Does a Continuous Function Need to Be One-to-One?
  • Level: Undergrad
  • Thread starter JasonRox
    Functions
7 replies · 3K views · last reply
Homework Helper
I have a question regarding this.
I wish I were home right now so I can give the exact words.
Anyways, the book is talking about continuous maps from one space to another. This is basically what it says...
Let f be a function with domain D in R. Then the following statements are equivalent:
f is continuous
If D is open, then the inverse image of every open set under f is again open.
If D is closed, then the inverse image of every closed set under f is again closed.
There are others, but that's not important.
I just want to clarify that f does not need to be one-to-one, correct?
No, f does not need to be one to one. Instead of 'inverse image' try using the phrase 'preimage' of a set as someone here once pointed out. Can't remember who to credit it with.
So, using the "preimage" we can "map" to two elements?
I used quotes for map because it doesn't really satisfy the definition.
I'm not sure what you mean by "map" two elements but here is an example:
If f(x)= x2 (not one-to-one) and D is the interval (-1, 4) then f-1(D) = (-2, 2), the set of numbers whose square is between -1 and 4. Since (-1, 4) is open and f is continuous, that inverse image (preimage if you prefer) is open.
That's exactly what I wanted to confirm. Thanks.
My most embarassing moment: My first semester in graduate school, I was called on to do a proof in Topology class that involved f-1(A) where A is a set. Without thinking, I did the proof assuming that f had an inverse! (Hey, it said f-1!)
I'll remember this whenever I get embarrased. :wink:
Were you lucky enough to redo your proof?
I did later submit a proof on paper to the professor but that day I just shrank into a small lump in my chair. The next time I was called on to present a proof in class I did well and I actually passed the course!
