Mentor
- 37,036
- 16,066
I already told you that this is not relevant. The motion you describe here is not spinning since it is rotation about an axis that does not pass through the object's center of mass.Dadface said:2.You start to whirl the mass in a horizontal circle playing out the string so that it lengthens and you adjust the speed so that the mass does not collide with the earth.
Let A and B be two arbitrary but identical rigid objects of mass m. A is not spinning, but B is spinning (rotating about an axis through its center of mass). A is experiencing a net external force f and therefore A's center of mass is accelerating at a rate a=f/m. The center of mass of B is also accelerating at the same rate a. From Newton's 2nd law the force acting on B is also f. Therefore, since the forces must be equal a spinning object must weigh the same as a non-spinning one.
