Does non-locality threaten spacetime if the wave function is physical?
  • Level: Graduate
  • Thread starter Thread starter stglyde
    Non-locality Spacetime
60 replies · 12K views
Ken G said:
Indeed, I find it curious how often that basic assumption is made-- that consciousness (or any aspect of reality) arises from the laws of physics. To me, that is essentially backward thinking-- it must instead be true that the laws of physics arise from consciousness (and any other aspects of reality). In other words, laws explain phenomena, but they don't create or cause phenomena, because laws are inside our heads. To hold that laws create reality, or that reality arises from laws (including consciousness), is essentially the philosophy of "idealism", where reality is subordinate to our minds. Yet most physicists claim to be realists, who hold that our minds are subordinate to reality. So it would be a fundamental mistake to place the laws in the reality rather than the place where they demonstrably exist-- in our minds. This point gets underscored every time a well-loved set of "laws" gets replaced by some new one!
The connection to x,t in quantum mechanics is that these parameters have to be connected to observations to be useful, and observations require participation by our minds to decide what constitutes an x measurement or a t measurement. The laws of physics escape the need to have clear definitions of what x or t are, we just know how to use these concepts correctly in our theory. That's an aspect that is not strictly related to pime or pace.
Ken, Can you please critique the following concepts made by Demystifier regard nonlocality and the its compatibility with the minkowski metric structure (do you believe they are compatible?). These are taken partially from from a June 2010 thread exchange between Demystifier and Maaneli in the thread "Re: Pilot wave theory, fundamental forces" at https://www.physicsforums.com/showthread.php?t=366994&page=6. Please see attached paper shared by Demystifier in that thread for summary of the ideas.
Maaneli: the relativity of simultaneity is nevertheless a consequence of the metrical structure of Minkowski spacetime
Demystifier: No, this is not true. What is true is that the metrical structure of Minkowski spacetime implies relativity of simultaneity IF THERE IS NO ANY OTHER STRUCTURE. But in the case we are considering there is another structure. And this additional structure is not the parameter s (as you might naively think), but the non-local wave function. (Or the scalar potential in the classical setting discussed in http://xxx.lanl.gov/abs/1006.1986.)
And yet, you can see that this nonlocal wave function (or the scalar potential) is compatible with the metrical structure of Minkowski spacetime and does not introduce a foliation-like structure.
So, does it mean that you agree that WITH example of my theory there IS a known dynamical structure that is consistent with the metrical structure of Minkowski spacetime, and yet violates the relativity of simultaneity?
By the way, one can introduce such a structure even in classical local relativistic mechanics. Consider two twins who initially have the same velocity and same position, and their clocks show the same time. After that, they split apart, and each has a different trajectory, independent of each other. Yet, one can consider pairs of points on two trajectories which have THE SAME VALUE OF PROPER TIME (showed by a local clock on each trajectory). Such a structure (defined at least mathematically, if not experimentally) also can be said to violate relativity of simultaneity, in a way very similar to that of my theory. Of course, there is a difference, but the similarity may be illuminating too.
Demystifier: Or let me use an analogy with nonrelativistic BM. A point is space is denoted as [tex]r=(x,y,z)[/tex]. Consider two particles with space positions [tex]{\bf r}_1[/tex] and [tex]{\bf r}_2[/tex] at a given time [tex]t[/tex]. There is a Cartesian frame (given by a rotation of the original Cartesian frame) in which [tex]{\bf r}_1[/tex] and [tex]{\bf r}_2[/tex] have the same value of [tex]z[/tex]. In this frame, we say that the interaction between these two particles is z-taneous. Does it lead to any paradoxes? Does it mean there is a preferred z-coordinate? Does it mean there is a preferred foliation of space into 2-surfaces? Whatever your answer is, the same answer applies to analogous questions in relativistic-covariant BM. And if you still don't get it, then look at the equations of relativistic-covariant BM again.
Maaneli: ... by virtue of the fact that you have to synchronize the initial (spacetime) positions of the particles at a common time s,
Demystifier: The parameter s is not time.
Maaneli: But as a "joint parameter", it plays precisely the role of a universal time parameter for the evolution of the particle spacetime coordinates. Yes, I realize that the wavefunction on configuration spacetime doesn't depend on s, but that doesn't mean that s cannot also be interpreted as a time parameter (even if it is a fictitious one).
Demystifier: You are right. The parameter s can be interpreted as a sort of time. However, this is more like Newton absolute time, note like Einstein relativistic time [which I already implied by saying it is a UNIVERSAL time parameter]. OK, that's clear enough. And you are right, nonlocal signaling violates the relativity of simultaneity. Yet, in the next post I explain why it is NOT in contradiction with metrical structure of Minkowski spacetime.
(Maaneli in other message mentioned Nikolic theory has preferred foliation like structure)
Demystifer: No, there is no foliation-like structure. The synchronization parameter is NOT something additional to the SR metrical structure, just as time in nonrelativistic BM is NOT something additional to the 3-space rotational-symmetry structure.
My point is that relativistic-covariant BM in 4-dimensional spacetime is ANALOGOUS to nonrelativistic BM in 3-dimensional space. I am just trying to make you understand this ANALOGY, because when you do, you will suddenly say: "Oh, THAT is what you meant. Now I get it. In fact, it is trivial." But it is essential that you see this analogy by yourself, while I can only guide you in the right direction. And at the moment, it seems to me that you don't have a clue what I am talking about, because you are not able to see the analogy. And that is probably because you are unable to think of time as just another "space" coordinate.
To help you think in the correct way, let me suggest you a mental trick. For a moment, FORGET that the spacetime metric has the form (+---). Instead , think of metric as just any metric, which can be (++++), (++--), or whatever. In fact, simply don't think about metric at all. Just pretend that you have a 4-dimensional space with some unspecified metric. Or if it is easier for you, just pretend that the metric is (++++). And forget that one of the coordinates is called "time". (Who cares about names, anyway?) And NOW try to understand again what equations of relativistic-covariant BM are actually saying. This trick works for many physicists, so it could work for you as well.
(Note: the last exchange between Demystifer and Maaneli occurred in Jun 22, 2010)
Maaneli: Of course, by covariant, you must mean "fundamentally covariant", because anyone can construct a covariant particle dynamics on a preferred foliation. I think it might be best for us to resume our discussion on the old thread, "Pilot waves, fundamental forces, etc.", regarding whether your proposal of using a synchronization parameter and treating time and space on equal footing is truly fundamentally covariant or not, and whether or not it does have the condition of equivariance. We never got to finish that discussion, mainly because I became too overwhelmed with deadlines and work and kept forgetting to reply to the thread. My apologies about that.
Demystifier: I would like to continue the discussion there. But I will wait for your first step.
(But they never continued. And since June, 2010. There is no other challenger to Demystifier. And he continued to share his papers which are referenced in peer reviewed journals but unfortunately, no one read it much. Therefore let us continue and settle it once and for all whether Demystifier is fundamentally correct.)
References:
http://xxx.lanl.gov/PS_cache/arxiv/pdf/1002/1002.3226v2.pdf
http://xxx.lanl.gov/PS_cache/arxiv/pdf/1007/1007.4946v1.pdf (see section 2.1)
I'm not enough of an expert to be brought up to speed on the details of the argument without investing a lot of time, but I can give my general impressions:
1) I don't see why Bohmian nonlocality contradicts relativity, unless there is something "more nonlocal" in Bohmian mechanics than what is already in the predictions of quantum mechanics. I wouldn't expect that to be true, for as near as I can tell, BM is constructed to make all the same predictions as quantum mechanics in the same types of idealized situations in which physics is generally applicable. Extending BM to relativistic quantum mechanics should not be any harder than so extending any of the other interpretations.
2) In my opinion, strict global simultaneity is always a coordinate issue, which is never demonstrably essential to any of the physics. Demystifier seems to be advocating a coordinate s which is to be viewed as a physically real version of global simultaneity. I don't think it is wrong to inject a concept of global simultaneity into one's interpretation of physics, but I do think it is unnecessary to do so. That is my general beef against Bohmian approaches: they are invariably rife with unnecessary injections that allow a particular view of how reality works to be maintained, when it seems more natural to me to not cling to any preconceptions about how reality behaves and just let it teach us its lessons. To me, one key lesson of relativity is that there simply is no such thing as absolute global simultaneity, that is merely mistaking a subjective coordinate for something objectively real. But that doesn't make it wrong to interpret global simultaneity, any more than the standard rejection of preferred reference frames makes the aether wrong. For example, it is actually not a principle of relativity that there must be no preferred reference frames, it is merely a principle that there be no requirement for a preferred reference frame. The requirement refers to the theory itself, not any given interpretation of that theory. It is not at all uncommon for intepretations to create elements that are not required in the theory-- for example, most interpretations of Newtonian mechanics create a concept of a force, yet other interpretations (like the principle of least action) require no such ontological entities as forces. I view all ontology as the arena of interpretation, not of physical theory itself. For the theories themselves, the only ontology is the epistemology-- what exists is the theory, and all its interpretaitons, and their value to us. It is only in the interpretations that we encounter the various ontologies, and we need not expect them to be unique.
3) So I'm generally sympathetic to Demystifier's position that relativity does not refute BM. I view BM as a way to allow classical notions like trajectories and global simultaneity to survive quantum mechanics, just as Lorentz aether theory was a way to let those notions survive relativity. I just don't see the point in doing that-- but it doesn't make it wrong. It's important to recognize the difference between what is ruled out by observation, and what is simply regarded as a preferred lesson of the observations. Demystifier is arguing that BM need not be ruled out by the observations that support the need for a covariant formulation of quantum mechanics, and I can find no flaw in that position, though Maaneli may be seeing deeper than I am.
Thanks.. I'll reflect on what you said. For now I have only one question (at the bottom sentence).
Nikolic mentioned in the attached paper in my prior message:
"1.1 Relativistic Bohmian interpretation
- Nonlocality in BM requires superluminal (faster than light)
communication between particles.
- The most frequent argument that it is not compatible with relativity:
Superluminal communication
⇒ there is a Lorentz frame in which communication is instantaneous
⇒ there is a preferred Lorentz frame
⇒ the principle of relativity is violated.
- However, this is not a valid argument, because
this is like using the following argument on subluminal communication:
Subluminal communication
⇒ there is a Lorentz frame in which particle is at rest
The argument on subluminal communication is wrong:
- It is the general law of motion that must have the same form
in any Lorentz frame.
- A particular solution (a particle at rest with respect to some particular
Lorentz frame) does not need to have the same form
in all Lorentz frames.
But the argument on superluminal communication is
completely analogous.
⇒ It is wrong for exactly the same reason:
- A particular solution (communication instantaneous with respect to
some particular Lorentz frame) does not need to have the same form
This analogy works if one exchanges the roles of time and space."
My only question is how come this analogy only works if one exchanges the roles of time and space? If you don't know, Hope Nikolic himself can share. Thanks.
I'm not sure about the point of exchanging time and space either, but it seems to me that Demystifier is making a fairly simple argument that instantaneous communication is not ruled out by relativity as long as no FTL information can be extracted from that "communication," analagous to how phase velocity can be > c as long as group velocity is < c. This is commonplace, even Feynman path integrals include processes that one might regard as FTL "communication" if one wanted, but the point is, at the end of the calculation when all the amplitudes are added up, there can be no transfer of classical information that is FTL. This can be viewed as a kind of explanation for the principle of least action-- the path of least action is the path of constructive interference, so what actually happens emerges from a sea of possibilities that we don't expect to happen. Relativity is only about what actually happens, not about the sea of possibilities we include in our interpretation of what actually happens.
But this brings up a different problem for BM, which I think is a valid criticism of it. There is no need to interpret quantum mechanical nonlocality as a form of FTL communication between parts, because parts don't communicate-- intelligences do. So adopting the term "communication" here is just an awkward anthropomorphism. Nor should we say that parts "influence" other parts, because if the message is that QM is nonlocal, then I say we should ditch the whole concept of "local parts" that could "communicate" with each other in the first place, and simply talk about the complete system as if it was a whole, not a bunch of entangled parts. But again, this doesn't mean BM is wrong, it just means it may miss a key lesson of QM, choosing to instead replace that new lesson with old lessons from classical thinking. But whether or not this is actually a good or bad thing to do depends more on the next theory that we don't have yet, than it does on either quantum mechanics or relativity.
I've spent about 4 hours now just reading and rereading the old thread between Demystifer and Manelli and I think I can see it clearer now (we need to scrutinize Demystifier approach so that we can become conversant in dealing with exotic spacetime formulation in our search for ultimate physics of Quantum Gravity). The following message tells about Demystifier position that his theory is not lorentz invariance as we and Maudlin understood it.
message #78 of https://www.physicsforums.com/showthread.php?t=366994&page=5
Maaneli, you are correct that I use a different definition of "fundamental" Lorentz invariance than you (and Maudlin) do. Let me refer to this (your and Maudlin's) definition as CAUSAL Lorentz invariance.
You are also correct that my theory is not causal Lorentz invariant.
However, my point is that I do not see any particular motivation for retaining causal Lorentz invariance. For me, the only reason why I want Lorentz invariance is SYMMETRY, so for me the covariance with respect to coordinate transformations and the absence of a preferred frame is enough. Let me refer to it as SYMMETRY Lorentz invariance.
Let us also not use the unfair and vague expression "fundamental" Lorentz invariance any more.
Now let me answer you questions, having the definitions above in mind.
"So will the superluminal signaling occur along all of those hypersurfaces?"
- Yes.
"And would you still regard superluminal signaling in your theory as consistent with your definition of fundamental Lorentz invariance?"
- I would regard it consistent with symmetry Lorentz invariance.
Now in other message in that thread. Demystifier admitted that his theory depended wholly on making space and time equal. Therefore if we can argue correctly that it isn't so. Then his whole castle collapses.
Demystifer. First please explain why your example of subluminal and superluminal and how "a particular solution does not need to have the same form in all Lorentz frames" statement has everything to do with exchanging space and time. Me and Ken (perhaps) still don't understand this, so please explain. Thanks.
What I'd like to know is whether Demystifier is claiming that treating x and t symmetrically results in a theory that says it is possible to send classical information superluminally. Since there is no experimental evidence that this is possible, that would sound like going too far to treat x and t symmetrically. After all, the main reason for treating x and t symmetrically, despite our experience to the contrary, is that doing so supports the concept of a universal speed limit. Remove that constraint, and much of the reason to want to treat x and t symmetrically also vanishes. I'm not one of those who believes that we should embed symmetries into our theories even if nature does not give us reason to, just for the sake of having a more symmetric theory. Symmetry is often associated with parsimony, but there is more than just Occam's Razor to think about when constructing theories, there are also advantages to theories that support interpretations that retain our general experiential notions.
The argument compares two very similar arguments, one referring to a superluminal velocity
dx/dt > 1 .. (1)
the other to a subluminal velocity
dx/dt < 1 .. (2)
But note that (1) can be written as
dt/dx < 1 .. (1')
while (2) can be written as
dt/dx > 1 .. (2')
So, if we exchange the roles of space and time, i.e., if we interpret t as "space" and x as "time", then it is natural to define the velocity as dt/dx, rather than dx/dt. In this way (1') is interpreted as "subluminal" velocity, while (2') is interpreted as "superluminal" velocity. In other words, by exchanging the roles of space and time, subluminal velocities transform to superluminal velocities, and vice versa. Thus, if space and time are treated on an equal footing, then their exchange should be allowed, and then there is no fundamental difference between superluminal and subluminal velocities. In particular, if subluminal velocities are compatible with relativity, then so are superluminal ones.
I hope it's clearer now.
I would put it this way. If x and t are treated symmetrically, then there is nothing paradoxical about sending classical information superluminally. But it does not yet mean that sending classical information superluminally is possible. We apparently cannot send classical information superluminally because the dynamics is described by a particular Lagrangian which does not allow that. If the dynamics has been described by a somewhat different relativistic-covariant Lagrangian as in
then sending classical information superluminally would be possible.
dx/dt > 1 .. (1)
dx/dt < 1 .. (2)
dt/dx < 1 .. (1')
dt/dx > 1 .. (2')
Ok, clearer now. But you also give as one of the conditions that there should be no free will. Why. Why would your model collapse if there is free will? And what is the relation of free will to treating space and time as equal and these views seemingly dependent on each other? Maybe something to do with the fact that you believe in block spacetime and nothing can ever influence it. Everything is already written from past to future? This is what can falsify your theory. We don't have to discuss what is free will (to avoid off topic and it's not necessary), but the fact whether there is free will or not can either vadliate or invalidate your theory right?
So 50 yeasr from now. If it would be proven there was really free will, then your model completely collapse.
I have explained it in the paper, but let me repeat. If one has free will, then one can choose to send a signal one wishes to. But in my theory, that signal may travel faster than light. This means that a signal can be sent to the past. But sending a signal to the past one wishes to may be logically inconsistent (grandfather paradox).
If free will would be proven to exist, then all currently known fundamental physical theories, either deterministic or probabilistic, would collapse. That's because free will is incompatible with fundamental deterministic laws, as well as with fundamental probabilistic laws.
But it's easy to get over it. Whenever free will was used, then Preferred Foliation (Maudlin context) is invoked. There you won't have any grandfather paradox. What's so difficult about this? Note Preferred Foliation is even simpler or equally likely than your treating space and time as equal. Or you can have them both anyway with preferred foliation only used for free will.
Yes, that's also a logical possibility, but I wouldn't call it "simpler" or "equally likely".
How come in Copenhagen, free will can coexist with nonlocal correlations such that the randomness can't be used to send information because quantum randomness doesn't have order. Yet in Bohmian, nonlocal correlations automatically can be used to send information and cause causality paradox. Remember it is the wave function that do the trick in both so why can't we say the wave function in bohmian acts like in Copenhagen preventing the sending of sginal. I can't quite verbalize it although the reason is just on the surface of my mind. When mentioning Bohmian, please specify whether you are talking of old fashioned BM or your BM.
Oh I think I remember. Copenhagen has randomness scrambler built in so Alice and Bob wouldn't know what is really sent. So you mean if Bohmian would have randomness scrambler added, then will free and nonlocality won't imply sending information, agree with these arguments?
Oh I remember the contextuality part. In Copenhagen, in the absence of measurement to measure its position, the particle has no position.. so with randomness scrambler built in, there was no way to affect the past because the past won't know what to measure. In Bohmian, a particle always has position, so even if you send random 1 and 0 nonlocally and superluminal, it can still affect the past by the value regardless of 1 or 0 existing... but note this only occurs in a relativistic BM. But convensional BM has no relativistic counterpart (except yours) so this causality won't even be a problem because convensional BM uses Newtonian spacetime.
Now in your time and space equal formulation of BM which you made relativistic. You have to invoke it to avoid causality effect. But you have do away with free will.
Is is impossible to create relativistic BM (with changing reference frame) without using any of your device of treating space and time as equal?
The usual statement made about relativity is not that superluminal velocities are categorically impossible, but rather that crossing from subluminal to superluminal is impossible. So if there was some population of superluminal particles (tachyons), they would always be superluminal. This preserves the symmetry, yet still holds that superluminal communication is impossible, unless you get access to tachyons. So that doesn't refute BM, because BM can invoke some tachyon-like connection and still be consistent with relativity, but it's not clear that invoking new physics is justified simply to allow BM to give a consistent rendition of what is happening.
Not to get the thread too embroiled in free will, but I should point out that I can think of at least two ways that free will is not challenged by any highly successful deterministic (or random, for that matter) theory of physics:
1) physics theories are used by intelligences to understand reality, but the understanding it generates is never complete. If we observe something that we don't understand, and other things that we do understand, we do not say that the things we do understand make impossible those we don't. The only solid definition of an "illusion" is something that can be better understood in a different way, not something that simply isn't understood at all. Arguments that successful deterministic theories require a self-delusion of free will do not offer us any better understanding of delusions of free will than they do of actual free will.
2) the nature of free will is not well defined, and certain versions of the concept are fully compatible with determinism. Determinism is about predictability, and free will can be viewed as being about the absence of constraints that would tend to influence an agent to feel forced to do something against their nature. That is certainly close to the legal definition of someone's "will", after all. In those terms, anyone who argues that deterministic theories preclude free will is arguing that people being allowed to act according to their nature must not have free will if their nature is predictable. That argument does not follow, because if someone's behavior is predictable based on their nature, and they are allowed to perform according to their nature, then we can say that acting according to their nature is what acting according to free will is actually about.
Personally, I hold to the first argument of those, so find the second argument to be unnecessary. I think we don't know enough about free will to even give it a definition that makes any contact with fundamental physics at all.
Perhaps it is, but probably not in such a simple (whatever that means) way.
That's true if the mass of the particle is constant. But if mass can change, or more precisely if the sign of m^2 can change, then the particle can change its velocity from a subluminal to a superluminal one. See
Ken G said:
... but it's not clear that invoking new physics is justified simply to allow BM to give a consistent rendition of what is happening.
Quite the opposite, I think it is more than justified to introduce some new physics in order to explain what is happening behind the standard "shut up and calculate" rules of QM.
Here's the problem of normal matters using tachyons and sending them which not even be possible.. anyone know any workaround for it?
By PeterDonis:
Well, there's the obvious point that the theory would violate Lorentz invariance. You would also have to work out whether it is even possible for your version of tachyons to interact with ordinary matter, and if so how. Theorists have tried to construct theories of tachyons and have found issues with doing that; for example, the straightforward way of constructing a theory of tachyons interacting with normal matter violates conservation of energy. Also, when you start bringing in quantum field theory, it turns out that you can't really use tachyons to transmit information faster than light anyway; in other words, a quantum field theory that would allow a "tachyon pistol" is not really possible. See here:
http://www.desy.de/user/projects/Physics/ParticleAndNuclear/tachyons.html
I don't know whether an "aether" theory of tachyons could overcome the above issues, because if tachyons interact with normal matter, the interaction has to be Lorentz invariant even if the tachyons by themselves could violate Lorentz invariance (because normal matter is still Lorentz invariant, at least to a very good approximation).
Fair enough, but what your paper essentially does is group together all the new physics that one would need to form a Bohmian view that is consistent with relativity. The new physics includes things like scalar potentials, absolute simultaneity, and superluminal communication. I don't dispute the value in being able to notice the possible self-consistent groupings, but I do question whether it can be claimed that a superior interpretation of existing physics appears by introducing new physics. To me, the value of an interpretation is twofold, but both are essentially subjective. First of all, an interpretation helps us understand the theories we have now, but different physicists may prefer to understand in different ways. Secondly, they can help lead to the discovery of new physics, and this is a fine thing to use BM for, but it is not a particularly strong argument for the value of BM in regard to the existing physics, as it is basically anybody's guess how the new physics will shake out (that's the subjective part-- where one wishes to devote their resources). I see all the new physics that BM needs as a problem for using it with current physics, but I also see it as a valuable contribution for getting a "heads up" toward possible new directions. These are two rather different uses for interpretations, and sometimes that landscape can get a bit confusing when various different threads overlap.
The problem with introducing new physics is that it steps on the distinctions between theories and interpretations of theories. BM seems to suffer from this a lot-- it cannot decide if it is just trying to be one valid way to frame existing QM, or if it is trying to assert the existence of new physics that we should be designing experiments to look for. Either is a valid course, but confusing the two isn't, because they must be judged in very different ways. Pure interpretations of QM must be judged on essentially philosophical grounds, like Occam's razor and connecting with what is already understood and so on (which can be very different for different people, who already understand different things). New theories must be judged in the time-honored way: by support from observational evidence.
Towards the end of http://www.desy.de/user/projects/Physics/ParticleAndNuclear/tachyons.html it is mentioned:
"The bottom line is that you can't use tachyons to send information faster than the speed of light from one place to another. Doing so would require creating a message encoded some way in a localized tachyon field, and sending it off at superluminal speed toward the intended receiver. But as we have seen you can't have it both ways: localized tachyon disturbances are subluminal and superluminal disturbances are nonlocal."
Demystifier has *really* solved this problem as well?
This refers to classical tachyonic FIELDS (i.e., extended objects), while ...
... my tachyonic paper mentioned in #49 is about classical tachyonic PARTICLES (i.e., pointlike objects).
Note also that in the Bohmian case (Sec. 5 of that paper), a particle which may become tachyonic at some regions of spacetime is guided by a non-tachyonic "field" (wave function).
How many are working on relativistic BM without making space and time equal and how are they progressing now? If absolutely no progress (except yours). Why do many physicists give high hope to BM when it can't be made relativistic. And what are the exact arguments why they have difficulty making it relativistic (that is, by making time as coordinate and not parameter as in Newtonian). Here let's mention standard BM versions that doesn't include yours for sake of discussions.
stglyde said:
How many are working on relativistic BM without making space and time equal ...
A few.
stglyde said:
... and how are they progressing now?
There is some progress proportional to the number of people doing it. Since that number is not big, the progress is also not very spectacular.
People have different temperaments. Some are introvert, extrovert, artistic, thinker (logic or left brained), feeler (or right brain), and I guess this has to do with their choosing different interpretations. The thinker choosing Copenhagen because they simply want to think in terms of equations. The extrovert choosing Bohmian because it is like arts, you can imagine things and the maybe the introvert Many Worlds.
About support from observational evidence. Yes what can set them apart or nail the right one is a unique prediction that only one of them can make. Is this possible? Yes.
But then physics is also about belief and holding on to current consensus. In the 15th century. Discussion of anything physics can get one burnt at stake. So deep is the damage that it has affected us profoundly in an unconscious way, because now centuries later we have to to do the opposite, accept wholly that everything is explainable by physics and anything outside it doesn't exist.
I'll give a clue what it is. If I mention the name. It can trigger primal unconscious chord and cause some sort of uncomfortableness in physicists. I'll mention the word now anyway. It's "consciousness". Due to the deep pain suffered in the 15th century. Physicists avoid it like plague. But another reason is that they think consciousness function in the levels of cells and neurons and nothing below. And it is a good deduction to make.
What we have is some kind of catch 99. We don't know the new physics below. We use that fact to argue consciousness work in the level of neurons and cells because there is no new physics below (except by those who consider something akin to Penrose-Hameroff Microtubules and Objective Collapse).
Is there none? We can't discount anything yet. But physicists are more comfortable thinking of billions and billions galaxies were once the size of a hydrogen proton than thinking about consciousness and what form and level it may take below the metric (of the mind).
In addition to consciousness. There is something else. But mere mentioning the other word can make it banned and message deleted so I'll not mention the word. A century ago, any discussion about Many Worlds can make one be put in mental institutions, now it's a bit more humane, one is simply isolated.
You may not have a clue what I'm talking about Ken. Because the word is censored.. in spite of it having evidence and can make one nail the right interpretation or rather new physics. Also if you continue to discuss on this level. This thread would even be locked so let's not talk about it and just put it under the rag.
At this point in time. Officially we can't distinguish what is the right interpretation or rather new physics because of this lack of deeper and multi disciplinary explorations.
I'm not sure I agree about that. The problem is that many scientists argue that there's no hint of how one can get subjectivity/qualia/consciousness out a complex network of neural connections, etc. The gap between mind (the 'mental') and neurons (the 'material') (as presently understood) seems immense. They just don't seem to mesh. Consciousness seems to "provide us with a kind of ‘window’ on to our brain, making possible a transparent grasp of a tiny corner of a materiality that is in general opaque to us" but we haven't the slightest clue of how to mesh it together with what we presently call "matter". I found this Lockwood passage interesting:
Do we therefore have no genuine knowledge of the intrinsic character of the physical world? So it might seem. But, according to the line of thought I am now pursuing, we do, in a very limited way, have access to content in the material world as opposed merely to abstract casual structure, since there is a corner of the physical world that we know, not merely by inference from the deliverances of our five sense, but because we are that corner. It is the bit within our skulls, which we know by introspection. In being aware, for example, of the qualia that seemed so troublesome for the materialist, we glimpse the intrinsic nature of what, concretely, realizes the formal structure that a correct physics would attribute to the matter of our brains. In awareness, we are, so to speak, getting an insider's look at our own brain activity.
http://plato.stanford.edu/entries/neutral-monism/#7.2
Others argue that it's quite possible that our current "core" notions of "matter" (physics) may require revision to allow unification of the mental with the physical. Others argue that the problem may be intractable because of our own cognitive limitations. Maybe the problem of consciousness has its source as some special feature of consciousness, itself. By having this special access (inner experience) to it that we have to nothing else (and nothing else to us), this may not allow us to see the connection?
bohm2 said:
The problem is that many sciemtists argue that there's no hint of how one can get subjectivity/qualia/consciousness out a complex network of neural connections, etc. The gap between mind (the 'mental') and neurons (the 'material') (as presently understood) seems immense. They just don't seem to mesh. Consciousness seems to "provide us with a kind of ‘window’ on to our brain, making possible a transparent grasp of a tiny corner of a materiality that is in general opaque to us" but we haven't the slightest clue of how to mesh it together with what we presently call "matter".
But unfortunately. Only 1% of physicists are aware of the above. Those who are not aware just censor anything that mentions that it thinking "how medieval!".
And that is the problem we are having now. Those who have access to high tech instruments like particle accelerators or SQUID or other million dollar equipment are of the 99% variety. For example Lisa Randall and Stephen Hawking are sure the mind works in the levels of cells and neurons and nothing more.
In the mind lies the key to the next physics. But I can't continue more lest this thread be locked.
Not to get too far off track, but I would say that the "problem of consciousness" is that we don't have a scientifically framed hypothesis about what the problem of consciousness actually is. One might argue that there is a hypothesis that consciousness can be reduced entirely to the physical action of the brain tissue, but this isn't a scientific hypothesis, because it doesn't suggest an experiment that comes out A if the hypothesis is true, or B if it isn't. What does an experiment look like that refutes the claim that consciousness can be reduced entirely to the physical action of brain tissue? We need a better question than that, something that actually tells us something about consciousness.
