Does Black Hole Gravity Cause a Blueshift in Approaching Light?
The discussion revolves around whether the extreme gravity of a black hole causes a blueshift in light approaching the event horizon. Participants explore the implications of gravitational effects on light, including redshift and blueshift phenomena, and the perspectives of different observers in relation to these effects.
  • Some participants propose that observers near a black hole will measure incoming light as blue-shifted compared to a source further away, while others note that the perception of redshift or blueshift depends on the relative motion of the observers.
  • There is a discussion about the nature of light measurement, with some asserting that light does not change intrinsically and that redshift and blueshift are only meaningful in relation to the source and receiver.
  • A participant questions whether the intensity of gravity could affect the observation of light, suggesting that it might cause a continuous shortening of wavelength, potentially leading to blueshift beyond visible wavelengths.
  • Another participant challenges the idea of "observer-independent blueshifting," arguing that energy and wavelength measurements are inherently dependent on the observer's frame of reference.
  • Some participants discuss the breakdown of redshift into components attributed to velocity and gravity, suggesting that such distinctions are arbitrary and coordinate-dependent.
  • A later reply introduces the idea that in a stationary spacetime, hovering observers can provide a meaningful context for discussing gravitational effects on light, though this is not observer-independent.
  • There is curiosity expressed about whether gravitational effects could increase the frequency of light to visible levels as it approaches the event horizon, raising questions about the nature of light escaping a black hole.
Participants do not reach a consensus, with multiple competing views on the effects of black hole gravity on light and the nature of redshift and blueshift. The discussion remains unresolved regarding the implications of gravitational effects on light measurement.
Participants highlight the complexity of discussing redshift and blueshift, noting that definitions and assumptions about observers and reference frames are crucial to understanding the phenomena. The discussion reflects a range of interpretations and uncertainties regarding gravitational effects on light.
  • #31
PeterDonis said:
Also, to hover that close to a black hole's horizon, you need a rocket with an extremely powerful engine and lots and lots of fuel, since the rocket thrust required will be enormous. The effects you describe are best viewed as due to the enormous rocket thrust, not due to the radiation itself.
Oh yes, if a spaceship is equipped with a ridiculously powerful engine, turning on a light bulb on the ceiling will cause a filament shaped hole to appear on the floor.
  • #32
If the ship's acceleration is large enough relative to its height that the blueshift from ceiling to floor is that large, yes. But that is a much more stringent condition than what is required for the ship to hover close enough to a black hole that radiation coming in from far away is blueshifted to that extent. A ship in the latter situation could still have negligible blueshift over the range of its own height.
  • #33
jartsa said:
Let's say I start shining a laser pointer down towards a black hole. One meter above the event horizon there is a hovering mirror that reflects the light back. When I see the reflected light I turn the laser pointer off.
Now I calculate that the total number of produced waves was 1020. And all those waves were in the space between me and the mirror when the first wave returned.
Next the experiment is repeated, but this time the mirror is one micrometer above the event horizon. This time 1023 waves can be calculated having been between me and the mirror.
Well, it seems like in the latter experiment thousand times more waves were packed between me and the mirror compared to the first experiment.
(It took thousad times longer time for the light to return in the second experiment, because of Shapiro delay)
Jartsa,
Your experiment got me thinking and curious about what happens if the mirror is now 1 micro meter past the EH? Is the EH the critical point where space time dilation increases the path length beyond the photons ability to return?
  • #34
Revolucien said:
Jartsa,
You can't have a mirror hovering below the event horizon. Anything below the EH follows a path to the singularity.
Instead, you could think about someone falling through the EH and shining light in all directions. At the EH, light shone radially outward would theoretically hover at the EH indefinitely. Light in all other directions would follow a path inward towards the singularity. And, once below the EH, all light paths lead to the singularity. There are no light paths starting from inside the EH that cross the event horizon.
  • #35
I would like to add that a photon emitted inside the black hole upward "falls" towards the singularity. So even emitted upward it's r-coordinate decreases.
EDIT I just recognized @PeroK said the same: "And, once below the EH, all light paths lead to the singularity. "
  • #36
From the perspective of an observer at any point in space above a black hole's event horizon, stationary with respect to the black hole, the blueshift of a light beam shown down to the event horizon would be infinite. By the time the front of the light beam reaches the event horizon, the light beam (imagine an idealized laser beam) would contain an infinite sequence of light wave cycles.
  • #37
This doesn't make sense; the observer you're talking about is emitting the light beam, not receiving it. But "blueshift" means observed blueshift, i.e., blueshift observed when the beam is received. It's impossible to have an observer stationary exactly at the horizon to receive the beam.
  • #38
An observer stationary above the horizon would observe finite blueshift and another observer at the horizon wouldn't observe infinite blueshift because he can't be stationary there. He would be in free fall instead and thus would observe this light beam (source far away) redshifted with z = 1.
  • #39
Note that there is no requirement that an observer crossing the horizon be in free fall. He could be firing his rockets and accelerating. He just can't possibly fire his rockets hard enough to stop at the horizon.
Also, the redshift of z = 1 for radially ingoing light from infinity, strictly speaking, is for a Painleve observer crossing the horizon, i.e., an observer who free-falls "from rest at infinity". Observers who free-fall from rest at a finite altitude will have a different 4-velocity when crossing the horizon so the redshift they observe won't be exactly z = 1.
  • #40
Got it, thanks.
  • · Replies 22 ·
  • · Replies 62 ·
10K
  • · Replies 40 ·
  • · Replies 22 ·
  • · Replies 46 ·
11K
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 22 ·
