Does a Toroidal Solenoid Violate Newton's Third Law?
  • Context: Graduate
  • Thread starter Thread starter htg
    Law Third law
6 replies · 3K views
htg
Consider a toroidal solenoid powered by a sinusoidal voltage. This will lead to appearance of sourceless electric field, also sinusoidally varying with time. Now consider a conductive ball in the center of the system. Let the electric charge on the ball vary in phase with the voltage applied to the toroidal solenoid. Then there will be force acting on the ball, due to the E field, but no force acting on the solenoid - the net charge on the solenoid is zero, there are no sources of the field E produced by the solenoid. This violates Newton's third law (action and reaction).
If you have thought about it earlier, please contact me at <personal email address removed>.
Just think about the presented example - it clearly shows that Newton's third law is violated (in agreement with Maxwell's equations).
The "oscillating" charge on the ball creates its OWN changing E and B field which interact with the solenoid!
Zz.
Hi htg, ZapperZ just gave you the key, but really the details of your example are completely irrelevant momentum is always conserved regardless of the details.
Did you even read the link I posted? If so, what part did you not understand? I would be glad to help you learn the principles involved and understand the derivation.
The link you provided makes use of the idea that an EM wave carries momentum.
Even if we assume that it is true, we can see that the total momentum carried out by the EM wave is ZERO because of the symmetry of the system.
This is getting sillier. EM waves carrying momentum isn't just an "idea", it is a FACT of experimental observation! The fault in your "thought experiment" has already been shown.
If you think that you have found a valid experiment that violates the 3rd law, then please publish it. Till then, this is unfounded speculation that violates the https://www.physicsforums.com/showthread.php?t=5374" that you had agreed to.
Zz.
