Does Noether theorem apply to gauge symmetry?
The discussion revolves around the applicability of Noether's theorem to gauge symmetries, particularly in the context of electromagnetism and quantum field theory. Participants explore whether gauge symmetries yield conserved quantities and how they relate to global symmetries.
  • Some participants question whether Noether's theorem applies to gauge symmetries, suggesting that gauge symmetry may not be the "right type" of symmetry for this theorem.
  • Others argue that Noether's theorem can derive conserved quantities for both global and local gauge symmetries, citing examples from quantum electrodynamics (QED) and quantum chromodynamics (QCD).
  • A participant raises the issue of conserved charges in the context of a free photon field, questioning what conserved charge corresponds to gauge symmetry.
  • Some participants note that in QED without electrons, the conserved Noether charge is zero, but a local conservation law, represented by Gauss's law, still exists.
  • There is discussion about the implications of gauge symmetry in the photon sector being trivial in QED compared to non-abelian gauge symmetries in QCD.
  • Participants mention the divergence-free nature of the stress-energy tensor for the free electromagnetic field, which leads to conservation of momentum and energy, but clarify that this is not directly related to gauge symmetry.
  • Some express curiosity about the relationship between classical and quantum theories regarding gauge symmetries and constraints, referencing Dirac's work on constraint quantization.
Participants express differing views on the applicability of Noether's theorem to gauge symmetries, with some asserting its relevance while others question it. The discussion remains unresolved regarding the nature of conserved quantities associated with gauge symmetries.
Participants acknowledge that the treatment of gauge symmetries may differ from global symmetries, and there are unresolved mathematical steps and assumptions regarding the implications of gauge fixing and the relationship between classical and quantum frameworks.
Rocky Raccoon
Basically, the title says it all. I've never heard of Noether charge corresponding to gauge symmetry of the Lagrangian. Is it because gauge symmetry isn't the "right type" of symmetry (one parameter continuous symmetry) so the Noether theorem doesn't apply to it?
Electromagnetism: U(1) gauge symmetry -> conservation of charge ?
You can derive all conserved quantities of both global symmetries and local gauge symmetries using Noether's theorem. In QED you get the conserved (four-vector) current density, an equation describing the local conservation law, the charge conservation via integrating the charge density and all that.
The meaning of a gauge symmetry, how it is treated in quantization, etc. is partially different from global symmetries, but Noether's theorem works as expected.
That applies to non-abelian gauge symmetries like SU(3) in QCD as well.
I'm aware of global gauge symmetry of charged scalar, spinor, etc fields corresponding to the charge conservation. I was thinking more along the lines of free photon field - what is the conserved charge with respect to gauge symmetry?
I'm still new to all of this, but doesn't the EM field exist only as the gauge field of the charged spinor field's gauge symmetry? I didn't think you could separate it out and treat it as a free field by itself like that.
Zero! The charge is zero, but this is more complicated than it seems.
Of course there is no charge associated to photons b/c they are charge-neutral - and there is no charge associated to electrons as you decided to eliminate them :-) Therefore there is no conserved current and no conserved charge. But there is still a Gauss law which - when promoted to an operator during quantization - still acts as a generator of the local gauge symmetry.
But this is basically due to the fact that in QED w/o electrons and positrons the photon is free field. If you do the same calculation in QCD you get a conserved current which is purely gluonic.
The reason why the gauge symmetry in the photon sector is trivial in QED is that the photon field strength F_{\mu\nu} is itself invariant w.r.t. to the gauge symmetry A_{\mu} \to A_{\mu} - \partial_{\mu}\chi. This is a very special case. In QCD the gluon field strength is NOT invariant w.r.t. the gauge symmetry but transforms in the adjoint rep. Only the quadratic term in the Lagrangian is invariant.
@Chopin: of course you can study QED w/o electrons - it's a free field theory.
A free photon field exist even in the classical limit - it's the usual EM waves.
So, the conserved quantity of free EM field is zero?
The conserved quantity is electric charge. So yes, for a free EM field it is zero.
The conserved Noether charge is zero.
But for local gauge symmetries there is a quantity that is conserved locally, namely the Gauss law. In case of QED w/o electrons this is (promoted to a constraint equation acting on physical states)
\nabla E|\psi\rangle = 0
The conservation law is just
[H, \nabla E] = 0
i.e. the Gauss law operator commutes with the Hamiltonian. In that sense the globally defined Noether charge is identically zero but the gauge symmetry is still present due to the Gauss law. This is different for global symmetries as they do not have something like Gauss law.
Sure. I guess what I meant by that (but put into words poorly) is that if you're dealing only with the EM field, the gauge transformation itself becomes uninteresting, since the covariant derivative term is gone. So I guess that basically leads to what you said--the Noether current of the gauge symmetry of a free photon field results in the conservation of 0. :)
yes - it's d0/dt = 0
study QCD w/o quarks - it's fun
The stress-energy tensor (SET) for the free EM field is divergence-free (as are all physically realizable SETs), so momentum and energy are also conserved for this field. I realize this is a bit off topic, but just to be precise :smile:
correct, but the stress-energy tensor is not related to the gauge symmetry
[H, \nabla E] = 0
Might be worth mentioning that these equations hold in the "pre"-Hilbert space before gauge fixing. In the "physical" space the conservation law will be the identity operator.
I've always wondered at the back of my mind what the precise relation is between the corresponding structures in quantum theory and classical theory. I know it involves Dirac constraints, but I confess to never having fully internalised how that's supposed to work :-p Would it be fair to say that the whole tortured thing is a result of topological obstructions to constructing a decent coordinate system on the physical symplectic manifold? Such that we find it easier notationally to talk about an enlarged system and then impose the "symmetry"?
Exactly; thanks for adding this comment.
Yes; you should read the "old" Dirac papers regarding constraint quantization. It is essentially a qm framework to implement a foliation of the gauge fiber bundle.
Yes, I've tried ;-) The thing which I guess I'm not clever enough to infer, is actually the other way round. It's not so hard (conceptually) to understand the quantisation procedure and its motivations, but I wonder what it looks like going the other way: what can be said about the classical structures if you "ungauge fix" a quantum theory? Now, clearly (?) we need to be specific about what kinds of overlabelling is allowed, but a good starting point would be the usual Yang-Mills type thing. Are we always going to end up with a proper Hamiltonian formalism in the classical limit? What does the lack of a proper inner product in the pre-Hilbert space correspond to?
I suspect that it's all there already in Dirac's work, but I guess (since it's not my actual research) I'd like someone to just tell me :-)
I don't know if I get your point.
First of all these issues can be treated in different formalisms - which should be identical w.r.t. to physical results :-)
So essentially one MUST gauge fix - depending on the formalism in different ways and due to different reasons. In the canonical formalism gauge fixing is required in order to have a physical Hilbert space w/o negative norm states (one can try to work with negative norm states as well - Gupta-Bleuler-formalism - but in the end again the unphys. d.o.f. must cancel; in addition this formalism does not work for non-abelian gauge theories). In the PI formalism one must gauge fix as otherwise one integrates not only over physically different paths but over gauge-copies which leads to a divergent PI b/c each physical paths appears in infinite number of times due to gauge-copies.
Gauge fixing in the canonical formalism is essentially described by Dirac; gauge fixing in the PI formalism uses Fadeev-Popov ghosts (killng unphysical d.o.f.) or the more sophisticated (but related) BRST invariance. In the very end the gauge d.o.f. are removed / canceled / ... w/o breaking gauge invariance
There is a simple analogy for a two-particle system with translational invariance and interaction V(|x-y|). Going to the c.o.m frame means to use p (rel. mom.) and P (c.o.m. mom.). "Gauge fixing" now means setting P=0 (or in QM P|phys>=0) i.e. looking at the rel. momentum p in the c.o.m. frame. Of course this does not break translational invariance but it reduces the physical space to states with vanishing P (all other states are still there in the larger Hilbert space but we are clever enough to project them away).
The difference between gauge fixing classically and quantum mechanically is not that we do not gauge-fix but that the details of the implementationa re different. This is most clearly seen in the canonical approach as one can relate both the classical and the qm case
{.,.} => [,.]; Poisson bracket => commutator
H => H; Hamiltonian (function) => Hamiltonian (operator)
C=0 => C~0; C|phys>=0; constraint => constraint acting an states; kernel = phys states
K => U; canonical transformation => unitary gauge fixing transformation
(in the exmaple above this transforms from the two coordinates describing the two particles to the c.o.m. frame)
Your sentence "Are we always going to end up with a proper Hamiltonian formalism in the classical limit?" is misleading. The proper Hamiltonian is constructed both in the classicasl and in the qm case and has nothing to do with the classical limit.
Of course one can work in an unphysical Hilbert space as well, but one has to use other mechanisms to cancel the unphysical d.o.f. The Fadeev-Popov ghosts do something like that; they cancel certain contributions coming from unphysical gluons.
There is one major benefit in fxing the gauge (such that it becomes the identity in the physical subspace): After gauge fixing you can use any approx. you like w/o ever violating gauge symm. Dealing with a larger Hilbert space is risky as an approx. my break gauge inv. which typically kills the consistency!
http://www.osti.gov/bridge/servlets/purl/6129984-GWXEJY/6129984.pdf
The conserved charge in local gauge theories is not truly conserved. But local gauge symmetry is unphysical and has to be removed (gauge fixed), unlike global gauge symmetry. This "fixes" the local gauge charge into the a conserved charge (similar to global gauge charge). I have also be told that Noether's second theorem is related to all this - but I never got to read and understand it.
nice paper; but note that it uses BRST and not Dirac
  • · Replies 47 ·
