Does a Glider Complete Its Loop Starting at 60 m/s with 30 m/s² Acceleration?
  • Thread starter Thread starter StudentTM
    Airplane Loop
The discussion revolves around a physics problem involving a glider completing a loop while flying horizontally at a speed of 60 m/s with an initial centripetal acceleration of 30 m/s². Participants are exploring the dynamics of the glider's motion, including the effects of gravitational force and lift during the maneuver.
  • Mixed
  • Some participants question whether the pilot maintains constant airspeed throughout the maneuver, suggesting that this could affect the problem's specifications.
  • There are discussions about applying Newton's laws to relate acceleration and force, with references to centripetal acceleration and its relationship with lift force and speed.
  • One participant attempts to clarify the relationship between lift force, speed, and centripetal acceleration, while others express confusion about the implications of these relationships.
  • Participants are also considering numerical methods for solving the equations of motion, with suggestions to break down the problem into smaller time increments.
The discussion is ongoing, with various interpretations and theoretical approaches being explored. Some participants have offered guidance on relevant physics concepts, while others express uncertainty about the application of these concepts to the problem at hand. There is no explicit consensus yet, as participants continue to seek clarity and understanding.
Participants note the importance of assumptions such as neglecting air resistance and the implications of the glider being a specific type of aircraft. There is also mention of the need to understand the mathematical concepts involved, such as derivatives and differential equations, which are central to the problem.
  • #31
Height in your case is y, not x. Good otherwise.
  • #32
y of course :)
Thank you, I'll check that out
  • #33
At the bottom of the loop where y = 0 and v = 60 m/s the KE is (1/2)mv^2 = 1800m J. At the top of the loop I have v=19.36m/s and y= 166.061, for a total energy of (1/2)mv^2 +mgh = 1814.8m J. I think the error is due to the way that the Euler method assumes for each incremental step that acceleration is constant in both x and y directions - it ignores the fact that the plane's angle has changed which would have the effect of slowing its forward velocity.
Should I include the angle somehow with this simplified equations?
  • #34
You have the error because Euler's method approximates a continuous function with a piecewise linear curve. This should have been explained to you in your "numerical methods" course. You cannot eliminate this error, but you can make it smaller by reducing your time step. Another source of error is the finite precision of computer arithmetic. This you cannot reduce at all (without taking some extreme measures, that go far beyond your little assignment).
Keeping track of total energy let's you estimate the error; your error is about 1%, which is not too bad, especially if you recall that you ignore drag completely, which will have a much greater effect on energy and other variables.
  • #35
I understand. Thank you Voko!
I'll now start finishing this program and start writing report.
I might have a questions or two for the process of evolving those equations.
I'll post the finished assignment/program here. Thanks to everyone who helped and participate in discussion.
  • #36
Somebody suggested to me that
a_x = ( 30 (centripetal acceleration) * v * v_x1 ) / 60*60
a_y = (( 30 (centripetal acceleration) * v * v_y1 ) / 60*60 ) - 9,8
would be correct.
And
a_x = -39.8 * V_t * Vy_1 / (60 * 60);
a_y = 39.8 * V_t * Vx_1 / (60 * 60) - 9.8;
is wrong.
Why should it be like that?
Sorry guys, for dummy question, I really respect your patience with me, but .. How can I learn to understand these final equation? Where to start? Where do they come from exactly?
Voko your explanation for upper difficult equations makes sense for a start.
Where do I begin to study those final simplified equations?
For example - POSITION:
I see why there is '' x_2 = x_1 + (Vx_1) * delta_t ''
V * t = x
But how do I know V_x is constant?
VELOCITY:
Vx_2 = Vx_1 + Ax * delta_t
a * t = V ... I agree, but this time we are using equation for accelerated motion. Why? If we used an equation for constant velocity for position?
ACCELERATION:
Ax = -39.8 * V_t * Vy_1 / (60 * 60) or a_x = ( 30 (centripetal acceleration) * v * v_x1 ) / 60*60
This one I don't understand at all.
  • #37
would be correct.
As you explained earlier yourself, the initial acceleration is 30 m/s2, and because we have -9.8 m/s2 due to gravity, the lift coefficient must be 39.8 / (60*60). So these equations cannot be correct.
is wrong.
The coefficient is correct. The signs are also correct, which should be intuitively clear: as the pilot pulls up, the horizontal velocity must start decreasing, while the vertical velocity must go up.
Newton's second law, gravity, lift. High-school material.
It is not constant. But when you integrate differential equations using Euler's method, you assume that during the very small time interval of each integration step, all your variables do not change appreciably. This is the source of the error intrinsic to the method. You should have been paying attention to your professor, this has certainly been explained in the class.
  • #38
Ohh, that explains a lot :) Thanks .. Yes I should be paying more attention at class for sure ;)
  • · Replies 33 ·
