Does Microwave Energy Transfer Depend on Contents Inside?
  • Context: High School
  • Thread starter Thread starter physicsnoobie79
    Microwave Physics
The discussion revolves around the question of whether microwave energy transfer is consistent regardless of the contents inside the microwave. Participants explore scenarios involving heating milk in different quantities and the efficiency of heating multiple mugs simultaneously. The scope includes theoretical considerations, experimental suggestions, and conceptual clarifications related to microwave heating processes.
  • One participant questions if the heat transferred to the contents is largely constant across different amounts of milk heated for the same duration and power setting.
  • Another participant hypothesizes that heating a half-full mug and then topping it up will result in a colder temperature compared to heating a full mug directly.
  • Some participants suggest that the efficiency of heating two mugs simultaneously versus one after the other may differ, with one proposing that two mugs will take approximately twice as long to heat.
  • A technical explanation is provided regarding the relationship between load resistance and power transfer in microwave ovens, with a focus on the implications of mismatched loads.
  • Participants discuss the importance of stirring to achieve uniform temperature and suggest that experiments could clarify the heating efficiency and temperature outcomes.
  • There are mentions of the potential for improved microwave designs, such as incorporating magnetic stirrers, to enhance heating efficiency.
Participants express differing views on the efficiency of heating methods and the impact of load on microwave energy transfer. There is no consensus on whether the heat transferred is consistent across different scenarios, and the discussion remains unresolved regarding the optimal heating approach.
Participants note that the efficiency of microwave heating can vary based on factors such as load impedance and the specific characteristics of the microwave oven. There are also references to the need for careful measurement and experimentation to draw reliable conclusions.
physicsnoobie79
TL;DR
At a specific microwave power setting and duration, is the heat energy transferred to the contents relatively constant?
I've got no real physics education but I am interested in it from a popular science and layperson level. If anyone is able to help with this thought experiment.
My question is, on a given microwave power setting and a fixed duration, is the heat transferred to the contents largely constant regardless of what is inside?
E.g. if I want to heat milk a mug so the milk is warm, are the two the roughly the same:
1. Pour cold milk into a mug until mug is full. Microwave set to 900W and 1 minute duration.
2. Pour cold milk into a mug until mug is half full. Microwave set to 900W and 1 minute duration. Top up mug with cold milk until full.
Will both scenarios result in broadly the same temperature?
Likewise, if a full mug of milk takes 1 minute to warm at 900W setting. If I then want two full mugs of milk, what will be more efficient:
1. Putting both mugs in the microwave at the same time, run at 900W and for 2 minutes duration or
1. Put each mug in one after the other, each mug being heated at 900W and for 1 minute each?
The above thought experiment is for nothing other than to conclude a friendly family debate :-D
Science news on Phys.org
The best way to check this is to actually experiment. I have not done the experiment so I don't actually know the answer.
My hypothesis would be that for your first experiment they would not be roughly the same. I would guess that 2 will be substantially colder than 1.
This reminds me of the "tea or milk first" debate. Taking into account evaporative cooling, I would hypothesize that in both scenarios above, option 2 will lead to colder milk.
physicsnoobie79 said:
TL;DR Summary: At a specific microwave power setting and duration, is the heat energy transferred to the contents relatively constant?
This is a very difficult question, I think. I trawled around for some help and I found this link which I briefly looked at and which would be worth a look. But most of the hits I got from my search seemed more interested in the various modes that the waves have within the cavity than in the actual heating process for the food put in it.
In any system which involves a radio frequency amplifier / source and a load, it's usual to need to know the Impedance of the load in order to know how much power will be transferred to it and how much will be reflected and wasted. A microwave oven uses a magnetron which is a fairly robust device (actually, a pretty magic invention aamof) which can 'handle' a range of load impedances (jugs of water / lumps of meat etc., all of different sizes). But a nominal 900W setting will not necessarily mean that the 900W is getting into the water.
The efficiency factor can vary a lot. This link claims to have values but I honestly suspect the figures may not be too reliable and comparing one appliance with another would need lots of different cooking loads and types. They suggest values 70% up to the high 90's%.
I agree with @Dale who suggests that you could very easily do some experiments with various masses of water in glass jugs. Avoid unspecified crockery which may absorb much of the microwave energy and mess up your results.
Best to operate well below 100C, for good practical reasons and measure the temperature as soon as you can, after removing the jug. (don't leave it inside during cooking!)
After thorough stirring! (Otherwise the temperature of the water will not be uniform and the reading meaningless.)
Good call! On that topic, I often wonder why they don’t offer a magnetic stirrer (chemistry lab style) in microwave ovens.
I’m sure it would be possible to suppress induced currents in the puck with suitable slots(?).
Just think; perfect sauces with no stop-stir-stop-stir.
Even easier would be to have it in electric stove tops. I have been wondering about this absence for a long time...
Good idea for some applications; I had a Dowe Corning glass casserole for years . Unfortunately, the pans needed for induction hobs are iron content and I would never willingly leave induction cooking in favour of auto stirring.
The 'old' microwave ovens with turntables could work with a paddle suspended from the roof of the cavity. 'Height adjustment' problems in a deep bowl could require a fancy fixture, though
An elbow joint type mechanism ?
If we consider the magnetron as a generator and the coffee cup as its load, then for max power transfer the resistance of the two will be equal. If we now reduce the load resistance to half by adding a second cup of coffee, the total power transferred will drop only slightly. This may be seen if the generator resistance is considered to form a potentiometer with the load resistance. For one cup, Rg=Rl and voltage is one half, but for two cups the voltage is 0.5 Rl/(0.5 Rl + Rg) = 0.5 / (0.5 + 1) = 1/3. The power delivered to one cup is then V^2/R = 1/(4 Rl) and to two cups is 2/(9 Rl). so the comparison is 0.25 in the first case and 0.22 in the second.
From this I would conclude that two cups will take approximately twice as long as one. In other words, the total energy being supplied is not excessively sensitive to the actual load.
I couldn't disagree with that in principle but there is a significant SWR (evidence in the locally melting ice cream experiments) so affairs it's anyone's guess. The power delivered to a mismatched load on the end of transmission line with a high VSWR will be very dependent on the line length / frequency. I imagine that the dimensions of the cavity would have been chosen for the best performance overall, after a number of tests. (They must be sick of baked potatoes and ready meals.)
The way forward is to do a number of experiments and careful adherence to the above ideas - stirring and quick measurements. It would be good if the OP could get back to us with a brief report of results. ;-)
No it won't be the same ( read below ) .
Hello there . That's an interesting question . In my opinion :
What's important to realise in first place is that there's no heat transferred to food ( you really don't have any heat flowing ). I get what you mean , but it's important to realise why it's wrong to talk about heat transfer , because this insight will help understand the answer to your question better .
What the microwave oven does is to fill it's inner space with standing EM waves ( the oven chamber acts like an EM cavity ). When you put food inside this cavity you basically force food's molecules to vibrate due to the oscillating EM field inside the cavity . The vibration of food's molecules results in heat production .
An important detail here is that not all molecules can actually vibrate . At least not as much as others . The molecules should pocess a property called dipole moment . In very simple terms there should be separation of a positive and a negative charge ( could also be induced to some degree by the field itself if not inherent to the structure of the molecule )* .
So yes , the content of the microwave oven definitely affect whether the object will be heated and if energy is going to be drained from the cavity . Therefore...
If a full mug of milk takes 1 minute to warm at 900W , then you should place both mugs in the oven for just 1 minute . The energy is there , in the cavity . Placing a second mug of milk won't affect the heating of the other mug . You are just draining more energy from the EM field which is already stored in the cavity .
*Conductive materials can also heat in the oven . Extremely fast to be honest , so you have to be extremely careful and never , ever put something conductive in a microwave oven like for example aluminum foil .
It is not necessary to have a resonance in the box for a magnetron to supply energy to food. When you switch on, the resonant energy builds up to a maximum over many cycles. When you switch off, the box then supplies energy to the load and to the magnetron over many cycles. When the magnetron supplies energy to food, a travelling wave goes from the magnetron to the food. Resonance can be useful to provide transformer action but is not fundamental to microwave heating.
sophiecentaur said:
...I often wonder why they don’t offer a magnetic stirrer (chemistry lab style) in microwave ovens.
Things in microwaves are generally - and imminently - headed for someone's mouth, not a beaker.
In order to do its job, an impellor feature would have to be engineered into the stove. i.e. not just a gadget you buy at Bed, Bath and Beyond.
And that would mean the stove company would have to take responsibility for every person (pro-cook, absnt-minded senior or naive child) who forgot to take the impeller out of their food and accidentally broke a tooth - or worse. Much worse.
I can see why such a feature would not get off the drawing table.
  • Skeptical
DaveC426913 said:
responsibility
That was my first thought as well. The times we live in...
This would be "Beyond" right?
So microwaves has a rotating turntable to even out the exposure. Not exactly a stirrer, but how do you stir piza anyway?
The very idea of a pizza in a microwave gave me a problem. Isn't pizza all about a crust, for crust's sale?
:wink:
Not on its own, Nor touching the sidewalls.
Thin aluminium pie plates of metal with food in them are OK, as evident by the sale of such products as being microwave ready. I cook my fish sticks on a pie plate and it does not come out 'red' hot.
:wink:
A friend showed me this: to reheat leftover pizza, just put the slice in a large skillet on the stove. Medium low, and I like to cover it for the first few minutes. The crust comes out nice and crispy, not that flubbery microwaved bread yuck-o.
Once i made the mistake to put inside the microwave oven food wrapped up in aluminum foil. It didn't touch the walls . I literally saw plasma inside the oven and the food obviously caught fire . About the aluminium pie plates now...i'm not sure why they don't catch fire . I guess it has to do with the thickness and maybe they have also made changes to the material ?
You can't beat one of those big globe (real) filament bulbs. Firework night but only for a few seconds as the bulb gets dangerously hot.
  • Haha
Not physics, but last week I did what I should have done years ago: I took the back off of our microwave, located the piezo, and twisted it until it tore loose from the controller board. No more beep beep beep!
  • Haha
Thats kinda funny. Maybe not.
Must of scared the crap out of you. It would me!
Wrapped in foil - no way for the microwaves to get into the food. They reflect off of instead.
The pie plate has an open top, so waves can attack the food.
There is some induced current in the pie plate, but nothing I have noticed as being overly hot, actually more like as warm as the food.
They also have "browners", if that is what they are called, which has a metal surface that heats up which, if in contact with the food, is supposed to give it the baked in the stove look.
I think I have some old-style flashbulbs around here. I wonder what will happen when....
zirconium fire bad juju
You just reminded me of this :
The really funny thing is that happened during my internship which was also RF/microwaves related . So the embarrassment was double . I could be an excellent example of how to get fired in no time , lmao 🤣 . But yeah , i was lucky because i realised it almost immediately . I can't imagine what could have happened if i had just left , continuing whatever i was doing at that time . It took no more than 5-10 secs to catch fire . The smells were awful btw . The burger was okay though , after removing the burnt parts of course . And luckily i didn't die 🥲.
That's some useful piece of info , thanks . Next time i will definitely try someting like a pie plate . Doesn't it block some of the EM power though ?
That's pretty cool actually . Is there any difference to the taste of the food or is it just an aesthetic emulation of the stove look ?
Yeah. I had my back to my microwave, saw the whole room light up with the flash.
I think it as a lot to the do with the shape of the material. Pinch points (such as corners and creases) are prone to concentration of current, which is often where the flashes occur. A large surface with no corners may be less prone to having radiation focus on a small area.
I think.
Yes, it's still crunchy, a little. You're converting the radiation to heat, and drying out the surface of the food at particular points, which effectively toasts it. A little.
A small trinity test , lmao .
Oh...i believe you must be absolutely right . It didn't cross my mind but it's true , aluminum foil is full of crests , creases and corners . Large curvature means larger local electric field strength , which inevitably leads to the breakdown of air , and hence the birth of an arc/plasma .
An experiment would be interesting , and we could verify it , but on the other hand i don't want to start a fire again . I will trust theory on this one 😂.
It's a very smart trick . As long as it doesn't burn the food . But that can happen even in a regular oven if don't know what you are doing .
  • · Replies 66 ·
  • · Replies 16 ·
15K
  • · Replies 21 ·
  • · Replies 152 ·
12K
  • · Replies 16 ·
