Does it look like I'm doing this double integral correctly?
18 replies · 2K views
DottZakapa
{(x,y)∈R^2|x^2+y^2<=4, y<=x+2 }
integral of 8x dx dy
double integral
are the boundaries of integration correct?
i split the domain in two as follows
-2<=x<=0 , -(4-x^2)^(1/2)<y<=x+2 and
0<=x<=2 -(4-x^2)^(1/2)<=y<=(4-x^2)^(1/2)
if, concerning the one on the right, if I use polar coordinates, the boundaries of integration become
0<=r<= 2 and pi/2 <= ##\theta##<=-pi/2
is it correct doing so?
Yes, although you could include the third quadrant as well in that case: ##-\pi \le \theta \le \frac \pi 2##. And that simplifies the bounds on the other integral.
so i don't understand why my result doesn't match with the solution :(
What is your answer?
-32 the one on the left and -128/3 the one with polar coordinates
The answer must be positive, as there is more positive ##x## than negative ##x## remaining. I think you got a sign wrong somewhere.
mind if i post the picture of my calculations? just to save typing time?
Do you mind if a post the picture of my calculations? just to save time
Okay by me.
Just an idea, did you integrate ##\cos \theta## as ##-\sin \theta##?
You've got the bounds on the integral the wrong way round.
could be that being integrating from pi/2 to -pi/2 should i put a minus sign in front of the integral due to the clock wise direction ?
PeroK said:
You've got the bounds on the integral he wrong was round.
sorry I'm not getting what you are saying
The way ##\theta## is defined in polar coordinates, you integrate anti-clockwise. In this case from ##-\frac \pi 2## to ##\frac \pi 2##.
Yeah, but you didn't integrate ##r## from ##2## to ##0## and put a minus sign in front!
ok integrating from -pi/2 to pi/2 and putting al together everything works thanks
A couple typos here might have confused the OP. This should read "You've got the bounds on the integral the wrong way round."
@DottZakapa, keep in mind that ##\int_a^b f(x) dx = -int_b^a f(x) dx##, so if you integrate in the reverse direction, the sign of the result changes. That's what @PeroK was talking about in the quote above.
