Does a horizontally spinning weight = no motion weight?
The discussion revolves around the effects of spinning a weight attached to a string while standing on a scale, specifically whether the scale reads the same weight as when the weight is stationary. Participants explore the implications of forces at play when the weight is in motion versus at rest, considering concepts from physics such as gravity, tension, and centrifugal force.
  • One participant suggests that the scale reads 100kg when the weight is stationary, but questions whether it would read differently when the weight is spun, proposing that it might read 99kg due to the motion of the weight becoming external.
  • Another participant argues that the scale still reads 100kg because the ball is still affected by gravity, and spinning does not change the downward force exerted by the weight.
  • Some participants challenge the analogy of a spinning top, stating that the forces acting on the scale must still account for the weight of the ball regardless of its motion.
  • A participant introduces the concept of astronauts experiencing weightlessness, questioning how the horizontal string can still transfer weight to the scale if it is not vertical.
  • Several participants assert that the total weight on the scale remains 100kg, emphasizing that the vertical component of tension in the string must counteract the weight of the ball.
  • One participant proposes that if the scale could measure horizontal forces, it might register more than 100kg due to the tension in the string and the friction with the scale surface, depending on the speed of rotation.
There is no clear consensus among participants. While some argue that the scale reads 100kg regardless of the spinning, others suggest that additional forces could lead to a higher reading, and some express uncertainty about the implications of horizontal motion on weight measurement.
Participants note that the string cannot remain perfectly horizontal while spinning, as a vertical component of tension is necessary to support the weight of the ball. This introduces complexity regarding the forces acting on the scale that remains unresolved.
This discussion may be of interest to those studying physics concepts related to forces, motion, and weight measurement, as well as individuals curious about practical applications of these principles in everyday scenarios.
evowerks
Imagine a person weighing 99kg stands on a bathroom scale. He reads 99kg. That same person then grabs a ball attached to a string that weighs 1kg together. Since he never left the scale he now reads 100kg total.
Now imagine he spins the ball and string like a helicopter overhead. (Since he's a big dude he can do this without shaking the scale)
What does the scale read? 99kg or 100kg or 99.5kg etc? If it is not 99kg what forces are at play given the mass of the ball and string are now in motion?
It is my notion that the motionless man on the scale reads 100kg because he, the string, and the ball are now one unit. Once the 1kg mass is in motion it becomes external to the unit and the scale reads 99.
What are your thoughts? (this isn't homework, just something that has been bothering me)
Justin
I believe the scale still reads 100kg. The ball is still being pulled down by gravity. This is why you have to spin something faster to make it rise towards a 90 degree angle. A spinning top doesn't weigh less than one that is stopped and fallen over.
My counter to the comparison of the top is that the top was and remains one unit so to speak. If the scale reads 100 how is that 1kg being transferred to the scale? If the string is horizontal how is the weight on the scale the same?
The weight is being pulled down by gravity, no matter if it is spinning or not. The string is near horizontal because of centrifugal force, not because the force of gravity has lessened. It is still pulling down on the string just as much as it was when it was stopped. You just have 2 different forces now instead of one.
Who was it that said "Give me a place to stand and I can move the world"? I'm just not as confident as you are on this. Astronauts experience weightlessness in orbit but there is about the same amount of Earth's gravity on them as us on the ground. They don't experience the sensation of weight because they have nothing to "stand on". If you are right than we must conclude the horizontal string still transfers 1kg to the scale as it would vertically. I just can't get past that concept.
It is still 100 kg. You can convince yourself of this simply by drawing some free body diagrams. You still have to exert a 10 N force up on the string to keep the ball from falling. By Newton's 3rd law that results in a 10 N force down on your hand. The force on the scale is then your weight plus those 10 N.
The reason is that the string isn't horizontal. The string is slightly below horizontal, with a 1 kgf vertical component to the tension (plus a much larger horizontal component which will depend on how fast the string is being swung).
So what you are saying is that it doesn't matter how fast the weight is spinning because you are still pushing up the 1kg anyway? Let's change the scene a bit. Let's say the man holds a high speed electrical motor attached to a string and weight, again with the string and weight equaling 1kg for a total of 100kg (man, motor, batteries, string, weight).
He holds the motor overhead and spins the weighted string...Same outcome? 100kg?
No. You have to include the weight of the motor and batteries.
apology. What I meant to say is that the man got thinner and he now weighs 99kg whilst holding the motor and batteries. :)
Same outcome. It's still 100 kg.
Then it would be 100 kg. Whatever the total mass is of all the things on the scale is what the scale will read. Spinning in a horizontal circle does not cause antigravity, otherwise we would have built vehicles on that principle.
It doesn't matter how fast he spins it, the strong cannot be horizontal. The vertical component of the tension in the strong (acting on the ball) must be nonzero to cancel the ball's weight. If the string is horizontal, the ball will accelerate downwards.
That is true. When books talk about horizontally spinning weights it should be understood that the ball is spinning in a horizontal plane, but the string necessarily rises above this plane for the reason you gave here.
I guess I didn't realize that the string would never become horizontal relative to the hand/motor...
DaleSpam, that's kind of what I was getting at. The mass of the ball is unchanged, but I was debating if the weight perceived at the scale would change given the weight is possibly external to the unit.
A good question to ask yourself is "What is holding the ball up against gravity?". The answer of course is the string and the person.
Justin
The red part is an important addition. As anyone who stands on a scale knows if you crouch down and then stand up quickly, your weight appears to change. Its fairly difficult to stand really still on a digital scale that reads to the 0.1 pounds, and not have it change some...
OK. We seem to have a consensus that the scale would indeed read 100kg. I think the concept I was missing was that the spinning weight is not on the same plane as the center. (i.e. not horizontal) It makes sense that the weight can be transferred down to the scale given the vertical component of the string is still present. Thanks to all for the input.
J
Krrrhm, a small correction folks. I submit that if the scale in questison is properly constructed, it will register MORE than 100kg. You all forgot horizontal force applied to the scale!
What prevents that ball from flyng away? String tension. Where does THAT come from? Well, via the man and the soles of his feet, ultimately - it's friction with the scale surface. Spin that ball fast enough and it can pull you off the scale...together with your electric contraption :-)
So, if your scale can measure horizontal as well as vertical forces applied to it, the total will be more than 100. How much more - depends on rotation speed. The resulting force vector will be rotating around the vertical and the angle - how far off the vertical it is, also depends on the speed.
How does a horizontal force make a scale have a higher reading?
I thought I explained it above. In detail.
The platform the man stands on must compensate (with a spring, counterbalance, whatever) not just for the gravity but also for the inertia of that ball flying in a circle.
But really... I repeat myself.
Before starting on this thread, I think we ought to think (have thought) what the consequence would be if the two weights didn't 'add up'. If they didn't, then we would have the makings of a reaction-less propulsion system and that's how we would all be traveling about the planet these days. I don't see any craft of any type which work this way.
What you have to do is find reasons for this suggestion to be basically flawed rather than to try to kid yourself that it could be right. It all boils down to the forces acting on the whirling mass and the string. The vertical component will be the same (assuming we eliminate vibration by controlling the spin well enough) whatever rate the mass is whirling round. The centripetal force will be just enough to sustain the circular motion and the tension in the string will be the vector resultant of the centripetal force (H) and the weight force (V).
How could this thread possibly have extended to two pages, I wonder? It must be such an attractive idea that people actually want Physics not to apply.
More likely it's simply the way even elementary physics is [not] taught in schools today.
On the other hand, that's the propupsion UFOs use, haven't you heard?
Yes, but I don't see how that matters to a horizontal force. (Not saying it doesn't, I'm saying I don't know)
You haven't ever been abducted and 'probed', obviously.
The man and mass will mutually move about their mutual CM if they are decoupled from the platform of the scales (either by having frictionless shoes or by wiggling his bum appropriately to maintain no horizontal force on the platform - a-la hula hoop). In that case, there will be no H force on the scales.
Since I started this thread I feel obligated to ask some of you guys to take a deep breath. I think it was a fair question worthy of asking and if you guys wish to debate how American high schools blow please do it elsewhere.
  • · Replies 56 ·
  • · Replies 29 ·
  • · Replies 0 ·
  • · Replies 16 ·
11K
