Do gravitons interact with gravitons?
  • Level: Undergrad
  • Thread starter KurtLudwig
    Gravitons
100 replies · 12K views · last reply
I am working on something similar to that of Dr. Alexandre Deur. I am also using the self-interaction of gravity. But I'm doing the self-interaction in reverse of how he's using it. And I am getting very good results in fitting to the rotation curves of the galaxies.
Sincerely.
Dr. Rigoberto Carbajal Valdez
Sincerely.
This is my email.
rcarbajal68@gmail.com
Have you published anything (even a pre-print) that someone could see?
As @ohwilleke has pointed out, we need a reference (a published peer-reviewed paper) in order to have a basis for discussion.
I wonder if https://www-livescience-com.cdn.ampproject.org/v/s/www.livescience.com/amp/gravitational-wave-detector-strange-bumps.html?amp_js_v=a6&amp_gsa=1&usqp=mq331AQIKAGwASCAAgM%3D#aoh=16324719503472&csi=0&referrer=https%3A%2F%2Fwww.google.com&amp_tf=From%20%251%24s&ampshare=https%3A%2F%2Fwww.livescience.com%2Fgravitational-wave-detector-strange-bumps.html is relevant at all
If GR with self-interaction reproduces all verified MOND predictions (including the EFE) while retaining the beautiful symmetries and general framework of gauge fields and the standard model of particles:
THAT'S AWESOME!
Good morning. I am working on that, in collaboration with another Doctor, as soon as I have something I will share it through this forum. Thank you.
DanielJoseph said:
I wonder if https://www-livescience-com.cdn.ampproject.org/v/s/www.livescience.com/amp/gravitational-wave-detector-strange-bumps.html?amp_js_v=a6&_gsa=1&usqp=mq331AQIKAGwASCAAgM%3D#aoh=16324719503472&csi=0&referrer=https%3A%2F%2Fwww.google.com&_tf=From%20%251%24s&ampshare=https%3A%2F%2Fwww.livescience.com%2Fgravitational-wave-detector-strange-bumps.html is relevant at all
Not really.
THAT'S AWESOME!
FWIW, this particular effort does not resolve deep inconsistencies between classical GR and the quantum mechanical foundation of the Standard Model, and indeed, can be formulated in a purely classical sense, although the motivation for the work was rooted in quantum gravity concepts. But assuming it is correct (which is hard to verify as few other in the field have examined it closely) it is indeed awesome.
The latest paper in the series of papers cited earlier is the following:
Line graph of the CMB power spectrum, l(l+1)C_l/2π against multipole l from 0 to about 1800, with a red curve labelled CMB Power spectrum with field self-int. fitting blue Planck data, 2018 points with error bars and multiple acoustic peaks.
Figure 2 from the paper
Field self-interactions are at the origin of the non-linearities inherent to General Relativity. We study their effects on the Cosmic Microwave Background anisotropies. We find that they can reduce or alleviate the need for dark matter and dark energy in the description of the Cosmic Microwave Background power spectrum.
A. Deur, "Effect of the field self-interaction of General Relativity on the Cosmic Microwave Background Anisotropies"
arXiv:2203.02350 (March 4, 2022).
The introduction in the body text explains:
The power spectrum of the Cosmic Microwave Background (CMB) anisotropies is a leading evidence for the existence of the dark components of the universe. This owes to the severely constraining precision of the observational data and to the concordance within the dark energy-cold dark matter model (Λ-CDM, the standard model of cosmology) of the energy and matter densities obtained from the CMB with those derived from other observations, e.g. supernovae at large redshift z. Despite the success of Λ-CDM, the absence of direct or indirect detection of dark matter particles is worrisome since searches have nearly exhausted the parameter space where candidates could reside. In addition, the straightforward extensions of particle physics’ Standard Model, e.g. minimal SUSY, that provided promising dark matter candidates are essentially ruled out.
Λ-CDM also displays tensions with cosmological observations, e.g. it overestimates the number of dwarf galaxies and globular clusters or has no easy explanation for the tight correlations found between galactic dynamical quantities and the supposedly sub-dominant baryonic matter, e.g. the Tully-Fisher or McGaugh et al. relations.
These worries are remotivating the exploration of alternatives to dark matter and possibly dark energy. To be as compelling as Λ-CDM, such alternatives must explain the observations suggestive of dark matter/energy consistently and economically (viz without introducing many parameters and fields). Among such observations, the CMB power spectrum is arguably the most prominent.
Here we study whether the self-interaction (SI) of gravitational fields, a defining property of General Relativity (GR), may allow us to describe the CMB power spectrum without introducing dark components, or modifying the known laws of nature. GR’s SI already explains other key observations involving dark matter/energy: flat galactic rotation curves, large-z supernova luminosities, large structure formation, and internal dynamics of galaxy clusters, including the Bullet Cluster. It also explains the Tully-Fisher and McGaugh et al. relations. First, we recall the origin of GR’s SI and discuss when it becomes important as well as its overall effects.
Although I am now a great fan of Deur's theory, this last paper is not so much to my liking. It would have been great if Deur had brought it like "okay, so the CMB is explained this way by lambda CDM and if you really want to reproduce the CMB that way, in principle it can also be done without dark matter".
My issues are:
  1. This CMB graph from the Big Bang is a postdiction, not a prediction. And with 6 free variables.
  2. The CMB in this interpretation ought to be dampened by cosmic dust, which is not reckoned with in Lambda-CDM or Deur's paper. See Vavrycuk's paper and video.
  3. The Big Bang explanation assumes inflation, which is an unfalsifiable idea for our current experimentation range.
  4. I'm a believer in the bible, and there's good reason to reject the Big Bang as description of how God created the universe. An alternative explanation is given by for instance Russell Humphreys' book Starlight and Time.
In general, my great liking of Deur's theory is slightly dampened by the fact he attaches such importance to accomodating a Big Bang scenario alike to how the lambda-CDM community preaches it. For my taste this paper handles a detail not worth a paper so early in Deur's on the whole extremely prudent approach.
Nevertheless I'm a big fan of his work! :-)
  • Skeptical
  • Haha
There is no reason for you to investigate science in that case.
Please note this is off topic here; this forum is about physics, not religion.
As to how the universe came into being, I do admit that for what I believe about it I don't currently need a scientific technical description of it. But it may certainly help! And if my belief doesn't match what hardcore science tells I will feel this need a lot indeed! Indeed I felt it pretty much until I found Vavrycuk's research. Belief must be factual or it is useless.
As to it being off-topic, isn't there a saying "nature doesn't care what you think?". This saying expresses the belief in an absolute entity and its order. So shouldn't you tell Newton and Einstein, who started science based on such belief?
Contrary to having no reason to investigate science, in my personal interests I've noticed this: exactly because I believe in an absolute entity that governs the laws of physics and made them, I become very curious as to how these laws work and every aspect of them. I feel they were made by the greatest genius - God, whose genius is expressed by the results of many experiments - and that makes me all the more curious.
  • Skeptical
  • Haha
Yes, there is such a saying. Here are examples of applying that saying: nature doesn't care that your belief in God leads you to think that the Big Bang theory is not correct. Nature doesn't care that you've read of some alternate theory that you like better.
However, that saying is irrelevant to whether or not discussions of religion are off topic here. They are off topic here because the PF rules say so. It has nothing to do with what nature does or does not "care" about. Nor does it have anything to do with what you think.
That's fine, and learning about that is what PF is for. But any claims about what laws you think are correct need to be based on scientific evidence.
And see the discussion in that thread. It gives plenty of good reasons not to believe that "cosmic dust" is a significant effect.
With my mentor's hat on, while I have no issues with what has been written, it must not degenerate into philosophy by forum rules. Please note it is not because we have anything against philosophy; it's just when we allowed it because we do not have an expert mentor in it, it degenerated into a mess. So please keep that in mind.
Thanks
Bill
I will from now on adhere to this rule, didn't know about it. Therefore I won't tell you what I think of this rule, that would violate the rule.
Well I've looked through the paper and Vavrycuk's video and I don't see anything unscientific in his approach. FYI, Vavrycuk supports no biblical view at all but some kind of Cyclic Cosmology. What bothers me is that people react with closing the thread and scorn for Vavrycuk, which is exactly how a scientific community should NOT react to new results and theories. Investigate everything and keep what has proven to be good. And certainly don't use scorn as a way to shrink the credibility of a theory that is unorthodox.
  • Skeptical
I didn't say his paper was unscientific. I said that the discussion in the other thread gives plenty of reasons not to believe that the "cosmic dust" he hypothesizes is a significant effect.
PF's primary purpose is not to discuss "new results and theories" that the scientific community is still evaluating. It is to help people understand science that is already mainstream. PF's reaction is emphatically not the same as the reaction of the "scientific community". If you want to know how other researchers in the field react to Vavrycuk, you will need to look at scientific papers, not PF.
That said, if a particular paper has issues, PF members are perfectly within their rights to point out those issues.
don't use scorn
Pointing out issues with a paper is not "scorn". Nor is pointing out that a statement made by someone who calls themselves a scientist and claims to be an expert in a field is seriously inconsistent with basic knowledge in the field.
No, it doesn't. Inflation is just one hypothesis for what happened before the Big Bang (i.e., before the hot, dense, rapidly expanding state that is the earliest state of our Universe for which we have good evidence). It is not the same as the Big Bang model itself.
That happened, and his paper was not kept. So what's the problem?
If the proposal is weak to begin with it will be dismissed quickly. We can't spend an unlimited time on everything everyone has ever proposed anywhere. There is a time to move on. People who never realize that will keep defending something dead until they retire.
Just list the arguments against for me. Vavrycuk had just enough time to answer 1 question, then the thread was banned.
What would falsify this earliest state? The Hubble tension? Too large structures like this one? Too big galaxies at high redshift? That if string theory is correct, the 168m Ethan Siegel gives for the universe right after inflation might be far too small to contain all those strings? It's far smaller than the scharzschild radius would be.
I think these each don't falsify the initial state entirely, correct? But still it's not settled IMO that we have conclusively proven this.
The reason for that was given in the thread.
Further discussion of that other thread is off topic here. Please stick to the topic of this thread.
You can't falsify a "state". You would have to falsify the entire class of "Big Bang" models that have the universe starting from such a state and expanding to the state we have now. Note that our best current model is only one model in that class; falsifying it is not the same as falsifying the entire class of models. In particular, finding an alternative explanation for galaxy rotation curves that does not involve dark matter is not the same as falsifying the entire class of "Big Bang" models.
You protest about unproven models and yet you are bringing in string theory? I think you need to take a step back here.
Please give a reference.
Irrelevant since the spacetime geometry in Big Bang models is not the Schwarzschild geometry; the early universe in Big Bang models is rapidly expanding, not static.
Moreover, all of this is off topic for this thread. I suggest you take more time to learn basic cosmology. If you have a reference discussing issues with the Big Bang model and you would like to ask questions about it, please start a separate thread. Please keep discussion in this thread focused on the topic of this thread.
I also have become enamored of Deur’s theory that explains a host of astrophysical phenomena by just a single consideration – gravitational self-interaction (SI). But I wondered if there might be a problem with gravitational lensing. Since his model dispenses with Dark Matter and the gravity field beyond a galaxy or cluster is already reduced due to SI within those structures, it would seem there wouldn’t be sufficient gravity outside such structures boundaries to induce the observed lensing. But it could be this issue is already addressed in one of his papers, which I haven’t come across.
Thinking about it some more it occurred to me that the reduced g-field outside massive astronomical structures, in his model, might lead to a sufficient gravity field gradient to induce the same space-time curvature as would be the case if the gradient were shifted into a stronger range as in the Dark Matter picture. But, I’m just guessing here how his model would handle lensing, since I’m not really sure if such a heuristic idea is compatible with General Relativity
What you are calling "gravity field gradient" is an effect of spacetime curvature, not a cause. In any case, "reduced g-field outside massive structures" is a highly heuristic and imprecise way of describing what is going on in Deur's models, and should not be used as a basis for trying to reason out their consequences. (Note also that only some of Deur's proposed models even have this property, and those are the more speculative ones, that add additional quantum gravity-type effects on top of the straightforward classical effects I describe below.)
Deur's models, in general, do not change the Einstein Field Equation and do not postulate any different "source" of spacetime curvature as compared to standard GR. His basic idea is simply taking into account properties of particular solutions of that equation (such as disk-shaped rather than spherical gravitational sources) that other researchers had ignored on the assumption that they were too small to matter, whereas Deur attempts to show that that is not the case, that those properties do matter, and that taking them into account means the visible matter in galaxies can account for things like their rotation curves, using the standard Einstein Field Equation, without having to add invisible (dark) matter to the gravitational sources. (In some of his proposed models, as noted above, he does add quantum gravity effects that aren't present in classical GR.)
Thank you for having taken the time to read some of these papers sufficiently to understand what Deur is trying to do accurately. Your summary here expresses the gist of it clearly and succinctly. The effort you have taken to investigate and understand this not widely cited body of work is appreciated.
Andrew Ohwilleke
I've been reading your excellent write-ups on Deur's models and was wondering if you have come across any mention of how either the quantum or classical versions of his models deal with gravitational lensing. I did a google search, but so far haven't found anything connecting gravity self-interaction and gravitational lensing.
I have to say this is the most interesting thread that I have read anywhere on Deur's work, which I am keenly interested in. The back and forth dialogue is very informative. I just can't help but wonder if his efforts will lead to a major paradigm shift in our understanding of nature at the largest scales.
I didn't mean to imply that "gravity field gradient" was the cause of spacetime curvature. I'm fully aware that in a given region of spacetime the curvature is determined by the distribution of matter and energy. My bad, I bungled it.
As far as "reduced g-field outside massive structures" as being "highly heuristic and imprecise way of describing what is going on in Deur's models". In comment 35 of this thread Deur states (in a quote box) "Likewise 2 in gravitational systems the increased binding due to GR's SI weakens gravity's action at large scale". He clearly is conveying this in a much more professional and exact way. I'll try to do that in the future.
Now back to how lensing is handled in Deur's SI models. The Bullet Cluster is one of the most studied lensing systems in astronomy so would be a great test for the SI approach. Unfortunately, I haven't been able to pin down any good info on what the baryonic mass of the various components of this system are. Popular descriptions, like in Ethan Siegel's blog, invariably state that "most" of the baryonic mass is in the ionized gas clouds between the clusters, usually cited as 90% of the system's baryonic mass. But then I came across a physics.stackexchange post titled "Bullet Cluster and Mond" where "ProfRob" states that 9% of the baryonic mass is in the form of hot gas and 11% is within the visible galaxies forming the clusters. The remaining 80% of the system's mass is in the form of Dark Matter, that is gravitationally centered on the two clusters, based on lensing data. This is drastically different than what popular expositions say.
But, if these mass ratios are correct then the dark matter in each galaxy cluster would be about 7 times the baryonic mass for each cluster. So with SI (and Mond also) dispensing with dark matter both of these models have to somehow be able to replicate the lensing that in LCDM is mostly attributed to dark matter. It seems like a pretty tall order, but hopefully Professor Deur is aware of this lensing issue and has either been able to explain it his SI paradigm or is working on it.
