Do Light Wavelengths from the Sun's Edges Differ from Its Center?
The discussion centers on whether light emitted from the edges of the sun has a different wavelength compared to light emitted from the center of the sun's disk. Participants explore various aspects of this question, including the implications of the Doppler effect, limb darkening, and gravitational influences on light emission.
  • Experimental/applied
  • Some participants suggest that there may be a small difference in wavelength due to the sun's rotation, with one edge moving towards the observer and the other away.
  • Others question whether any experimental data exists to confirm these potential differences in wavelength.
  • One participant proposes that the Doppler effect could be calculated based on the speed of the emitting surface, indicating that the frequency of light is influenced by the velocity of the source.
  • It is noted that limb darkening may contribute to a small shift favoring longer wavelengths, alongside a slight Doppler shift.
  • Some participants reference the Fraunhofer lines as evidence of different wavelengths emitted from the sun.
  • There is mention of using the Doppler shift between the eastern and western solar limbs to determine the solar surface's rotation rate.
  • Concerns are raised about the sensitivity of instruments to measure the small Doppler differences due to the sun's differential rotation.
  • One participant introduces gravitational effects that may lead to redshifting of photons emitted from the sun's edges, in addition to the rotational Doppler shift and limb broadening.
  • There is a discussion about the nature of the photosphere and whether it can be considered a surface, given its gaseous composition.
Participants express a range of views, with some agreeing on the existence of wavelength differences due to various effects, while others remain uncertain about the significance and measurement of these differences. The discussion does not reach a consensus on the extent or implications of these effects.
Participants highlight limitations in measuring very small differences in Doppler shifts and the dependence on definitions related to the photosphere's nature.
mcgucken
When we look at the sun, does light emitted from the edges of the sun have a different wavelength than light emitted from the center of the disk?
Astronomy news on Phys.org
I would imagine that there is a small difference. Since the sun rotates on its axis, one edge is accelerating towards us and the other away. So the biggest difference would be from edge to edge across its equator.
Has anything like this been measured? Is there any experimental data regarding this? Thanks!
I would tend to think it does not because all light moves through space at the speed of light but there could be a bit more light dencer perhaps at the center of the sun disk than at the edge hmm ill do some more research interesting question.
I am thinking the inverse square law would apply to measuring...
You would be referring to the Doppler effect. It would be a simple matter to take the speed of the emitting surface and calculate the Doppler effect. One could confirm by looking at the Doppler shift of emission lines from the edge of the sun rotating toward and the edge rotating away, to which GOD__AM alluded. I don't believe the effect is significant, IIRC.
Certainly the speed of light is constant, the frequency however is influenced by the speed (velocity) of the emission source.
There is a small shift favoring longer wavelengths due to limb darkening. There is also a very slight doppler shift.
Fraunhoffer Lines first analysed by Fraunhoffer himself depicted different wavelengths coming from the sun.
BJ
Yes, and the difference in wavelength (doppler shift) between the eastern to the western solar limb (at the equator) is how we can determine the amount of rotation of the solar surface...
Creator :smile:
Creator :smile:
Being just gas of increasing density, I don't really know if we can call it (the photosphere) a surface.(?) Also, since the Sun has a differential rotation of about 25 days at the equator and ~29 days at high latitudes, does anyone know (legit question) if we have instruments sensitive enough to measure the very small difference (doppler) between the approaching and receding "edges"? 25 days in a long time for one rotation... :confused:
I had always thought that we observed the rotation rate by observing sunspots and convection granules at different latitudes.
Labguy said:
...does anyone know (legit question) if we have instruments sensitive enough to measure the very small difference (doppler) between the approaching and receding "edges"? 25 days in a long time for one rotation... :confused:
The Michelson Doppler Imager has a resolution of about 20m/s [compared to the solar equatorial revolution speed of about 2000m/s].
http://soi.stanford.edu/science/obs_prog.html
Astrometric dopplers can resolve line of sight velocities down to about 3 m/s [!].
There are gravitational effects that draw the photons emmited from the outer edges toward the centre of the sun-observer axis in accordance with einsteins theory of general relativity. So the photon energy is decreased as energy is lost gravitationally, therefore further redshifting emmitted photons from the outer edges in addition to the aforementioned rotational doppler shift and limb broadening.
Labguy said:
Being just gas of increasing density, I don't really know if we can call it (the photosphere) a surface.(?) .
The layer of gas in the sun that emits visible light (the photosphere) is relatively thin, and from Earth it looks like a surface.
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 49 ·
