Maybe you forgot that we are talking about [itex]m \cdot a = \frac{{G \cdot M \cdot m}}{{r^2 }}[/itex].
Well m is a scalar so ## m \notin S ## but that is easily fixed.
I agree that your proof is valid for vector spaces over a field. However I think if you include my counter-example function x(s) then the set is no longer a field.
I think this addresses the source of A.T.'s confusion. Using this notation, you can't prove that [itex]x(0) = y(0)[/itex] unless you make the additional assumption that the functions [itex]x[/itex] and [itex]y[/itex] are both continuous at zero, and then you can.
(For readers unfamiliar with the definition of "continuous", it means [itex]x(m) \rightarrow x(0)[/itex] as [itex]m \rightarrow 0[/itex].)
Yes, in the previous thread we all agreed that taking the limit is the mathematically correct way to deal with this.
I was a bit sloppy with the statement about functions. The theorem in post #30 holds even if we replace ##\mathbb R## with an arbitrary vector space, as long as we take S to be a set that contains the multiplicative identity of the associated field.
What I had in mind was situations like the one described in post #31:
yeah. this is how I would interpret it. And so from ##ma_m(s)=mg_m(s)##, we don't get ##a_m(s)=g_m(s)##, unless we also specify that ##a_m(s)## and ##g_m(s)## is the same for any permissible choice of ##m##. Which I suppose we can do, but if you are trying to logically derive some physics, I don't think it is a good idea usually.
A.T. said:
I disagree that it's unambiguous, because aside of the relationship
$$R_1: \hspace{10 mm} x=y$$
You mean the relationship between ##x## and ##y## depends on ##m## in the ##R_2## case? That is true, but is this ruled out by the preposition: ##mx = my## for all ##m## ?
So if the relationship between ##x## and ##y## depends on ##m##, we can only prove ##x=y## for the ##m > 0## case.
Yes, I obviously chose functions that are not continuous at zero, to demonstrate that you have to make that additional assumption.
The proof in 42 works even for discontinuous functions, which are still a vector space. You just have to make sure that you are treating them consistently, I.e. if x and y are functions then treat them as functions everywhere in the proof, not as functions in one place and reals in another.
I know that this thread is about the math, but we should look at the class of mathematical objects of interest to the physics, even if we don't specifically examine the physics itself.
The acceleration of a classical point object is a vector valued function of time a(t). The gravitational field experienced by a classical point object is also a vector valued function of time g(t). This does not place any restrictions on the continuity or differentiability of a or g.
The set of all vector valued functions of time, V, forms a vector space over the reals, F. The non-negative reals is a subset, S, of F which contains 1. Therefore, if ##ma=mg, \forall m \in S## then ##a=g## per the proof in 42 (which is just a generalization of Fredrik's proof).
Yes, there are some objects which are not part of a vector space and some quantities which are not subsets of a field on that vector space. Those would not be covered by the proof, but the case of physical interest is covered by the proof.
If the relationship depends on m, then at least one of x and y depends on m. So I would say YES to that question, because if x and y depend on m in any way, it would be absurd to hide this dependence behind a notation like "mx=my". This notation suggests extremely strongly that the short "mx=my for all m" is a shortened version of a statement of the form
Let x,y,m be arbitrary. Suppose that ##x,y\in\mathbb R## and that the following implication holds: ##m\in S\ \Rightarrow\ mx=my##.​
There's some ambiguity about what set S is, but we know that if it contains 1, then the assumption is strong enough to imply that x=y, as I've shown several times above.
Before we can prove anything, we have to take a different statement than "mx=my for all m" as the starting point, because I can't interpret "mx=my for all m" very differently from how I interpreted it above. So let's take "mx(m)=my(m) for all m" as the starting point. This would be a shortened version of the following statement.
Let x,y,m be arbitrary. Suppose that x and y are real-valued functions with domain S, and that the following implication holds ##m\in S\ \Rightarrow\ mx(m)=my(m)##.​
This assumption implies that ##x(m)=y(m)## for all ##m\in S-\{0\}##.
What do you mean by "hide the dependence"? We honestly don't know if the relationship between x and y depends on m or not, because we don't know what that relationship is. We are trying to derive that relationship, and at some point in that derivation we arrive at "mx=my for all m". Why should we assume that the relationship between x and y doesn't depend on m?
Yes, this is the essence of the problem. We cannot assume that x is independent of m because this is what DaleSpam is attempting to prove.
No, it isn't. I am only attempting to prove that if ##mx=my,\forall m \in S## then ##x=y##. Fredrick did so in post 3 for x and y in the reals and S the positive reals and I rather trivially generalized it in post 42 for x and y in any vector space and S a subset of the field. What I wanted to prove is proven and I have no desire to prove independence.
Is it? I didn't get that impression, but I must admit that I haven't read all his posts in detail. Edit: OK, I see now that DaleSpam has explicitly denied this in the post above this one.
I thought you started this thread to ask about what can be derived from the statement "mx=my for all m". As I said in my previous post, there no way I can interpret this as allowing x to depend on m. It's possible that I have misunderstood what you meant to ask when you started this thread, so maybe your question is something else entirely, but the question about the consequences of that statement is trivial.
I am pretty confused by all this. You started this thread in a math forum (it was later moved here), and at some point the notation got changed from g and a to x and y, presumably to further distance the discussion from the physics discussion where the statement "mg=ma for all m" was first made. These things seem to support that the thread is about that statement. But apparently it's not.
So what is it about? About proving that the empirically determined constant g=9.81 m/s2 doesn't depend on m? No, that can't be it. I'll tell you what it looks like to me. This thread is about the question "How do you find both the solution and the correct statement of a problem, when you only have a vague idea what the statement and the solution should be?"
Regarding independence. The dependence that A.T. and MrAnchovy are introducing makes it so that x and y are not elements of a vector space with m an element of the field (at least not in any way that I can tell). So the proof in 42 doesn't apply to those x, y, and m.
Fortunately, "vector spaces" is not too restrictive, and so, although the proof is not universal, it is useful for a broad category of practical problems. In particular, it is sufficiently broad to cover the physics that spawned the question.
That there exist x, y and m where it doesn't hold is fine, we at least know some of the places it does hold and we can use that relation in those cases.
I had the impression that this was the whole point of your original derivation. After all, it is the conclusion that you state at the end:
DaleSpam said:
##F=ma##
##GMm/r^2=ma##
##gm=ma##
##g=a##The acceleration is independent of mass, and is well defined.
So in order for your proof of x=y to work, you have to assume that such a dependence on m doesn't exist. And then you conclude from your x=y that in fact it doesn't exit.
It's been a long discussion. Two long discussions actually, but I have only partipated in one of them. None of us has been able to make it perfectly clear what we meant in every single post. It seems to me that what you're doing is to ignore the posts where DaleSpam made it perfectly clear what he meant, and focus only on the ones where he didn't.
I don't think it's unreasonable to describe the theorem
For all ##g,a,S## such that ##g,a\in\mathbb R## and ##1\in S\subseteq \mathbb R##, if ##mg=ma## for all ##m\in S## then ##g=a##.​
as "the acceleration is independent of mass". It's obviously not as clear a statement as the theorem, but it sounds like an attempt to summarize the content of the theorem.
Edit: Corrected ##1\subseteq S## to ##1\in S##.
Remember, you are trying to separate the math from the physics. The whole point of the math derivation is only to show that given ##mx=my,\forall m \in S## you do indeed get ##x=y##. That was the point of the physics derivation where you objected to the math, and that is the step which is justified here.
Since we were not trying to separate them in the other thread, the independence I mentioned there is obtained not only from this mathematical step but also from other knowledge of the physics (specifically that g is independent of mass). If you are satisfied with the validity of the math in 42 then we can go back and talk about the physics and see if you agree that it is legitimate to apply 42 in the specific case of the physical question that spawned this mathematical discussion.
I would recommend a separate thread for that. One which takes the math as an agreed upon starting point and returns to the physics. Do you have any objections to the proof in 42? Do you agree with its validity as stated?
