ohwilleke
- 1,651
Actually, that isn't the case.PeterDonis said:A key weakness that I see in Deur's models as alternatives to dark matter is that they only address the specific case of galaxy rotation curves. But that is not the only case in which the dark matter hypothesis comes into play in the current Lambda CDM model of our universe. As far as I can see, Deur's models give no help at all in avoiding the dark matter hypothesis in, for example, the evolution of the early universe. His model depends on gravitational properties of isolated bound systems like galaxies and does not even apply to relatively uniform matter distributions like those in the early universe, before gravitational clumping became significant.
Early Universe Cosmology Evidence for Deur's Approach
The most recent paper that I cited above is precisely above the evolution of the early universe, a subject only addressed more tangentially in earlier papers:
Alexandre Deur, "Effect of gravitational field self-interaction on large structure formation" arXiv: 2018:04649 (July 9, 2021) (Accepted for publication in Phys. Lett. B) DOI: 10.1016/j.physletb.2021.136510
As the body text of that article explains:
Fig. 2. Time-evolution of a baryonic overdensity δ. The initial value of δ at the recombination time, t ≈ 3.7 Gyr, is 2 × 10−5. The band shows the evolution including field SI effects, with the central solid line corresponding to the nominal DM−1(t). The dashed line is the evolution without SI. In neither case, dark matter has been assumed.
The picture for structure growth that emerges from the result showed in Fig. 2 is that at early times, SI [Ed. i.e. gravitational field self interaction] did not influence the Jeans collapse mechanism since the initial overdensities were spherical. Mergings of overdensities would also not be significantly enhanced since density anisotropies would be too small to trigger the onset of SI. At later times, the overdensities lose their spherical symmetry due to mergers and radiative energy dissipation. The SI-enhanced internal binding then accelerates local collapses. As anisotropies become denser, merging rates increase, especially for overdensities that had so far retained their spherical shape. The quantitative analysis shows that the SI-enhanced gravitational interaction is sufficient to form structures reaching the present-day densities, without requiring dark matter. We have considered here the time-evolution of δ and not the related subject of matter's spatial distribution. As shown in Ref. [10], the same formalism also yields a position of the peak of the matter power spectrum of keq≃0.014 Mpc−1, in agreement with observations.
The cosmology conclusions in Reference 10 (a prior published paper by Deur, i.e.
A. Deur, Eur. Phys. J. C, 79 (2019), p. 883 arXiv:1709.02481) are as follows:
A. Supernova observations
Explaining supernova observations with GR’s self-interaction is the focus of this article. These observations are that the large-z (0.1 . z . 1.5) supernova apparent luminosities are dimmer, viz their apparent magnitudes are larger, than expected from a homogeneous and isotropic decelerating Universe. This is interpreted as evidence for an accelerating universe, i.e. for Λ > 0. However, we show in this section that lifting the approximations of homogeneity and isotropy can also explain the observations, while keeping Λ = 0. From the luminosity distance DL(z), Eq. (23), the apparent magnitude DL(z)H0 of events can be calculated. Assuming Λ = 0, taking H0 = 68 ± 1 km/s/Mpc, . . . we compute the band shown in Fig. 3. . . . Our calculation agrees well with the γ-ray bursts and supernovae data. There is no adjustment to these data, all the parameters in DM being constrained by observations of large structure evolution. Also shown in the figure are the calculations for the cases of a homogeneous and isotropic Universe with only matter (dotted line), that for an empty Universe (continuous line) and the ΛCDM (dark energy, cold dark matter) model (dashed line). The difference between the observations and the expectation from a homogeneous and isotropic Universe with Λ = 0 is clearer by forming a residual apparent magnitude:
r(z) = 5 log H0 DL(z) 1 + z − 5 log H0 z + z 2/2 1 + z , (27)
with the last term corresponding to the empty Universe case. Positive values of r(z) indicate fainter apparent luminosities than expected in the case of an empty Universe. They constitute the best evidence for Λ > 0. Our calculation of r(z) with Λ = 0 agrees well with the observations.
FIG. 4: Residual between observed apparent magnitudes (γ-ray bursts: star symbol. Supernovae: other symbols) and their expectation from an empty universe. The continuous line is for the ΛCDM model. The band is the present work, without any free parameters adjusted to the γ-ray or supernova data.
We now outline how GR’s self-interaction may also explain the observations providing less direct evidence for Λ > 0.
B. Age of the Universe
Without Λ > 0, the calculated age of the Universe would be 11.7 ± 0.2 Gyr for the standard ΩM = 0.32 value and for H0 = 68 ± 1 km/s/Mpc. This conflicts with the measured age of the oldest stars, up to ∼ 13.5 Gyr. The ΛCDM model, with ΩΛ = 0.68 and the same H0 and ΩM values, yields 13.6 ± 0.2 Gyr. GR’s self-interaction also solves this problem, while keeping Λ = 0: Eq. (24) yields a compatible Universe age of 13.2 ± 1.7 Gyr.
C. Large structure formation
In a Universe without gravitational self-interaction or dark matter, large structures do not have time to coalesce. What happens in the self-interaction framework can be sketched as follow: As DM(z) departs from 1, viz as gravity weakens globally, energy conservation demands that the global weakening is balanced locally by an increase of gravity within the structures themselves, thus speeding up their formation compared to a Universe without self-interaction. Since DM(z) evolves following the formation of large structures, gravity strengthens locally with the same timeline. Because strengthening reproduces the dynamics of galaxies and clusters, the local effect of self-interaction is equivalent to the effect of dark matter. Furthermore, the position of the peak of the matter power spectrum is now given by keq = H0 p 2Ω∗ M(0)/aeq, with aeq the scale parameter at zeq. Assuming ΩBaryon = ΩM (no dark matter) and using Ω∗ M = ΩMDM yield Ω∗ M(0) ' 0.3, i.e. keq = 0.014, in agreement with observations. This suggests that the present approach is compatible with large structure formation.
D. CMB and BAO
The CMB main acoustic peak position depending on the Universe dynamical evolution, its calculation in the present framework involves Ω∗ M rather than ΩM. Thus we have now θ ' p Ω∗ M/zrec (with zrec ' 1100 at the recombination time), resulting in θ ' 0.8 ◦ , which agrees with observations. Predicting the smaller features of the CMB and the BAO is complex and, like for large structure formation, beyond the scope of this first article.
E. Other consequence
Field trapping naturally explains the cosmic coincidence, i.e. that in the ΛCDM model, dark energy’s repulsion currently nearly compensates matter’s attraction, while repulsion was negligible in the past and attraction is expected be negligible in the future. No natural explanation exists within ΛCDM for this apparently fortuitous coincidence. In the present approach, structure formation depletes attraction and thus, compensating it with a repulsion, viz dark energy, is unnecessary. Thus, there is no coincidence and hence no need for explanation.
It has long been known that modified gravity approaches, generically, tend to solve the "impossible early galaxies" problem of ΛCDM by speeding up structure formation. See, e.g., Llinares et al. 2008 ("we find that the large-scale structure evolution is faster in our revised MOND model leading to an even stronger clustering of galaxies, especially when compared to the standard LCDM paradigm."). See also Sanders 1998, McGaugh 1998, McGaugh 1999, McGaugh 2000, Sanders 2001, Nusser 2002, Stachniewicz & Kutschera 2002, McGaugh 2004, Skordis et al. 2005, Feix 2016, Khoury 2016.
Meanwhile, the ΛCDM model when compared with observational data at the larger cosmology scale also fails the test of the new EDGES 21cm wavelength radiation data that demonstrates the temperature of the universe at 180 million to 280 million years after the Big Bang. This is inconsistent with the ΛCDM model because the universe was much colder than predicted and is instead consistent, generically, with a no dark matter hypothesis.
Also, finally, last year, a relativistic modified gravity theory that reduces to MOND in the limit has reproduced the crown jewel of LambdaCDM, the CMB patterns that are observed. See Constantinos Skordis, Tom Złosnik, "A new relativistic theory for Modified Newtonian Dynamics" arXiv (June 30, 2020). And, given that Deur's model is very close to MOND at the galactic rotation curve level, the likelihood that Deur's approach can achieve the same result is much more plausible than it was two years ago. In another proof of the concept that modified gravity theories can get the CMB right, Moffat's MOG theory did so in 2014.
Other Non-Galaxy Rotation Curve Evidence
Furthermore, keep in mind that unlike many modified gravity theories, this isn't just galaxy rotation curves in addition to this recent paper on the early evolution of the universe discussed above.
It is also planar alignments of satellite galaxies. It is cluster dynamics and the Bullet Cluster. It is all dark energy phenomena (in a manner equivalent to dark energy that is not a pure cosmological constant as the data increasingly slightly favor).
It is providing a theoretical grounding from first principles for phenomena that other gravitationally based approaches to dark matter and dark energy phenomena have only described with phenomenological fits to observations.
Conclusion
One of the things that makes this approach so attractive is that it has a domain of applicability that is broader than almost any other gravity based approach out there right now, with the possible exception of Moffat's MOG theory (which manifestly deviated from GR and designed simply to fit observations without a clear theoretical foundation). MOND doesn't address dark energy or cluster scale phenomena correctly. Meanwhile, many other modified gravity theories proposed by GR researchers provide alternatives to the cosmological constant/dark energy, but don't solve dark matter phenomena.
Also, while there are areas of this approach that simply haven't been developed yet by the sole primary researcher working on this in addition to this day job in QCD physics (e.g. CMB, derivation of MOND constant from Newton's constant, wide binaries, external field effects), there are so far, no instances of clear contradictions with observation, or theoretical inconsistencies that have been identified.
