Do Air Molecules in a Sealed Elevator Accelerate Equally When It Speeds Up?
  • Context: Undergrad
  • Thread starter Thread starter Jazzyrohan
    Accelerating Elevator
The discussion revolves around the behavior of air molecules in a sealed elevator that begins to accelerate upwards. Participants explore whether all air molecules will accelerate equally with the elevator and the implications of this acceleration in relation to gravitational forces and pressure differentials.
  • Some participants propose that if a sealed elevator accelerates upwards, all air molecules inside will not necessarily accelerate with the same acceleration, suggesting that individuals inside may feel the air moving in the opposite direction.
  • Others argue that a body in an accelerating frame has the same acceleration as that of the frame if it is in direct contact, which raises questions about the behavior of air molecules that are not in direct contact with the elevator walls.
  • A participant mentions the equivalence principle, comparing the scenario to a decompression chamber, questioning whether air would pool at the bottom if the elevator were accelerating.
  • Some responses highlight the need to consider the initial conditions of the elevator, such as whether it is in gravity-free space or subject to Earth's gravitational force, and how this affects the air's behavior.
  • There is a discussion about the potential for pressure differentials within the air in the elevator due to acceleration, with one participant suggesting that this effect might be measurable under certain conditions.
  • A participant references a video that illustrates the concept of acceleration in a different context, emphasizing the complexity of visualizing these effects.
  • Another participant provides information about measurement devices that can detect changes in air pressure, suggesting that such devices could demonstrate the effects of acceleration on air molecules.
Participants express differing views on whether air molecules will accelerate equally with the elevator, with some supporting the idea of differential acceleration and others questioning this perspective. The discussion remains unresolved, with multiple competing views present.
Participants reference various scenarios, including the effects of gravity and the presence of sufficient air for breathing, which may influence the behavior of air molecules in the elevator. There is also mention of the limitations of human measurement devices in detecting subtle pressure changes.
Jazzyrohan
If a sealed elevator moving with a constant velocity in upward direction suddenly starts accelerating upwards with an acceleration "a" ,will all the air molecules inside the elevator also accelerate with the same acceleration?
Jazzyrohan said:
If a sealed elevator is accelerating upwards with an acceleration "a" ,will all the air molecules inside the elevator also accelerate with the same acceleration?
What do you think and why?
A body in an accelerating frame has the same acceleration as that of the frame if it is in direct contact with the frame,right?
So I think the air molecules will not be moving with the same acceleration and someone in the elevator will feel the air accelerating in the opposite direction.
Am I right?
Jazzyrohan said:
Am I right?
Remember the equivalence principle - this is similar to being in (for example) a decompression chamber at rest on the Earth's surface. If you are correct, in a decompression chamber there would be a downwards wind until the air pooled on the floor.
Am I right?
Where is your elevator initially? In gravity-free space? Where is the someone in the elevator initially? What happens to someone in the elevator as it accelerates? If there were only one air molecule (or a million) in the elevator, what would happen to that? If there is enough air in the elevator for someone to breathe, how does that change things?
The elevator is subject to gravitational force on earth.That someone is standing on the floor in the elevator.
Have you ever been in an elevator? Did it feel like the air was moving down?
Am I right?
I think there is a subtly that has been missed in the responses so far. Those responses are looking at the macro level and correctly pointing out that your idea (apparently) that the air would pool at the bottom of the elevator is a non-starter. BUT ... they are overlooking the fact that you are right at one level in that the air in a non-accelerating elevator car in space would distribute itself evenly whereas the air in an elevator car on the ground on Earth or accelerating at 1G in space, WOULD in fact have a differential of air pressure due to the acceleration. I don't know if human measurement devices exist that can tell the difference in air pressure over, say, 10 feet at 1G, but if they could it would be there.
Perhaps you missed this:
Didn't miss it but missed the point (so effective missed it, yeah)
This video demonstrates the action graphically. In the video, the acceleration is horizontal, thus eliminating the complication of Earth's gravity.
I must admit, that "balloon goes the wrong way" thing is one where, even knowing how and why it works, something low down in my brain just goes "Nuh uh! Must be fake!" Even when I'm watching it in reality.
There is, and it does:
The image is of an aircraft altimeter showing 920 feet altitude above mean sea level at a barometric pressure reading of 29.92 inches mercury. The skinny hand is 10,000 feet per numbered division, the short hand is 1000 feet per division (10,000 feet per revolution), and the large hand is 100 feet per division (1000 feet per revolution). The little tick marks are 20 feet apart.
You could also use an ordinary barometer. One thousand feet of altitude change is one inch of mercury pressure change, so 10 feet is 0.01 inch mercury. A good barometer should show that if you tap it lightly.
Or you can calculate the rate of change of pressure with altitude. It's the same rho*g*h calculation used for liquids. Rho for air is about 0.0765 lbs/cubic foot at standard temperature and pressure.
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 38 ·
