Do you need absolute value around argument for log and ln?
4 replies · 16K views · last reply
find_the_fun
When I learned about derivatives I was taught to put the absolute value sign around the argument for ln and log. For example [math]\log{|x|}[/math] and [math]\ln{|x|}[/math] instead of [math]log(x)ln(x)[/math]. Does this make a difference? Should both brackets and the straight lines be used?
When taking the derivative what is the effect on the absolute sign? For example if I write [math]\ln{|x|}[/math] would it be incorrect if I didn't write [math]\frac{1}{|x|}[/math]
It is merely more general.
I don't usually use absolute value signs myself.
That is, until I may want to generalize my result to negative x, but usually there is no reason to.
Yes. Assuming that you mean by $\ln|x|$ a function that is defined both for positive x and for negative x, that means that the derivative must be $\frac {1}{|x|}$, which is also defined both for positive and negative x.
You can only leave out the absolute value signs if you limit your domain to positive x.
EDIT: My mistake. See Prove It[/color]'s comment below. The absolute signs should not be there.Btw, there is a catch.
The indefinite integral of $\frac {1}{x}$ is often denoted as $\ln|x| + C$.
But this is not quite correct.
That is because the integration constant can be different for positive x and for negative x.
Ah, no, this should be stricken from the record.
The derivative of [tex]\displaystyle \begin{align*} \ln{(x)} \end{align*}[/tex] is [tex]\displaystyle \begin{align*} \frac{1}{x} \end{align*}[/tex]. Notice how here we have that [tex]\displaystyle \begin{align*} x > 0 \end{align*}[/tex] in order for the logarithm to be defined.
Notice too that the derivative of [tex]\displaystyle \begin{align*} \ln{(-x)} \end{align*}[/tex] is also [tex]\displaystyle \begin{align*} \frac{1}{x} \end{align*}[/tex]. Don't believe me, use the Chain Rule. Notice that here we have [tex]\displaystyle \begin{align*} x < 0 \end{align*}[/tex] for the logarithm to be defined.
Thus, if we go in reverse, we have [tex]\displaystyle \begin{align*} \int{\frac{1}{x}\,dx} = \ln{(x)} \end{align*}[/tex] IF [tex]\displaystyle \begin{align*} x > 0 \end{align*}[/tex] and [tex]\displaystyle \begin{align*} \ln{(-x)} \end{align*}[/tex] IF [tex]\displaystyle \begin{align*} x < 0 \end{align*}[/tex].
That sounds an awful lot like the definition of an absolute value to me...
So to summarise [tex]\displaystyle \begin{align*} \int{\frac{1}{x}\,dx} = \ln{|x|} + C \end{align*}[/tex]There is NO reason (and in fact it is completely incorrect) to put [tex]\displaystyle \begin{align*} \frac{1}{|x|} \end{align*}[/tex].
My mistake.
I'll put an EDIT note in my previous post.
As I said, I don't usually use those absolute signs.
On the other hand, y = ln |x| has two branches, one on the +x axis and one on the -x axis. y = ln(x) only has the branch on the +x side. I think that makes it rather different.
[math]\int \frac{1}{x}~dx = ln |x| + C[/math]
is defined on all values of x (except for x = 0, of course) not just the +xs.
-Dan
Sorry ProveIt. I missed your post somehow.
