Do internodes break in runners?
  • Thread starter Thread starter gracy
    Break
Runners are horizontal stems that produce buds, which can develop into new plants. The discussion centers on whether internodes can break and if this affects the survival of new plants. It is confirmed that if internodes break, the new plants can thrive independently, as they develop their own root systems. If internodes remain intact, the plants can still grow successfully. The distinction between runners and stolons is clarified; while both can produce roots and form independent plants, they differ in origin—stolons arise from lower branches and grow downward, while runners emerge from axillary buds and grow horizontally. Both structures can reproduce vegetatively, and the definitions of runners and stolons are seen as helpful but not absolute, as plants often exhibit varied behaviors that defy strict botanical classifications.
gracy
Runners are stems that grow horizontally above the ground. They have nodes where buds are formed. These buds grow into a new plant.
The thing I want to ask is does internode break?In a video I have seen internodes break and then the new plant lives independently ,is it right?Do internodes really break?
Biology news on Phys.org
If the internodes break, the new plants will be perfectly able to survive independently of the original plant as it will have all the necessary components (e.g. is own root system) to do so.
Likes gracy
And if internodes do not break?
Then the plant can still grow fine. After the bud establishes is own root system, I'd suspect the plants will be fine whether the internodes are intact or broken.
Likes gracy
According to wikipedia, runners and stolons are the same thing.
Likes gracy
I have found out that sub aerial stems develop from lower branches of stem are called stolon while side stem which grows out from bud at the base of the main stem is called runner.stolon grows obliquely downward while runners (sub aerial stem)creep horizontally on the soil.Stolon has adventitious root .I don't know about runners whether they have true or adventitious roots.
Is it correct?
Adventitious literally means out of place. This is purely for us humans - the plant is doing just fine, thank you, because it evolved to reproduce vegetatively and well as sexually. You can create adventitious roots at home by cutting an herb stem with a few leaves on it off, and placing the cut-off piece into a glass of water. This is called rooting.
You can induce rooting with stolons or with runners by burying them or cutting them off from the parent and doing the glass of water trick.
So they really are very similar. Plant anatomy has a slightly different viewpoint. It deals with the origin - the tissues from which a structure developed - of structures like stolons and runners. If I recall correctly - stolons arise from the cambium in the stem, and runners arise from axillary buds (or the meristem in the bud, more correctly).
The point is the what differentiates them not what they look like, or whether they have roots. but where they arise. Either can create roots - either can break off from the parent to form an independent plant. Sometimes this feature kinda runs amok and you get dangling "babies" Chlorophytum - spider plant:
Sorry about the advertisement - this is the only one I could find showing "babies":
http://www.joann.com/28in-spider-plant/7856081.html?mkwid=x0sHCDie|dc&utm_source=google&utm_medium=cpc&utm_term=&utm_campaign=Shopping+-+Home+Decor&CS_003=12310478&CS_010=[ProductId]&gclid=Cj0KEQjw9JuuBRC2xPG59dbzkpIBEiQAzv4-G_cIIulLf_SfdrNOV2oNbNaFsnlkcpBH4IfjeZC-F18aAv-U8P8HAQ
Chlorophytum:
https://en.wikipedia.org/wiki/Chlorophytum_comosum
So this plant has a kind-of "stolon-runner" which does not fit the definition about stolons having roots.
Actually these definitions are great for starters but, darn it, plants in the real world cannot read Botany books. So they do all kinds of weird things.
Likes gracy
You wrote a lot.Congrats that paid off. I actually understood !:smile:
  • · Replies 35 ·
  • · Replies 19 ·
