Robert Shaw
- 64
- 6
Entangled states are only separable relative to certain basis states. So does that mean that reference frames have importance beyond those in spacetime?
atyy said:Whether entanglement is basis dependent or not is a matter of convention.
Consider the 4 maximally entangled states, eg |ud>-|du>. If a Martian chose them for basis states then he would see them as separablefacenian said:Does this mean that entaglement as a physical phenomenon is conventional?
Entanglement depends on the split of subsystems, but a split of subsystems does not fix a basis and a choice of basis does not induce a split of subsystems.Demystifier said:Once we split the system into subsystems, the entanglement does not depend on the choice of bases for each subsystem. However, there is no entanglement without the split into subsystems, and such a split may not be unique. If the choice of basis for the whole system is associated with such a split, it can be said that entanglement also depends on the choice of basis.
No, because they still can't be written as ##\zeta\otimes\xi##. The choice of basis doesn't affect this fact.Robert Shaw said:Consider the 4 maximally entangled states, eg |ud>-|du>. If a Martian chose them for basis states then he would see them as separable
Based on the other post's explanations, this is not the correct way to interpret entanglement.Robert Shaw said:Consider the 4 maximally entangled states, eg |ud>-|du>. If a Martian chose them for basis states then he would see them as separable
Separability is a matter of choice as this paper makes clear https://arxiv.org/abs/1106.3047facenian said:Based on the other post's explanations, this is not the correct way to interpret entanglement.
If the system is split into subsystems ##A## and ##B##, then it is natural (though not necessary) to choose a basis in which each member has a form ##|\psi_A\rangle \otimes |\phi_B\rangle##. How would you take such a basis without the split?rubi said:Entanglement depends on the split of subsystems, but a split of subsystems does not fix a basis and a choice of basis does not induce a split of subsystems.
Please would you look at it this way.Robert Shaw said:Separability is a matter of choice as this paper makes clear https://arxiv.org/abs/1106.3047
("Entanglement or separability,the choice of how to factorise"...Bertlmann being John Bells friend and collaborator)
Well, first of all, you still need to make infinitely many arbitrary choices here, because the vectors ##\psi_A## and ##\phi_B## are not fixed by the split, so the split does not induce a choice of basis. And the other way around, a choice of basis does not induce a split. It needn't even be compatible with any split. A split and a basis are very different concepts. What choice of basis is natural depends on the problem one wants to solve. It is most natural not to choose a basis at all and it is often natural to choose a basis, such that some important operator becomes diagonal.Demystifier said:If the system is split into subsystems ##A## and ##B##, then it is natural (though not necessary) to choose a basis in which each member has a form ##|\psi_A\rangle \otimes |\phi_B\rangle##. How would you take such a basis without the split?
Robert Shaw said:Take two 2D vector spaces Zeta and Xi.
Consider the Cartesian product set (Zeta,Xi). One create maps from this set to the 4D vector space Psi.
I'm wondering if the confusion may be due to the two different notions of product.rubi said:A vector ψ∈H⊗Hψ∈H⊗H\psi\in\mathcal H\otimes\mathcal H is called separable if there are ζ,ξ∈Hζ,ξ∈H\zeta,\xi\in\mathcal H such that ψ=ζ⊗ξψ=ζ⊗ξ\psi = \zeta\otimes\xi. Otherwise, it is called entangled. No reference to a basis is made in this definition.
I was merely following the definition of a tensor product: In mathematics, the tensor product V ⊗ W of two vector spaces V and W (over the same field) is itself a vector space, together with an operation of bilinear composition, denoted by ⊗, from ordered pairs in the Cartesian product V × W into V ⊗ W, in a way that generalizes the outer product.Zafa Pi said:I'm wondering if the confusion may be due to the two different notions of product.
Shaw claims to be using Cartesian product ×, and rubi is using tensor product ⊗.
Now if H = ℝ² then H×H = H⊗H = ℝ4, however [1,0]×[0,1] = [1,0,0,1], whereas [1,0]⊗[0,1] = [0,1,0,0], and [1,0,0,1] isn't separable in H⊗H.
In H×H all members are separable, and in H⊗H only the tensor product of vectors are separable. Thus my guess is Shaw meant to say tensor rather than Cartesian.
It would nice if Shaw gave concrete examples (in H⊗H) for the Martian and the Earthian, so I could see clearly what he is talking about.
Also a Cartesian product is just an ordered pair not a vector. So [1,0]X[0,1] is not a 4 vector, it only relates to 4vectors as a consequence of a bilinear map being defined.Robert Shaw said:I was merely following the definition of a tensor product: In mathematics, the tensor product V ⊗ W of two vector spaces V and W (over the same field) is itself a vector space, together with an operation of bilinear composition, denoted by ⊗, from ordered pairs in the Cartesian product V × W into V ⊗ W, in a way that generalizes the outer product.
Happy to furnish an example
A Cartesian product is something in set theory, it has no intrinsic vector properties until they are created by the bilinear mapRobert Shaw said:Also a Cartesian product is just an ordered pair not a vector. So [1,0]X[0,1] is not a 4 vector, it only relates to 4vectors as a consequence of a bilinear map being defined.
EXAMPLERobert Shaw said:A Cartesian product is something in set theory, it has no intrinsic vector properties until they are created by the bilinear map
Excellent paper, thanks for the referencekith said:Disregarding experiments, it may be interesting to discuss different factorizations anyway, especially when it comes to the ontology of QM. You may be interested in the following (arxiv-only) article which has been discussed here before:
https://arxiv.org/abs/1210.8447
"Nothing happens in the Universe of the Everett Interpretation" by J. Schwindt
As Schwindt puts it (see reference above)Robert Shaw said:A Cartesian product is something in set theory, it has no intrinsic vector properties until they are created by the bilinear map
That's a very good point. The algebra of observables is critical.rubi said:It's not really the factorization that is needed. The factorization is arbitrary and has no physical relevance, since all unitarily equivalent quantum theories describe the same physics. A quantum theory always comes with an algebra of observables and a subsystem of a quantum system is characterized by a subalgebra of this algebra (i.e. take the subalgebra of observables of particle 1 only). If you have a pure quantum state on the full algebra, it may become mixed when restricted to a subalgebra. The Schwindt paper doesn't take the observables into account and is thus pretty useless.
e.g. in Ballentine's book, separability is NOT introduced in the context of observables but rather as if it is a property of the state space itself.Robert Shaw said:That's a very good point. The algebra of observables is critical.
However, how many textbooks on QM make that point?
The usual approach in most textbooks is to focus on states and discuss separability as though it's an absolute, rather than relative to the algebra of observables.
Do you have any recommendations on textbooks that make clear the importance of the algebra of observables in understanding QM?
On reflection, the algebra of observables does not resolve the puzzle.rubi said:It's not really the factorization that is needed. The factorization is arbitrary and has no physical relevance, since all unitarily equivalent quantum theories describe the same physics. A quantum theory always comes with an algebra of observables and a subsystem of a quantum system is characterized by a subalgebra of this algebra (i.e. take the subalgebra of observables of particle 1 only). If you have a pure quantum state on the full algebra, it may become mixed when restricted to a subalgebra. The Schwindt paper doesn't take the observables into account and is thus pretty useless.
A good textbook that highlights the algebraic foundations of quantum mechanics is "An Introduction to the Mathematical Structure of Quantum Mechanics" by Strocchi.Robert Shaw said:Do you have any recommendations on textbooks that make clear the importance of the algebra of observables in understanding QM?
No, because the Martian would have to use the transformed operator if he uses an unitarily equivalent Hilbert space. Both states (##\psi \rightarrow U \psi##) and operators (##O \rightarrow U O U^{-1}##) need to be transformed and physics is invariant under such unitary equivalences. The structure of the Hilbert space can't be detected by any experiment.Robert Shaw said:Martian could have suboperator M1 and M2. It would measure up for particle 1 and 2 for state (1,0,0,1) on Earth basis. Earthperson would see the same state as entangled.
Does this mean that the arena for QFT is different?vanhees71 said:This would be strange already from a mathematical point of view since there's essentially only one separable Hilbert space, which is the arena of (non-relativistic) QM.
