Does Higgs Boson Discovery Support 4-D Spacetime Model?
The discussion centers on whether the discovery of the Higgs boson supports a 4-D spacetime model, particularly in the context of the standard model of particle physics and its implications for theories of gravity and higher energy physics. Participants explore the relationship between the Higgs boson, spacetime models, and concepts such as time travel.
  • Some participants argue that the Higgs boson is predicted by the standard model, which operates under the assumptions of special relativity and a flat 4D spacetime.
  • Others suggest that while the Higgs boson is included in the standard model, its inclusion is seen as a necessity to explain experimental data rather than a prediction based on deeper theoretical foundations.
  • There is a discussion about the implications of the Higgs boson discovery for the standard model's validity at higher energy levels, with some suggesting that new physics may emerge if the Higgs is not found.
  • One participant questions the relevance of time travel discussions in relation to the Higgs boson, suggesting that such connections are unfounded and not scientifically valid.
  • Another participant expresses skepticism about the connection between the Higgs boson and time travel, labeling it as nonsense and not worthy of speculation.
Participants express differing views on the predictive nature of the Higgs boson within the standard model and its implications for spacetime models. There is no consensus on the validity of time travel discussions related to the Higgs boson, with some dismissing it entirely.
Participants note that the standard model's success is particularly strong in certain areas, but it has weaknesses in neutrino and Higgs physics. The discussion also highlights the lack of deeper justification for the Higgs potential within the standard model framework.
Descartz2000
Would the Higgs boson discovery support a 4-D spacetime model?
Yes. The Higgs is postulated within the framework of the standard model of particle physics, which takes special relativity as one of its assumptions. Special relativity assumes a flat 4D spacetime called "Minkowski spacetime".
The discovery of the Higgs particle (+ non-discovery of other particles + non-discovery of other effects) would confirm that SM + 4-dim GR is 'correct' and 'complete' within the energy range accessable at the LHC.
But it doesn't say anything regaring higher energies, Planck scale physics, unification of gravity with other forces, SM generated by broken SUSY generated by low-energy strings + compactification.
So the Higgs particle isn't PREDICTED by the standard model, but merely added in addition to it?
No, the Higgs is predicted by the SM. But in order to produce that predition - and, more importantly, explain a large number of other experimental observations, the SM has to "parachute in" a quartic 'Mexican hat' Higgs field potential into its Lagrangian. The SM has no deeper justification for this than that it explains the data.
More likely, most of us probably feel, that Higgs potential is the result of some even more fundamental physics at higher energy levels...
Is this why I have seen some discussion on aspects of time travel in relation to the Higgs boson, in the sense that the past, present, and future are 'laid out' or existing in principle? Or, maybe it is better for me to ask: How does time travel relate the Higgs boson discovery, or is this merely pseudo-science speculation and really nothing to do with science at all?
I don't know where on Earth you heard it, but any connection between the Higgs boson and time travel is total nonsense. It doesn't even deserve the term 'speculation'.
So if no Higgs boson is found, what happens to the standard model? Will it essentially stay the same with the addition of the new physics at higher energy?
The place on Earth that I read about this concept was while sitting in front of my computer. Type in 'higgs boson and time travel' into a search engine and see what pops up-
Probalbly yes. The success of the SM is outstanding, especially in the el.-mag. and in the strong sector. The weak points are neutrino and Higgs physics.
  • · Replies 24 ·
  • · Replies 17 ·
