Do spinning objects really lose weight?
69 replies · 34K views · last reply
Dadface
- 2,489
- 105
1. spin-vb to rotate or cause to rotate rapidly,as on an axis.
2. rotate-vb to turn or cause to turn about an axis revolve or spin
3 revolve-vb-to move or continue to move around a centre or axis;rotate
(definitions taken from Collins concise dictionary)
I did not want to get involved in semantics but I think that words such as spinning are more appropriate than the word orbiting when applied to real gyroscopes and the like.In post number 19 granpa summarised it wonderfully when he wrote that the point mass is partially orbiting the centre of the earth.It is a phraseology that I have borrowed from(thank you granpa)
If we are to be fussy about the terminology used I have never referred to a ball on a string but I have referred to a point mass(post 14) later being more economical with words and referring to it as a mass.To reiterate on a previous comment,by considering a point object we can ,by a process of integration,sum the effect on the whole object.
In the anticipation of any criticism of my reference to a light inextensible string I want to point out in advance that this itself is nothing more than a theoretical construct that enables the above calculation to be carried out.
p.s.I haven't carried out the full calculation for an extended object because my maths is probably not up to it .Because of lack of use I have forgotten most of my maths and I was never particularly good at it in the first place(it was the 1960s).If you are able or inclined to do a fuller analysis I would be interested by any findings you make but whatever these be there will be an apparent weight loss. If I ever embarked on the task I would calculate the fractional apparent weight loss for a gyroscope where most of the mass is contained within a thin but finite ring on the circumference of the gyroscope this structure being the one that will display a loss which is greater than that displayed by a gyroscope where the mass is more evenly spread out.
Dadface
- 2,489
- 105
Hello turin.You may be conviced if you do a free body force diagram with a round earth.I am new to forums and a dinosaur when it comes to using computers (despite having attended several courses)and I don't know ,as yet, how to present diagrams.
Staff Emeritus
Education Advisor
Dearly Missed
- 35,014
- 21,729
I think you need to better explain what your question is. It's jumped from spinning objects to shaking scales to orbiting objects.
Dadface
- 2,489
- 105
I agree that I could have I could have explained my original question more clearly but then we can all improve upon the parlance we use.My original intention in starting this thread was to promote some sort of discussion in the hope that some people may work it out for themselves.In retrospect I realize now that this thread would have been better introduced in the brain teasers forum.My excuse is that I am new to forums and I am still getting used to the procedures one should follow.
Several weeks ago I posted a copy of my findings to a well known magazine.It was written in a tongue in cheek style and I am hoping that they will publish it as an amusing snippet in the letters page.If I hear nothing I will try elsewhere,but written more formally.Thanks to a comment made by granpa I am going to call it the satellite effect.
Mentor
- 45,592
- 2,492
Dadface, it sounds to me that your question (at least the latest version) is about the change in apparent weight of an object on the Earth due to the Earth's rotation. Is that what this is all about? (Of course the Earth's rotation has no effect on the actual weight of an object--the strength of the Earth's gravitational attraction.)
Dadface
- 2,489
- 105
It is an apparent weight loss but not due to the Earth's rotation.Although there are effects due to the rotation of the Earth I did not bring this into my analysis.What I considered was the rotation of the object itself.
Homework Helper
- 2,314
- 3
I don't need to draw the diagram; the situation is too simple. I see only two forces and one acceleration. One of those forces is weight. The other force is tension. The acceleration is centripetal. To determine weight, I use Newton's law of universal gravitation, regardless of whether or not the ball is orbitting, rotating, or whatever you want to call it, so I get the same weight as if the ball were just sitting still at that same height on a table top. AFAIK, Newton's law of universal gravitation does not have a velocity-dependent term or factor in it.Dadface said:You may be conviced if you do a free body force diagram with a round earth.
Dadface
- 2,489
- 105
AFAIK Newtons law does not have a velocity dependent term in it etc and I agree with everything else you have written.To reiterate I am not claiming a real weight loss it is an apparent weight loss of the type an astronaut in orbit experiences.Since you did not draw the diagram can I enquire which ,if any, of the two forces you identified provides the centripetal force which is needed for the centripetal acceleration?The conventional view is that for an object moving in a horizontal circle, it is the horizontal component of the tension and that the vertical component of the tension supports the weight.In your mind did you see the weight vector pointing vertically downwards?That direction is arguably correct for a flat Earth but not for a round earth. The weight of an object acts towards the Earth's centre and because it has a horizontal component it provides some of the centripetal force needed thereby reducing the tension and resulting in an apparent weight loss. In short we are in agreement about the forces themselves but it is the directions of those forces that I am asking you to consider.Please just scribble it out on a scrap of paper.
Dadface
- 2,489
- 105
The fractional loss of weight is given by:
f^2=(2v^2.g.r.cos phi)/(v^4+g^2.r^2)
v= speed.
g=acceleration due to Earth's gravity at the particular height of the object/ring.
phi = the angle that the weight vector makes with the orbital plane.
r =radius of circle.
Again I need to check my maths.
Please note the following:
1.The fractional loss is independent of the mass.
2.When phi becomes equal to zero and v^2=rg the fractional loss becomes unity and the mass/ring becomes a satellite.
v= speed.
Homework Helper
- 2,314
- 3
Why does reducing the tension result in an apparent weight loss? Tension and weight are two completely different things. The directions of the forces, and in fact the entire fbd, are irrelevent. We don't need to separate force vectors into components. Weight is an input into the fbd, not something that you calculate from it. We already know that weight can contribute to centripetal force (i.e. anything that is in orbit around the Earth gets its centripetal force from its weight, as you say). I don't understand what is the big deal. And I am still waiting for you to relate this to gyros ...Dadface said:The weight of an object acts towards the Earth's centre and because it has a horizontal component it provides some of the centripetal force needed thereby reducing the tension and resulting in an apparent weight loss.
Dadface
- 2,489
- 105
Resolving the two forces into components is the easiest way to solve the problem.How else can you determine what provides the centripetal force and what supports the weight?The centre of the circle in which the mass moves is not along the line of of the string-it is below it and the centripetal force is directed towards the centre of the circle.
I will put it another way:
Imagine the mass was moving in a vertical circle by means of a light rod driven by a motor which is supported from a stand which is sitting on scales.Let the speed be constant and equal to v and let the radius of the circle be equal to r.The centripetal force needed to maintain this circular motion is given by mv^2/r.Now consider the mass when it is at different positions
Topmost point...At this point the two forces are in the same line ,the direction of both is towards the centre and together they provide the centripetal force(C.F.).We can write:
Mg+T =C.F...(Newton second law)
Bottommost point...At this point the two forces are in the same line but act in opposite directions,T towards the centre and Mg away from the centre.We can write:
T-Mg=C.F.
At other points we have to calculate the component of the weight towards the centre.The measured weight of the mass is felt through the tension and the tension varies from a maximum at the bottom ,showing an apparent weight increase to a minimum at the top showing an apparent weight decrease.You are probably familiar with systems of the type I have just described but my analysis of motion in a horizontal circle works on exactly the same principle the weight itself having a horizontal component and the apparent weight change being a loss at all parts of the circle.It does not matter if a method of support other than a string is used or if it is a gyroscope a spinning top or anything else,the principle is the same.
T-Mg=C.F.
Homework Helper
- 2,314
- 3
This will likely be my last post.
BTW, as a suggestion, I would be happy to identify the time average of such a support force as the "apparent weight" of a spinning gyroscope.
I see no problem to solve.Dadface said:Resolving the two forces into components is the easiest way to solve the problem.
In order to continue this discussion, I need you to define "apparent weight", and to identify the object that has this apparent weight.Dadface said:... the apparent weight change ...
What principle? I do not care about the centripetal force acting on the different parts of a spinning gyroscope. In order to continue this discussion, I want to know about the support force provided by the ground or table-top that supports the spindle of a spinning gyroscope.Dadface said:It does not matter if a method of support other than a string is used or if it is a gyroscope a spinning top or anything else,the principle is the same.
nuby
- 336
- 0
Here's a thought experiment. If a spherical object on a string was spinning around so fast .. that if released it would fly into outer space. Would it experience any weird effects wrt to its weight or Earth's rotation?
Homework Helper
- 2,314
- 3
According to GR? I do believe so. (you can look up GP-B as an example of why I believe so). According to Newtonian gravity? I don't believe so.nuby said:Here's a thought experiment. If a spherical object on a string was spinning around so fast .. that if released it would fly into outer space. Would it experience any weird effects wrt to its weight or Earth's rotation?
Dadface
- 2,489
- 105
Hello turin
1.The problem I was referring to was the problem of calculating the apparent weight or apparent weight loss.
2.The apparent weight is the force that would be measured by a weighing insrument.You asked me to identify the object that has this apparent weight and I thought I had already done this in earlier parts of the thread but there are numerous other examples most of them involving accelerated motion.Heres a couple more.
a. Hold a spring balance in your hand and weigh a bag of potatoes.Accelerate your hand up and the balance will give a higher reading,accelerate it down and it will give a lower reading,drop the balance and everything is in free fall.
b.Drive over a hump backed bridge too fast and leave the road and any weighing instrument that may be on the road..
c.Build a gigantic ring that surrounds but is above the equator.
Specifically I was talking about objects spinning or rotating in horizontal circles.The apparent weight changes(losses and gains)happening in vertical circles are already well documented and accepted and very easily measurable eg by a slightly unbalanced flywheel on a set of scales.By considering a gyroscope where most of the mass is concentrated in a very thin ring on its outer edge I have derived an equation giving the apparent weight and by plugging numbers into this the apparent weight can be predicted.It is the support force ie the apparent weight that I have calculated.
4.If predictions such as this can be made within the domain of Newtonian mechanics then they should be inherent in the more encompassing Einsteinium theory.It would be interesting to see what GR predicts and whether or not there are any deviations.
Homework Helper
- 42,895
- 983
What is the difference between "vertically down" and "toward the Earth's center"?
I would say that "down" is defined as "the direction in which gravity (weight) acts". Generally, that will be toward the Earth's center but if you are standing near a large mountain, say, the direction will be very slightly toward the mountain.
Mentor
- 45,592
- 2,492
Note that the question "Do spinning objects really lose weight?" is much less interesting when all you are talking about is "apparent" weight (the support force). The simple answer to the question in the thread title is: No, of course not. If I drop a ball (remove the support force of my hand) would anyone say that the weight of the ball really changed?Dadface said:Hello turin
Are you claiming that the force required to support a gyroscope is less when it's spinning? (Let's assume its center of mass is not accelerating.) Just to be clear: Rest the unspinning gyroscope on a scale--the support force is mg. Set it spinning and rest it on the same scale--the support force is less than mg? Is this what you are claiming?By considering a gyroscope where most of the mass is concentrated in a very thin ring on its outer edge I have derived an equation giving the apparent weight and by plugging numbers into this the apparent weight can be predicted.It is the support force ie the apparent weight that I have calculated.
Dadface
- 2,489
- 105
I agree with you HallsofIvy and there are other systematic effects such as those due to the Earth's spin,density variations within the Earth and the other deviations the Earth has from being exactly spherical.An even more detailed analysis would take into account the location of the spinning/rotating object.
Mentor
- 37,453
- 16,565
In Newtonian physics a spinning object does not lose weight, either real or apparent. The example provided in post 14 is not relevant. A spinning object rotates about an axis through its own center of mass, i.e. spinning does not cause the center of mass to accelerate. This is not the case in the analysis of post 14. There are no net external forces on an object whose center of mass is not accelerating, whether or not the object is spinning about an axis through that center of mass is irrelevant. Spinning will add internal forces, but will not change the external forces.
Obviously (from Newton's 2nd law) an object whose center of mass is accelerating is undergoing different external forces than one whose center of mass is not accelerating.
Homework Helper
- 2,314
- 3
Fair enough.Dadface said:You asked me to identify the object that has this apparent weight and I thought I had already done this in earlier parts of the thread
Again, fair enough. However, if you are referring to this equation ...Dadface said:By considering a gyroscope where most of the mass is concentrated in a very thin ring on its outer edge I have derived an equation giving the apparent weight and by plugging numbers into this the apparent weight can be predicted. It is the support force ie the apparent weight that I have calculated.
then I disagree with your equation. (BTW, when you say v=speed, I'm assuming that you mean the tangential speed of the ring of the gyroscope.)Dadface said:The fractional loss of weight is given by:
v= speed.
Since you politely took the time to clarify these issues, then I will humor your request for a fbd. I model a gyroscope as an infinitesimally thin ring of uniform mass density attached to the outer edge of a massless disk of radius, r, attached to the middle of a massless spindle of length, 2h. Neverminding the issue of stability (which I think is anyway irrelevant to the issue of apparent weight loss), I suppose that the spindle is vertical, and supported on a weight scale, of negligible thickness, on the surface of the Earth. I model the Earth as a perfect sphere of uniform mass density, mass M and radius R.
The following involves some basic notions of calculus. I would begin with an fbd that is symmetric about the vertical, with two differential masses, dm, on the opposite ends of a horizontal massless rod of length, 2r, and this horizontal massless rod would be fastened perpendicularly in the middle to the top end of a vertical massless rod, of length, h (so that I have a T-shaped arrangement of massless rods). The bottom end of the vertical massless rod would be supported by a scale. I assume that the horizontal rod with the two differential masses on its ends is rotating at such a rate that the masses are traveling at speed v into or out of the paper. From this diagram, I could calculate the tension in the left half of the horizontal rod to be:
[tex] d\vec{T}=+\hat{x}\left(v^2r-\frac{GMr}{\sqrt{\left(\left(R+h\right)^2+r^2\right)^3}}\right)dm[/tex]
and the tension in the right half of the horizontal rod to be:
[tex] d\vec{T}=-\hat{x}\left(v^2r-\frac{GMr}{\sqrt{\left(\left(R+h\right)^2+r^2\right)^3}}\right)dm[/tex]
Of course you recognize the first term in parenthesis as the centripetal acceleration. The second term that is subtracted is the horizontal component of weight. If you want to compare to your results, assuming that I have understood your definitions correctly, you can replace:
[tex] \frac{r}{\sqrt{\left(R+h\right)^2+r^2}}\rightarrow\cos\phi[/tex]
Anyway, when I add all horizontal forces on all parts of the ring, I determine that the total horizontal force on the ring vanishes, regardless of v.
[tex] \hat{x}\cdot\vec{F}_{tot}=0[/tex]
Now, all of that was actually irrelevant, because I don't care what is the horizontal force on the ring anyway. I want to know the force that the scale must apply vertically upward in order to prevent the spindle from accelerating vertically downward. I calculate the vertical component of the weight on each of the two differential masses to be the same:
[tex] dF_{gy}=-\frac{GM\left(R+h\right)}{\sqrt{\left(\left(R+h\right)^2+r^2\right)^3}}dm[/tex]
In order to integrate this, I will call the linear mass density of the ring, [itex]\lambda[/itex]. After doing the (trivial) integral, I find that the vertical weight component on the entire ring is
[tex] F_{gy}=-\frac{2\pi{}GM\lambda{}\left(R+h\right)r}{\sqrt{\left(\left(R+h\right)^2+r^2\right)^3}}[/tex]
Since the only other force acting on the system is the support force from the scale, I find that the apparent weight is
[tex] F_{aw}=\frac{2\pi{}GM\lambda{}\left(R+h\right)r}{\sqrt{\left(\left(R+h\right)^2+r^2\right)^3}}[/tex]
Notice that this is independent of v. This means that I will measure the same apparent weight regardless of how fast the gyroscope is spinning. In particular, I will measure the same apparent weight regardless of whether or not the gyroscope is spinning.
In terms of your notation, my equation says:
[tex] f=0[/tex]
regardless of v. So, I guess we're stuck.
Dadface
- 2,489
- 105
First I would like to reply to Doc Al
1.When I opened the thread I simply posed a question and never once have I suggested that it was a real weight loss having stressed that it is an apparent weight loss on several occasions.
2.Yes I am making that claim-a spinning or rotating object or indeed any accelerating object at all can display apparent weight changes(gains and or losses)and in several cases these are easily measurable.I have given many examples of this throughout this thread and I can give many more a lot of them coming from everyday life such as driving your car with an unbalanced tyre.If there is anything new here it is that I am suggesting that rotation in a horizontal plane results in apparent weight losses.The changes may be small but in principle they are measurable.
Dalespan imagine a spinning disc with angular velocity w at its outer edge.Now proceed from the outer edge towards the centre of the disc.Are you telling me that we reach a point where the disc is no longer spinning and has zero angular velocity?
turin thank you very much indeed for presenting your maths.I will go through your method and check it against mine(which seems much simpler)but unfortunately an assumption you made does not fit with the more detailed analysis needed .I refer to the "horizontal massless rod of length 2r".The rod cannot be horizontal otherwise there is no component to support the weight .This may seem,at first sight, to be a trivial point but it is not and is at the crux of what I have been trying to explain.As you know I have been trying to make it clear that marking in the force directions correctly is all important here.
As an example of the above, imagine a mass on a string being whirled in a horizontal circle at ever increasing speeds .As the speed increases the mass rises and the angle to the horizontal decreases.It can never reach the horizontal exactly because this would need an infinite speed.
Mentor
- 37,453
- 16,565
Certainly not, how did you ever come to that conclusion?Dadface said:Dalespan imagine a spinning disc with angular velocity w at its outer edge.Now proceed from the outer edge towards the centre of the disc.Are you telling me that we reach a point where the disc is no longer spinning and has zero angular velocity?
Look, my point is simple. If the centers of mass of two identical objects are undergoing identical accelerations then, by Newton's 2nd law (f=ma), the external forces (e.g. weight) on each object are necessarily identical.
Mentor
- 45,592
- 2,492
I still have no idea why you think that just because something is spinning, less support force is required.Dadface said:2.Yes I am making that claim-a spinning or rotating object or indeed any accelerating object at all can display apparent weight changes(gains and or losses)and in several cases these are easily measurable.I have given many examples of this throughout this thread and I can give many more a lot of them coming from everyday life such as driving your car with an unbalanced tyre.If there is anything new here it is that I am suggesting that rotation in a horizontal plane results in apparent weight losses.The changes may be small but in principle they are measurable.
DaleSpam's post #51 sums things up rather nicely. If you claim otherwise, please explain why Newton's laws do not apply.
Mentor
- 37,453
- 16,565
Thank you!Doc Al said:I DaleSpam's post #51 sums things up rather nicely.
Given the rather strange misunderstanding he posted in response to my explanation, I expect that communicating will be difficult.
Dadface
- 2,489
- 105
DocAl I am not claiming that Newtons laws do not apply,on the contrary I am using Newtons laws.Precisely Dalespam if the spinning object has a perfectly symmetrical structure and if it rotates in an exactly horizontal plane then the two objects ,if they are symmetrically situated and structured will undergo identical accelerations the only point of similarity being that the magnitudes of those accelerations are the same and not their directions.Please note that my analysisis primarily focussed on non symmetric structures
Mentor
- 37,453
- 16,565
Where are you getting all of this? I said nothing about symmetry, I said nothing about horizontal planes, and I said nothing about magnitude vs. direction of acceleration. The symmetry of the object is irrelevant as is whether or not the object is spinning about a vertical axis.Dadface said:Precisely Dalespam if the spinning object has a perfectly symmetrical structure and if it rotates in an exactly horizontal plane then the two objects ,if they are symmetrically situated and structured will undergo identical accelerations the only point of similarity being that the magnitudes of those accelerations are the same and not their directions.Please note that my analysisis primarily focussed on non symmetric structures
Dadface
- 2,489
- 105
Dalespam" I am getting all this from "your comment in post 55 when you referred to the "centres of mass of two identical objects undergoing identical accelerations".Perhaps I misunderstood what you meant but your comment was referring to my reference to a single disc so what am I to understand about your "two identical objects"?I thought that you were referring to objects on the disc itself as evidenced by my comments in post 58.Even though there was a mutual misunderstanding here my reference to force direction is most relevant as is the axis of spin.Please spend a few moments and take part in the following thought experiment:
1.There is an extremely tall structure built vertically at one of the Earth's poles and you are standing on top of this structure with an extremely long length of light inextensible string attached to a point mass.
2.You start to whirl the mass in a horizontal circle playing out the string so that it lengthens and you adjust the speed so that the mass does not collide with the earth.
3.You carry on doing this until the mass is moving parallel to and above the equator-it is now in orbitand can become a satellite
Of course you need the right orbital speed (approximately 8km/s for a close orbit)
When the mass becomes a satellite the weight of the object provides all of the centripetal force,the tension becomes zero and any device at the pole which is weighing the mass through the tension will record an apparent but not real total loss of weight.The mass can break loose of the string and it will still remain in orbit.
Does the apparent weight suddenly disappear in one go when the mass becomes a satellite around the equator?The answer is of course not the change is gradual; increasing as the string lengthens and it is Newtons laws that make these predictions there being an apparent weight loss no matter how small the radius of the circle.Any object spinning or rotating in a horizontal plane can be described as being in partial orbit.
- GTrax
- · Replies 3 ·
- Electromagnetism
- Replies
- 3
