Does a sinusoidal voltage source create a sinusoidal wave in space?
  • Level: High School
  • Thread starter Thread starter anhnha
    Wavelength
7 replies · 3K views · last reply
anhnha
Hi,
I want to ask one question about wavelength. Here is a picture defining wavelength.
To get a sinusoidal wave in space, we have to use a sinusoidal voltage source at transmitter, right?
I mean if there is a sinusoidal voltage source at the transmitter to create a sinusoidal wave in space.
Two sine waves stacked vertically: the upper plot is y against time t in s with period T marked in red, the lower plot is y against distance d in m with wavelength lambda marked in blue, both with amplitude a shown in green.
  • Two sine wave graphs stacked vertically: the upper plots y against time t in s, the lower plots y against distance d in m, each marking amplitude a and a period T or wavelength λ between successive crests.
Yes, where T is the period of the wave, f=1/T is the frequency, and lambda is the wavelength.
Note that wavelength x frequency = speed of propagation for the wave. This is the phase velocity.
Thank you, I wanted to know that to confirm my understanding about how wave propagating in space. For example,
there is a sinusoidal voltage source at transmitter and speed of propagation for the wave is v (m/s), the direction in which the wave moves is z.
Say, at t=0, the voltage at the source is 2V then at t=1s, at the point A that is v(m) away from the source in z direction, the voltage will be 2V, right?
If you are looking at an oscilloscope your phase will repeat in time steps of T=period of the wave=1/f.
Not sure what distance you are interested in here ...
I don't understand why the waveform in all wavelength are all sinusoidal. What shape of wave in space if the signal generated at transmitter is not sinusoidal? And then how we can definition wavelength in this case?
You could define terms like wavelength for a lot of non-sinusoidal waves, however there's a reason we usually focus on sinusoids. Fourier series/transform theory tells us that we can take any arbitrary wave and write it as a sum of sinusoidal waves. For example, a 2 Hz triangle wave can be written as a sum of 2 Hz, 4 Hz, 6 Hz, 8 Hz, etc. sinusoidal waves.
Rather than analyzing any arbitrary waveform (which may be messy and hard to understand), the easiest approach for a lot of problems is to break up an arbitrary non-sinusoidal waveform into sinusoidal components, analyze those components individually, and then add everything back up to get your result. It sounds like more work, but if you take a course on signal processing you'll quickly see the advantage. So basically, rather than study every kind of possible wave (assigning them wavelengths and what-not), we study sinusoids in great detail because we know that once we understand sinusoids, we can use that knowledge to understand a wide range of other types of waves.
Edit: by the way, you're right that a non-sinusoidal source would produce a non-sinusoidal wave. Your voice, for example, is a non-sinusoidal sound wave. However, like I explained above, it's usually much easier to describe your complicated vocal signal by breaking it down into sinusoidal waves rather than trying to analyze it directly.
Any wave has a period; you simply note when the wave repeats itself ...
But the simplest waveforms are sinusoids; you can build any wave from a collection of sinusoids - though it may take be a very large number, and sharp edges won't reproduce exactly.
If you look at the signal that's producing the wave (say, the signal from a tone generator, fed to a loudspeaker, waggling a string - and not necessarily a sinusoid, say a sawtooth waveform or perhaps a square wave) with an oscilloscope, you cannot know the wavelength - only the variation of the volts with time. A freeze frame photo of the wave on the string would have a similar shape, only this time the variation would be with distance, rather than in time. You would not know the frequency from that picture; it will show the wavelength. The relationship between the frequency, seen on an oscilloscope (number of cycles per second) and the wavelength (spacing between similar points on the wave), multiplied together, will give you the speed of the wave. That's how frequency and wavelength relate to each other (the so called 'wave equation').
See this link.
