Does 0.999~ Equal 1?
  • Context: Undergrad
  • Thread starter Thread starter QuantumTheory
86 replies · 17K views
QuantumTheory
According to this site, it does:
http://www.straightdope.com/columns/030711.html"
Is this really true? I don't see how, because it seems like a limit problem to me.
It is true because of the way we have defined what decimal representations* of real numbers are, and exactly because of what limits are. 0.9recurring is the limit of a cauchy sequence of the partial sums of the obvious geometric progession
9/10+9/100+9/1000+...
which is 1.
End of story.
Shall I await the "but you never get to the end of an infinite sum so it never truly equals 1" arguments?
* I presume you have no problem with the fact that 1/2 and 2/4 (and an infinite number of other fractions) all represent the same rational number? If so why is it so surprising that *two* (and only 2) decimal representations are of the same real number?
Incredible. Well, I never fully finished algebra, geometry, or pre calc or calculus. It's like you konw bits and pieces and not the whole thing, which makes thigns like this very difficult.
I won't doubt you ,but I still don't understand. However, my math teacher did tell me that there is an infinite numbers between 1 and 2.
I thought the whole point of a limit was that you can get close and not reach it? Wait a second. Will 0.9 always repeat itself or eventually get to 1?
Well it doesn't matter, but it could be 0.99999999999999999999999 and isn't that still 0.000000000001 close from 1?
I guess it only equals one if ou let it go for infinity. But if you stop the 'process' then it does not equal one.
The reals are something that obeys a set of rules, one of those rules directly implies that in the decimal representations *we must identify those two numbers if they are to behave properly*. Decimals are just representations of the real numbers. If you want to understand those definitions then you need to do significantly more maths (analysis), but it is just a formal consequence of hte definitions. It is not mysterious.
Of course no finite truncation of the infinite sum is 1, but I don't see what that has to do with the infinite sum. You just appear to have some misconception about what a limit is. In general I'd say you're reading far too much into what after all are just strings of digits that obey certain rules. If you don't know what the rules of the game are you cannot play it. You're 'let it go to infinity' thing is one such indication. This isn't something that adds up things one at a time as if it were a machine, this isn't some process, you don't let things 'run forever'. It is just a symbol with certain properties.
One of which is it is the smallest number larger than any of the finite truncations.
Right -- 0.999~ does not mean "a lot of 9's" -- it means the 9's keep going without ending.
More precisely, for every positive integer n, there is a 9 in 0.999~ located exactly n places to the right of the decimal point.
(There are infinitely many 9's in 0.999~ -- nothing is "going" to infinity)
1/3 is 0.333~, right?
3 * 1/3 is 1, right?
All you then need to accept is that 3 * 1/3 is "also" 0.999~.
To make it somewhat clearer, 2*2=4, 2 * 0.222~ is 0.444~. So if 3*3=9, 3*1/3=0.999~.
When I first stumbled across this, my main problem was accepting the seemingly illogical truth.
All you then need to accept is that 1/3 is "also" 0.999~.
I've seen this very often but what I don't see is why someone would accept 1/3 = 0.3~ and not accept 0.9~ = 1, yet this is often used as 'proof'.
??Typo? I presume you meant "All you then need to accept is that 1/3 is "also" 0.333~".
I think he meant that people would already accept that 1/3 = 0.3~ (don't ask me why though), then they'd need to accept that 3*1/3 is not only 1 but also 3*1/3 = 3*0.3~ = 0.9~.
Yeah, I always thought this was strange.
There is a lot of difference between something tending to 1 and something being 1. we approximate it to 1, but need not be that it is actually 1. The explanation given by Nagzun was really fantastic. Something tending to 1 being written as 1 when we don't know the actual value is a different case. This is what happens in GP. We don't know the actual value and so the formula given is a/1-x wherew x<1. Here a Mathematician is sue that no one tommorow will give a unique perfect answer to this question about summation about GP to infinite values, So he approximated the formula. We write root-2 as 1.414, But 1.414 is a unique rational number. However root-2 is not really 1.414, it only tends to that value. We have no use of finding root-2 to hundred decimals to solve numericals. So we neglect the remaining. We can be sure about the fact that 1 is something very near to the number 0.999~. However we cannot tell, that both are equal.
There is a big difference between an approximation, which 1.414 is for sqrt(2), and another representation for exactly the same number, which 0.9~ is for 1. There is no "choice" for us, to say whether or not those two are equal. If we're working in the real numbers, there is no other possiblity than for those two to be exactly the same real number - it's just another way of writing it.
Excuse me, but such displays of ignorance tend to rile me. Who said 0.9... tends to one? It is one, it is not tending anywhere; its partial sums tend to one. One is the smallest real number greater than any of the strictly increasing partial sums, hence is the limit **by the definition of the space in which the argument takes place**.
If nazgjunk's simple and elegant proof (minus the typo, of course :redface: )isn't enough to quench all doubt, perhaps a question:
If 0.999... is not equal to 1, then there must be a number between the two: what is it?
And don't say 0.000...1, because there is no such thing.
Like a sticky with the topic:
"BEFORE YOU POST 0.999 = 1, READ THIS!" with a link to that post?
I have been getting the feeling for a while now that each 0.999~ = 1 thread has been "better" than the previous one... I'm not sure what that really means, though. :redface:
We simply happen to use a system where 1 and 0.999... are equal. On the hyperreals, R*, a *logically vaild* superset of our current system, 0.9999... and 1 are not equal.
Sorry for my little typo. What I did mean was "all you then have to accept is that 3 * 1/3 "also" equals 0.999~". I will edit that one now.
Ow, how I love to force people into accepting what they just proved themselves.
eventually the series of threads might converge, and if we let it go to infinity it might equal one explanation...
The large infinity or the small infinity?
I still don't see why people so readily accept (1/3)=.333~
Only if each following thread got shorter and shorter... :D
That's incorrect -- every true internal statement about the reals is also true about the hyperreals, and that includes 0.999~ = 1.
(I can explain further in private message, or a new thread -- I just don't want to muddle this one up)
My take on this is that they think of decimals of representing the answer of doing a division, thus dividing 3 into 1 by long division gives them the sequence 0.3, 0.33, 0.333,... etc, and they somehow think that "thus the result is 0.3..." they do not see such a division for 0.999...
Further, to compound the problem, i suspect that since they do not know what convergence is they only accept 0.333recurring is 1/3 as some kind of decimal 'best guess', thus subconsciously they do not truly think of them as being exactly the same; this is the 'but you never reach the end' argument.
Of course this notional proof of 1/3 times 3 requires that we prove that the algebraic operations on decimals are well defined, which typically is not done.
Is that even possible? To muddle this, that is. :biggrin: I can't believe I said R*. I meant *R. Me is embarrassed.
Anyway, I think you might be misapplying the transfer principle or extension axioms or something. I think I can prove this as well. The basic ideas is that the limit never converges to 1 since there are an infinite number of numbers between.
It converges to 1 in the hyperreals too.
What's the difference between 1 and 0.9...? It is a real number (since the reals are a subring) that is also an infinitesimal, thus it is zero since there is exactly one infintesimal. (If it were otherwise how could it be a superset? (the injection would fail to be even a function))
hmm.. I see, although i still disgree. I need to work this out myself. Perhaps I was wrong to call them superset then, i dunno. Ill shall henceforth be posting either my thanks for you correcting me or a proof as to why i am correct.:smile:
I think part of the acceptance of 1/3=.33~ is there's no alternate decimal expansion. The unfounded notion that every number must have a unique decimal expansion is probably fuel for many of the .99~ complainers.
These threads always make me try to remember what I actually thought the real numbers were in high school, but I can't seem to remember doing any math before my first analysis class.
