Does Heating Air First Improve Dehumidifier Efficiency?
The discussion revolves around the efficiency of dehumidifiers, specifically whether heating air before it enters the dehumidifier improves the condensation process. Participants explore the mechanics of dehumidifiers, the role of temperature in condensation, and practical experiences with similar devices.
  • Experimental/applied
  • Some participants describe the typical operation of dehumidifiers, noting that they cool air to condense moisture and then warm it back to room temperature.
  • One participant suggests that heating air before cooling could enhance condensation due to a greater temperature difference, while others challenge this notion, arguing that condensation requires cooling to the dew point first.
  • There is a discussion about the mechanisms of heating, with some suggesting that warm refrigerant is used rather than electric resistance.
  • Participants express confusion about the airflow direction in dehumidifiers and how it affects performance.
  • One participant shares personal experience with mini-dehumidifiers, raising questions about the impact of fan speed on efficiency and overheating risks.
  • Another participant mentions issues with ice formation in dehumidifiers during cold conditions, suggesting that pre-heating may be necessary to prevent blockages.
  • There is a mention of using additional heating methods in conjunction with dehumidifiers in cold environments to improve functionality.
Participants do not reach a consensus on whether heating air before cooling it improves dehumidifier efficiency. There are multiple competing views regarding the mechanics of dehumidification and the effects of temperature on condensation.
Some participants highlight practical issues such as ice formation in dehumidifiers during cold weather, indicating that real-world performance may differ from theoretical expectations. There are also unresolved questions regarding the specifics of airflow direction and fan performance in relation to dehumidifier efficiency.
everybest
I did some research on how dehumidifiers work and from what've been able to find out, it takes in room-temperature air, cools it, thus condensation, then runs it back through heated coils so bring the air back to room temperature.
I got around to taking apart an actual dehumidifier it's pretty much as expected. The only thing that was actually different from my little bit of research was that the air was heated up first and then cooled down rather than vice versa. So the condensation process goes from warm to cool, rather than room-temperature to cool. Would this increased temperature difference make condensation more effective even though the source of the air is the same? Or would warming up the air first dry some of the moisture out?
Science news on Phys.org
It doesn't make sense.
To dehumidify, you neet to cool the air until dew point. Further cooling will not cool the air but will condensate humidity. Afterwards, you need to warm the air up to room temperature.
If warming comes first, you'll never get condensation.
By the way, wrming was done with electric resistance or was it using the hot part of the cooling machine?
Well, it wouldn't be done with electric resistance, it would be the warm refrigerant. But I always thought the airstreams were separated and that the cool plates just absorbed water via convection/vapor pressure.
This doesn't make any sense to me either. What part of the machine is indicating to you the direction of airflow?
Looking at the psych. chart its pretty easy to see that if you heat the incoming air, then cool, without heating it again, your just wasting energy. Unless I'm completely missing something.
Perhaps this issue can be further addressed by looking at the functions of it's opposite; the humidifier... or it's close cousin, the "swamp cooler"
I realize that a standard home "air-conditioner" has de-humidifying effects. In contrast, a swamp cooler might be an excellent example of a simple humidifier.
No, I don't think that's helpful. A swamp cooler does not include a thermodyanamic cycle, so there is nothing to analyze. Functionally, a dehumidifier should be exactly identical to an air conditioner.
Thanks for all the replies, that seems to make sense and helps a lot.
This was what I look apart: https://www.amazon.com/dp/B000FABESC/?tag=pfamazon01-20
I opened up the case and spread out it's components, plugged the power back in and I was looking at the fan and it's airflow direction. The fan is infront of that front vent and it seems to be sucking air directly into the warm heatsink. I will reinspect it more carefully when i get my hands on the device again Monday.
From what I can tell, it's using a Peltier module wedged between the warm and cool heatsinks. There are 2 pairs of wires though, looks like 1 pair per heatsink? I would have expected just one, so I will figure out what those are doing too.
Peltier. Interesting. So it seems that the thermic cycle is not performing well enough to get the air warm again after cooling it.
Hello
I have a mini-dehumidifier of a similar type to the one that EveryBest took apart. I have just replaced the fan because it had become extremely noisy. Although the new fan is a higher quality and much quieter fan with the added bonus of rubber mounts I suspect it may be somewhere between 1/2 and 1/3 of the speed as it is a 0.15 A one running at 1500 RPM and, whilst I don't know how fast the old one ran, it was a 0.4 A one and some 0.4A ones on eBay are advertised as going as fast as 3800 RPM.
I'm just wondering, is the work done by the dehumidifier controlled by the throughput of air? Will the dehumidifier overheat if it does not have as fast a fan?
Kind regards
Peter
Scotland, UK
PS Having had several of these mini-dehumidifiers (of assorted brands and appearances) go wrong over the past few years, some of the old ones should also be fixable by replacing the fan. In some the electronics to the Peltier module presumably failed as water stopped being accumulated despite the fan running, while in some others the transformer failed.
I've never known how interchangeable such transformers are i.e. which features have to be exactly the same for a replacement transformer to be safe and reliable. Any hints?
Kind regards
Peter
Well ... the fan that you use needs to provide the same amount of cooling as the original fan or the warm side of the peltier device will get too hot and it won't work as efficiently or fail altogether.
As far as transformers are concerned what matters is the voltage output and the maximum current output. You need to make sure that both match what the original transformer was providing. The transformer may or may not have a label that shows what it's outputs are.
Thanks. I think the fan needed to be installed upside down (with label underneath) as I have discovered the airflow is in the wrong direction. Will try it later.
There is an issue with dehumidifiers that doesn't seem to have been mentioned. Without some pre-heating in very cold conditions, the condensate can form ice at in the output heat exchanger and block the system entirely.
Having bought a cheap and cheerful one for drying out an uninhabited building, a few winters ago, I found this was what happened - a solid block of ice inside! I then found out that the more expensive ones have a pre-heater to avoid this effect. I imagine the pre-heater is only used if the exhaust temperature could be low enough for freezing to occur.
All the above Physics could well be right but real life sometimes takes over.
Sophie
Yes, I agree about them icing up! I use a tube heater in conjucntion with the dehumidifier in moderately cold conditions and turn the dehumidifier off altogether in very cold ones. They're only meant for 15 degrees C or above.
Kind regards
Peter
You can get the same problem with fancy no-frost food freezers. Once it starts to build up, the ice never seems to go away by itself. Hours and hours of defrosting time are needed because the ice is deep inside the guts of the machine.
  • · Replies 32 ·
  • · Replies 109 ·
10K
  • · Replies 25 ·
