Does a Magnetic Field Do Work on Electrons in a Wire?
7 replies · 4K views · last reply
Phrak
How does a magnetic field do work on the electrons in a wire?
If F = q v x B, the magnetic field is always perpendicular to the velocity of the free charge. After a small time interval, dx = v dt, so that v and x are in the same direction.
For the magnetic field to do work on the charge, dW = F dot dx. But F and dx are perpendicular, aren't they?, so no work seems to be done.
A time varying magnetic field will lead to an electric field that does work.
An example is Faraday's law.
An electric generator does work because the field changes?
nicksauce said:
That's right. Magnetic forces never do any work.
A magnetic field acting on a permanent or electric magnetic can do work.
That is how an induction motor works.
Other motors use a permanent or electric magnet as an armature,
and a magnetic field does do work on the armature.
Pam, thank you for answering.
You threw me so far. I am now sure you are applying Faraday's law in integral form,
[tex]\int _{_\partial S} \overline{E} ds = -\int _{S} \partial_{t}\overline{B}dxdy[/tex] ,
it must surely be.
This makes some very good sense.
I could not possibly see how to apply Faraday's law in differential form,
[tex]\nabla\times \overline{E} = -\partial_{t}\overline{B}[/tex].
Unfortunately, I still cannot.
In the vicinity of the wire B is unchanging, we should presume. In such a manner [tex]\partial_{t}\overline{B}[/tex] should be zero as well, in this locally manner. But should this not make [tex]\nabla \times \overline{E}[/tex] zero as well?
Something I am missing.
Can this be understood in terms of a field that doesn't act at a distance?
Does a locally acting 4-vector potential, A and Dirac's equation of A acting on the phase of the free electrons in a conductor make some sense of it?
