Maximizing DIY Battery Pack Capacity: Understanding Amp-hours vs. Watt-hours
This discussion clarifies the relationship between Amp-hours and Watt-hours in DIY battery pack configurations. When connecting multiple AA Alkaline batteries in series, the voltage increases while the Amp-hour capacity remains constant. Specifically, two 1.5 V 2700 mAh batteries connected in series will provide 3.0 V with a capacity of 2700 mAh, resulting in an energy output of 8.1 Watt-hours. Understanding this distinction is crucial for optimizing battery performance in robotics projects.
  • Basic understanding of electrical concepts such as voltage, current, and resistance.
  • Familiarity with battery specifications, particularly Amp-hours and Watt-hours.
  • Knowledge of series and parallel battery configurations.
  • Experience with basic physics principles related to energy calculations.
  • Research the differences between series and parallel battery configurations.
  • Learn how to calculate energy capacity using Watt-hours for various battery setups.
  • Explore the specifications and performance of different battery types, such as Lithium-ion vs. Alkaline.
  • Investigate battery management systems (BMS) for optimizing performance and safety in DIY projects.
This discussion is beneficial for university students, hobbyists, and engineers involved in robotics, particularly those focused on building custom battery packs for their projects.
CasVS
Hi,
I am a university student in the Netherlands and I just got the assignment of building a robot on a budget. Because of this budget I would like to make the battery pack that powers the 2 servo motors and 2 electric motors myself.
I did some research and found out it would be best to connect multiple AA Alkaline (1.5 V 2700 mAh) batteries. I know my basic physics as the current will stay the same and voltage adds up, though what about the capacity? I understand how this battery works but now my question was if I connect for example two batteries do I get a battery pack that can deliver 3.0 V with 5400 mAh, or just the 3.0 V with again a capacity of 2700 mAh.
Thanks in advance!
Think about it ... a little bit more and you will have answered your own question.:rolleyes::wink:
You sound like my physics tutors haha! I calculated the amount of Watts and think it is silly to assume that both the capacity and the voltage gets doubled. So from this I will assume that the battery pack would have a 8.1 W output with the 3.0 V and 2700 mAh!
Thanks
Ta-da.
See ? You new all along !
That's a pretty common source of confusion. Charge capacity in terms of Amp-hours does not change with the number of series cells, but energy capacity in terms of Watt-hours multiplies with the number of series cells. For a load that consumes a constant amount of power run time will double, for an ohmic load where power consumption goes up with voltage run time will not increase.
  • · Replies 16 ·
12K
