Does observing a particle require hitting it with another particle?
8 replies · 2K views
silvercats
So if we "look" at a particle, then its wave function collapses. Does "look" mean, hitting that particle with another particle (a light particle?). A simple Yes/No answers first please. I mean, does its wave function collapse because we first need to hit that particle with an electron or a proton first, to observe it? not because it "knows" that we observe it?
It cannot be a simple Yes/No answer. The wave function collapses when you get a measurement outcome, ie. a definite result, which is an "irreversible" "classical" or "macroscopic" mark. Whether you get a definite result is up to you to decide. You can delegate it to a machine, but you have to do the delegation. This is the "observer effect" and or the "Heisenberg cut", and is part of the orthodox Copenhagen-style interpretation of QM.
However, you should also note that in that interpretation, the wave function is just a tool to calculate the probabilities of measurement outcomes.
A few comments.
First collapse isn't actually part of QM - its part of some interpretations - but others like Bohmian Mechanics don't have it. There days the modern version is how does an improper mixed state become a proper one - colloquially its why we get any outcomes at all:
http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf
Look does not mean that. Look means interacting with the system to produce decoherence.
Thanks
Bill
atyy said:
get a measurement
how do we "Get a measurement"?
Simpler the answer the better.
How do we INTERACT?
silvercats said:
How do we INTERACT?
Its the other way around in general - how do we not interact.
In the everyday world systems are immersed in an environment they interact with all the time - in fact that's what gives things its classical properties. For example a few stray photons from the CBMR are enough to decohere a dust particle and give it a specific location. It turns out most interactions are of the radial type so that, for example, the closer two objects get the stronger the force they feel. Mathematically they have what's called an interaction Hamiltonian.
Thanks
Bill
So am I correct If I tell that the reason for the wave function to collapse is this "interaction Hamiltonian" ?
Its a bit more subtle than that.
As I said before collapse isn't really part of QM - only part of some interpretations.
And secondly interaction (represented mathematically by the Hamiltonian) only explains what is called apparent collapse.
But, basically, with those caveats, yes.
Thanks
Bill
QM does not answer. You have to know when you get a measurement outcome.
Only a deeper theory like Bohmian Mechanics can answer such a question.
