Does Bell's theorem imply nonlocality using a false assumption
6 replies · 3K views
Ali Lavasani
In https://arxiv.org/ftp/arxiv/papers/1409/1409.5158.pdf, the author (Donald A. Graft) concludes that Bell tests cannot refute local realism, because they employ a wrong analysis. He says:
"The quantum joint prediction cannot be recovered in an experiment with separated (marginal) measurements, just as for classical probability. Quantum mechanics correctly applied does not predict a violation of the CH inequality. The correct quantum mechanics prediction for an EPRB experiment must use the marginals (via reduced density matrices) and not the joint distribution. The source distribution in an EPRB experiment may be a joint one, but joint statistics cannot be recovered because the experiment yields only separated (marginal) measurements. A well-developed statistical field of study decomposes correlated joint distributions into the marginals plus an additional function called a copula. There would be no need for this field if any arbitrary joint distribution could be recovered through its marginals. Therefore, we cannot and do not apply the quantum joint prediction to EPRB experiments."
Also in https://arxiv.org/ftp/arxiv/papers/1309/1309.1153.pdf he mentions:
"Most importantly, quantum mechanics is shown to be compatible with local realism, by means of correct handling of separated systems. We cannot use the joint probability formula for cases of separated measurements; instead we use the marginals (partial traces or reduced density matrices) together with whatever priors we have from an understanding of the system. Specification of what are separated measurements is delicate but has been adequately addressed here. If we accept this small reinterpretation of quantum mechanics, nonlocality is eliminated. The experiments when correctly interpreted confirm the local realist position. Nonlocal entanglement is seen to be an error."
Another error he claims to have found is the application of Luder's rule to the EPR problem in https://arxiv.org/pdf/1607.01808.pdf. Here he says:
Lüders’ rule was developed for the treatment of ensembles [6], so its application to individual projection events is already problematic. Furthermore, by blindly applying Lüders’ rule to physical scenarios for which it is not validly applicable, such as EPR, nonlocality is in effect simply postulated by fiat, whereas Lüders’ rule is in reality not only incorrect for EPR, but is not needed to account for experiments correctly designed and analyzed. Prediction using Lüders’ rule is not a unique necessary quantum mechanical calculation for EPR. Alternative quantum mechanical calculations giving different results are available and required.
I don't completely understand this author's arguments, but I can't be convinced that all physicists have been making such basic mistakes for decades. Can anyone illuminate this case in a clear and rigorous way?
If this were true, then since the CH inequality is in fact violated in experiments, QM "correctly applied" would be falsified by experiment.
I haven't had time to read any of these papers in detail, but just from the above, I am highly skeptical that this person has actually produced a valid refutation of the standard arguments regarding the Bell Inequalities and EPR.
He is actually claiming that the data obtained in experiments doesn't show a violation, and I have quoted his reasons in the body of my question. I'd like to know whether he is right about the math stuff like "joint" and "marginal" probability and "use of Luder's law" used in the analysis of the data. These don't seem complex concepts to me, so I'm wondering how Bell and others haven't noticed it (if true).
The quotes you give don't give enough information to know what he's basing such a claim on. But I don't think it matters, because he doesn't get to make up his own way of comparing the standard QM predictions with experiments. The standard QM predictions already tell you how to compare them with experiments. If he has some different way of doing it, then he's not talking about standard QM, he's talking about some personal theory of his that he chooses to call "quantum mechanics".
I couldn't say without reading the papers, and I don't know when I'll have time to do that. But my Bayesian prior is extremely high that he's making a mistake somewhere.
