Does ΔG° for reactions vary by temperature?
ΔG° (Gibbs free energy change at standard conditions) does vary with temperature, contrary to the common belief that it is constant at 25°C. The equation ΔG = ΔG° + R*T*ln(K) indicates that ΔG° can change based on the equilibrium constant K, which is temperature-dependent. The discussion highlights the distinction between ΔG and ΔG°, clarifying that while ΔG varies with temperature, ΔG° is defined under standard conditions but can still be influenced by temperature when calculating related properties like ε° (electromotive force) at different temperatures, such as 90°C.
  • Understanding of thermodynamics principles, particularly Gibbs free energy.
  • Familiarity with the equations ΔG = ΔH - TΔS and ΔG = ΔG° + R*T*ln(K).
  • Knowledge of standard conditions in thermodynamics, specifically the significance of 25°C.
  • Basic grasp of equilibrium concepts in chemistry, including the role of the equilibrium constant (K).
  • Research the relationship between Gibbs free energy and temperature in chemical reactions.
  • Study the implications of the equilibrium constant (K) on Gibbs free energy changes.
  • Explore the concept of standard conditions in thermodynamics and how they apply to various reactions.
  • Learn about the calculation of electromotive force (ε°) at different temperatures and its relation to Gibbs free energy.
Chemistry students, thermodynamics enthusiasts, and professionals in chemical engineering or physical chemistry who seek to deepen their understanding of Gibbs free energy and its temperature dependence.
Nikitin
I thought it was only ΔG which varied by temperature,with the equation ΔG = ΔH - TΔS ?
It makes no sense to me why ΔG° (= change of gibbs free energy at standard conditions during a reaction) should vary with temperature, but I've gotten an assignment here to calculate ε° for a reaction at 90°C (ε is a function of ΔG), which suggests that ΔG° does indeed vary!
How can this be? I thought Gibbs free energy at standard conditions was always constant, with the temperature being 25°C?
Chemistry news on Phys.org
ΔG° at 90°C, when ΔG° is defined for 25°C - something doesn't add in what you wrote.
Is ΔG° for a reaction defined at 25 degrees, or is it temperature independent? This is what I am unsure about..
Defined at 25°C if you ask me.
Not that I am always right when it comes to thermodynamics.
Conjectures:
1) Maybe the superscript "°" doesn't represent all "standard conditions." Maybe "°" in this case it only represents "standard pressure".
Maybe ε° is the internal energy at standard pressure. Maybe the temperature is allowed to vary for internal energy.
2) Maybe in your system the internal energy, ε, doesn't vary with temperature. Maybe it only varies with pressure.
Just because ΔG varies with both temperature and pressure doesn't mean that the internal energy has to vary with both temperature and pressure. The variation with temperature may be subtracted out.
I admit number 2 is a bit of more speculative then the other one. It would take a strange equation of state to make the internal energy NOT vary with temperature. Number 1 is just a matter of convention. Not everyone is careful with the use of subscripts.
By the way: I am used to seeing internal energy designated by "ΔU", not "ΔG". I had to go through Wikipedia to find out that ε sometimes represents internal energy.
Maybe the exact text of the assignment would be helpful.
It was asking for the emf° (=ε°) at 90°C for a certain reaction. ε is the international sign for emf in chemistry, right?
Anyway, I think delta G does indeed vary by temperature. According to this equation, (ΔG = ΔG°+R*T*ln(K), at equilibrium ΔG° = -R*T*ln(K). This implies ΔG°=0 when K=1 at equilibrium, thus ΔG° must vary with temperature (since it can be both 0 and other values, depending on K). Can anyone see the flaw in my reasoning?
Indeed, when K=1 then all the substances in the equilibrium have an activity of 1. This means that ΔG = ΔG° only when that is the case (or if T=0).
Darwin123: Internal energy (=U) and G are two entirely different things. Internal energy represents the energy of the molecules (=1.5*R*T for an ideal gas), G represents energy free to do work during reversible processes. Enthalpy is a function of U. H = U + P*V. Gibbs free energy is a function of H, T and S. G = H - T*S
29K
