binis
- Messages
- 101
- Reaction score
- 8
A DC supplied superconductive electric coil must give off EM radiation according to Maxwell's law because rotation is acceleration. Does it?
Because the electrons are moving in circles (a spiral path) and by this are accelerated.vanhees71 said:I don't know what you mean when you say "rotation is acceleration".
By this definition a cyclotron should not radiate? Is this becausevanhees71 said:A DC doesn't radiate, no matter whether the current flows in a superconducting or normal conducting material. I don't know what you mean when you say "rotation is acceleration". Any static vector field is a pure solenoidal magnetic field, because of Gauss's Law, ∇→⋅B→=0, but static fields don't describe electromagnetic radiation but static fields ;-)).
Is there a specific treatment of this you can reference? I don't recall seeing this addressed and wonder how it actually falls out...it is not clear to me at first blush although your continuum supposition is likely correct..Ibix said:An individual electron moving in a circle would radiate, but a continuous stream of them does not.
Well, cyclotron electrons move in an expanding spiral, not a circle. Also they can't reasonably be called DC. Their speed is increasing, and they must be pulsed, since electrons moving from the currently positive D to the currently negative one will be decelerated while ones moving the other way (at the opposite side of the chamber) are accelerated.hutchphd said:By this definition a cyclotron should not radiate?
It's just a current loop with a constant current, as far as I can see. That's a textbook solenoid, no?hutchphd said:Is there a specific treatment of this you can reference?
The longitudinal acceleration is not necessary for the "cyclotron" radiation. In fact the (non-relativistic) Larmor Equation pasted from WikipediaIbix said:Well, cyclotron electrons move in an expanding spiral, not a circle. Also they can't reasonably be called DC. Their speed is increasing, and they must be pulsed, since electrons moving from the currently positive D to the currently negative one will be decelerated while ones moving the other way (at the opposite side of the chamber) are accelerated.
The answer in this paper is in fact a quantum argument. They use stationary phase to "do" the integration: I quote from the conclusiondRic2 said:@Ibix @hutchphd I googled it and found this link where the author addresses this issue. https://physics.princeton.edu/~mcdonald/examples/steadycurrent.pdf
I just skimmed through it. It seems to consider only the non-relativistic limit.
Vanadium 50 said:Acceleration doesn't cause radiation. Changing multipoles cause radiation, and a point charge accelerating is but one example.
There is no question about that. My particular issue is a "continuous" ring of current and the inconvenient notion that electron-carried charge is not continuous. I believe there may be a problem with any treatment of the free electron absent QM.tech99 said:According to Electromagnetic Vibrations, Waves and Radiation, by Bekefi and Barrett, p 289, a charge traveling in a circle is subject to acceleration towards the centre and emits cyclotron radiation with a frequency equal its rotational frequency.
This study considers a uniform circular motion in a ring of radius α. Provided that these math apply to a perfect circle circuit, then does not apply to an ellipsoid electric coil or an irregular circuit.dRic2 said:I googled it and found this link where the author addresses this issue. https://physics.princeton.edu/~mcdonald/examples/steadycurrent.pdf
Frictionless plane, stretchless rope...hutchphd said:But by this definition there is no DC ?
Yes I believe it does (I didn't really dissect it) but it fundamentally uses the quantum nature of the electron in matter to reach that conclusion. (It is the same reason electrons in an atom don't"spiral in": because of QM) I apologize for slightly hijacking the post by asking if a classical electron would similarly behave as a rejoinder to some questionable answers.binis said:This study considers a uniform circular motion in a ring of radius α. Provided that these math apply to a perfect circle circuit, then does not apply to an ellipsoid electric coil or an irregular circuit.
The best derivation of the Lorentz-Abraham-Dirac equation can be found in the textbookhutchphd said:New to me. Is there a good compendium treatment ? Otherwise I will hunt it down (maybe!)
binis said:A DC supplied superconductive electric coil must give off EM radiation according to Maxwell's law because rotation is acceleration. Does it?
So another convincing argument may be that the charge in the DC circuit will not accelerate or decelerate in the direction of the wire, otherwise it will not be DC. Therefore, the direction of charge acceleration must be perpendicular to the direction of charge movement in the wire, that is, the electromagnetic force accelerating the charge is perpendicular to the direction of charge movement. Therefore, the charge does not get energy from the electromagnetic force that accelerates it, so it does not generate radiation.alan123hk said:However, it is a bit surprising and unimaginable to say that a DC circuit of any shape will completely automatically cancel the radiated electromagnetic field generated by the acceleration of the charge in the loop.
You are trying to say that the magnitube of the velocity remains stable. So Maxwell's law needs a revision.alan123hk said:So another convincing argument may be that the charge in the DC circuit does not accelerate in the direction of the wire,
