Does every orbiting object have spin
  • Thread starter Thread starter Moazin Khatri
    Spin
Every orbiting object can have spin, but its behavior depends on initial conditions. A thrown object, like a basketball or arrow, will maintain its spin unless acted upon by external forces, such as tidal deformation over time. If thrown without spin, it will orbit Earth while its orientation changes relative to the planet. Artificial satellites, like the ISS, are often oriented to face Earth using small steering jets to maintain a consistent position. Tidal locking can occur over time, causing some objects to rotate in sync with their orbit.
Moazin Khatri
Our moon rotates around Earth in such a way that we always see the same face. But Earth orbits Sun in a different way. It keeps spinning. My question is, If I were to go to space and put a basketball in a circular orbit around Earth in such a way that at the time I throw it a particular face is facing Earth would it orbit Earth like the moon does(always the same face) or would it have a much faster spin?
No coincidence, but the ultimate result of tidal deformation.
Your baseball would spin at whatever spin rate you give it when throwing. If you throw exactly hard enough for a circular orbit and don't give it any spin, it wouldn't rotate, just orbit. (i.e. on your location on Earth you always see the same side, but your antipodes see the opposite side). In the long run this tidal deformation might change that -- see link.
Think of the central character of the gravitational force and conservation of angular momentum.
Thanks for your answer. Just clear one more thing .. Just to confirm If I have properly understood what you're saying...
If instead of a baseball I use a physical arrow .. throwing it hard but no spin at all .. is it true that in its circular orbit there will come a time when the arrow will be parallel to the surface of the Earth and there will also come a time when it will be perpendicular?
And if this is true then why is it that whenever we see pictures of artificial satellites like ISS orbiting Earth .. their main body seems parallel to the surface of earth? Do they add spin when they launch it?
P.S: The arrow thing will only be true if velocity vector is parallel to the body of the arrow .. If it is perpendicular then it will always remain parallel to earth. And the same might be true with ISS. Looking forward to your reply!
The consequence of what I wrote would indeed be as you describe: orientation in space invariant, so wrt Earth center it will rotate once per orbit.
ISS and other earth-facing satellites will probably be oriented properly with small steering jets.
@haruspex: are you aware of any mechanisms that would be helpful (or unhelpful) in this ?
Hmm... Thank You
I agree with what you posted. All objects would be subject to some tidal deformation, and over time that would lead to tidal locking.
Some satellites would be set into a one spin per orbit mode deliberately, so tidally locked from the start. Others might need to be in constant sidereal orientation, so might need a very small jet to maintain that. But without doing the calculation, I would guess the effect is small compared with, e.g., the solar wind on the solar panels.
Likes BvU
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
