Undergrad Does Gravity Affect Space Density in a Vacuum?
The discussion centers on the hypothetical scenario of the sun popping in and out of existence and its implications for space density and gravity. Participants argue that the question is fundamentally flawed, as it violates principles of physics, particularly energy conservation in general relativity. It is noted that mass curves spacetime, but the concept of "density of space" is deemed nonsensical in this context. The conversation emphasizes that curved space cannot be directly compared to flat space in terms of density. Ultimately, the scenario presented is considered internally inconsistent, leading to the conclusion that it cannot be meaningfully analyzed within the framework of established physics.
grahas
I was watching a movie called Everything and Nothing. It got me thinking. For the sake of argument pretend that you could make the sun pop in and out of existence. If you were to measure the distance between two points on the other side of the solar system with no sun, then if the sun were to just appear would the distance between the points shrink?
The question makes no sense. You cannot ask "what does physics say about a situation where I explicitly assume that physics does not hold?" and expect meaningful answers.
Well, answer is yes.
You are measuring space density by using light. Mass objects are creating gravity which affects light.
But there is a 'but'. Sun is quite massive. Mass creates gravity. But what in essence is mass and how it is connected to space in the first place no one knows. So maybe sun is dense space and you are putting it in less dense space. Maybe not. How it works... well, we know that without gravity space is 'flat'.
Einstein's field equations have the concept of local conservation of energy built into them. It therefore is not possible to describe the effect of the Sun popping in and out of existence (as @Orodruin said) in terms of general relativity since that would be a massive violation of energy conservation, so is inconsistent with general relativity.
This is not correct. The answer is not defined because the scenario is internally inconsistent.
Do you have a reference to support either of those positions?
https://en.wikipedia.org/wiki/General_relativity#Definition_and_basic_properties
Definition and basic properties
General relativity is a metric theory of gravitation. At its core are Einstein's equations, which describe the relation between the geometry of a four-dimensional, pseudo-Riemannian manifold representing spacetime, and the energy–momentum contained in that spacetime.[36] Phenomena that in classical mechanics are ascribed to the action of the force of gravity (such as free-fall, orbital motion, and spacecraft trajectories), correspond to inertial motion within a curved geometry of spacetime in general relativity; there is no gravitational force deflecting objects from their natural, straight paths. Instead, gravity corresponds to changes in the properties of space and time, which in turn changes the straightest-possible paths that objects will naturally follow.[37] The curvature is, in turn, caused by the energy–momentum of matter. Paraphrasing the relativist John Archibald Wheeler, spacetime tells matter how to move; matter tells spacetime how to curve.[38]
Following.
Mass is curving spaces. Curved space is more dense (than flat one).
Surely in GR there is no poping on and out of existence.
No, it isn't. The concept of "density of space" makes no sense. There is no way to compare a curved space with a flat one in the way you are thinking.
Wikipedia is not a good primary source. You need to look at a textbook. Sean Carroll's online GR lecture notes are a good start:
https://arxiv.org/abs/gr-qc/9712019
The OP question is based on misconceptions, which have been corrected. Thread closed.
  • · Replies 35 ·
  • · Replies 27 ·
  • · Replies 16 ·
