Steven Bolgiano
- Messages
- 53
- Reaction score
- 6
Hi Folks,
I'm 70, so I often confuse myself! Ha !
My question is: Do materials both absorb and release heat equally?
So when I evaluate different materials for thermo efficiency, does a copper pipe's surface absorb solar heat at the same rate it gives off heat?
My question is specific to a solar water heated, anaerobic digester project already under construction. The digester itself is a soft tank, tightly sitting inside a frame and acrylic panels, ... heated from underneath with solar heated water.
The plan for the sake of economy, is to use 3/4" cPVC pipe in a clear sealed "cabinet", for collecting the solar rays, that connects adjacently, to another pattern of 3/4" type N copper under the tank to heat the tank.
Attached are some slightly obsolete images, I just used to grab quickly, ... but they may help to visualize
So if there is a large disparity between the Collector (cpvc) and the Radiators'(copper) conduction rates, ... am I wasting time using copper for the radiator, because of that disparity?
I was hoping using copper as the Radiator, would use the heat from the cPVC with the optimum efficiency.
As I understand the three methods of heat transfer, any comments, corrections:
Conduction - Heat transfer by molecular contact
Convection - Heat Transfer through density differences
Radiation - Heat transfer by wave motion (no material required)
Conduction operates by contact
Convection operates by density
Radiation operates by waves
