Does physics forbid such a device; a heat destroyer
  • Context: Graduate
  • Thread starter Thread starter Deeviant
    Device Heat Physics
The discussion centers on the feasibility of a "heat destroyer" device that converts heat into another form of energy, such as electricity, without requiring additional energy input. Participants reference the second law of thermodynamics, which states that it is impossible to convert heat from a single reservoir into work without an additional energy source. They emphasize that while systems can approach absolute zero, achieving it requires infinite energy. The concept of negative temperature is introduced as a theoretical possibility, but its practical application is limited to specific systems.
  • Understanding of the second law of thermodynamics
  • Familiarity with heat engines and their efficiency limits
  • Knowledge of negative temperature systems
  • Basic principles of energy conversion and losses in physical systems
  • Research the second law of thermodynamics and its implications for energy conversion
  • Explore the concept of negative temperatures and their applications in physics
  • Investigate current technologies for heat energy conversion, such as thermoelectric generators
  • Examine the limitations of heat pumps and refrigeration cycles in energy transfer
Writers of science fiction, physicists, engineers, and anyone interested in the principles of thermodynamics and energy conversion technologies.
  • #91
Deeviant said:
There is no material that can successful absorb the energy of a .99 C projectile of any significant mass ... To put it into perspective, a 1 kilogram projectile traveling at .99 C represents 10.52 MEGATONS of energy, there is NO material conceivable that will be able to withstand that much energy.
I said you don't have to absorb all of it. If it breaks up when it hits something floating in space (not attached to your ship) made of the same material as it, it doesn't matter as much.
Your idea of some sort of "decoupled" armor is laughable, you'd have to know where I am in order to put it "in line" with my attack vector;
Put it all around like a cage. I found some photos down the bottom of the modern version of this. It is not decoupled from the vehicle but that is the tech advancement I was proposing for "space wars". A little drone computer to control a bunch of metal plates with engines. Or you can electromagnet them? BTW I know this doesn't stop hard rounds (it's for RPG and other "plasma jet" weapons - don't know if a physict would call it a plasma, but it is a jet of hot, vapourised metal), but that's the not point: the point is "it's a cage" and it's a cage because they can't predict which side will get shot at.
http://farm1.static.flickr.com/137/407807009_84d10d122f.jpg
http://media.defenseindustrydaily.com/images/LAND_RG-31_LROD_Armor_lg.jpg
It's strange that you basically said I was wrong, then agreed with me; "The defence there is the same as it probably always will be, use decoys, maneuver erratically and use stealth".
No you said stealth was the ONLY defence. That's not identical to what I said.
As for you WWII in space, that is exactly what I foresee; a scenario similar to WWII submarine warefare.
Getting off topic here, but I don't agree there either: WW2 submarines preferred to attack while surfaced and in most cases weren't able to fight a warship - they were typically sent after mechants instead.
Science news on Phys.org
  • #92
Drakkith said:
Perhaps, but there is no way to accelerate a 1 kg mass to 0.9999c using a single launcher either. It require extremely hard acceleration for a very long period of time to get up to speed using a propulsion system. It takes the LHC almost an hour to accelerate protons up to their top speed, and this is using multiple stages of circular accelerators that are kilometers long, and you're talking about something many orders of magnitude larger. It isn't feasible at all.
To be honest, an engineering problem is exactly what it is. Given a few thousand years, I think it would be foolish to say that any complex engineering problem could not be solved. In the end though, it doesn't matter. It could simply be a gamma laser. Anything armoring that would defend against a laser, would make it less stealthy. The bottle line is a ship is going to have to contend with relativistic weaponry.
As I already said, the amount of energy released by a host of possible future space weapons is far too great for a material based armor approach. Stealth IS the only defense.
  • #93
An engineering problem? It is FAR more than that. To be honest I don't see any point to this thread any more. You have your answers to your initial question and most of the thread has simply been argument on non-existent weaponry and defensive measures. I don't see it going anywhere else so I am done.
  • #94
In response to the origonal post, you can actually use targeted sound waves to heat small areas to very high temperatures. This is currently being researched as a method to destroy tumors in "hard to reach" locations.
  • #95
Right, because we have never heard of a laser before, that's totally crazy. And it would be foolish to even think a few thousand years of human advancement could yield a serviceable relativistic mass-driver, which funny enough is just about lowest tech "high-tech" weapon in common sci-fi use.
Perhaps you just don't like that fact I don't agree with you. Anyways, the thread will end when the responses do. As far as the point of the thread it is obviously useful for me to discuss these things with others and experience different viewpoints, even if I do not agree with all of them, this is how learning works.
  • #96
If weapons are just an engineering problem (they are not*), what is different in defense?
*relativistic mass-drivers are somewhere between "limit of physics" and "limits of engineering". For electrostatic acceleration, you hit the physical limit of electric arcs quite soon. Pure magnetic acceleration hits similar limits in field strength and gradient. Electromagnetic interaction similar to railguns might achieve higher accelerations, but you need a direct contact between projectile and the gun, which gives serious issues with relativistic velocity. In addition, I think you will need superconductors to get a reasonable current density in the projectile. This limits the allowed temperature of the contact. It is an engineering issue, but a serious one as you have physical limits everywhere and you have to go around them.
1000km^2 of solar cells? Engineering problem. Disassembly of a planet? Engineering problem. Relativistic mass-driver? Problematic.
  • #97
Yes, but the standard in hard sci-fi is just that it not violate any known physical laws. Anything else, including things between the limit of physics and the limits of engineering, is considered fair game. So a relativistic mass driver would be appropriate provided merely that conservation of energy and momentum is not violated.
However, I agree in principle with the "what is different in defense" premise. Stealth would certainly be an important defense, but not the only one.
  • #98
I disagree for a number of reasons, many already stated.
Now what about over-penetration?
What happens if you shoot a car with a really big, slug firing weapon, like a tank gun?
That should annihilate the car, right?
Well no. Slugs are not explosive. It will strilke the window, or door, pass straight through the car, and go out the other side. The window is weak enough that it won't be able to receive more energy from the bullet than is required to break the glass. I wouldn't like to be sitting in that car, but many of the occupants will survive the broken window glass and the vehicle will probably still be drivable.
Hunters know this too: over-penetration of targets is a consideration.
So if you're using a solid round, your target must have sufficient mass to convert its energy. For example if you instead hit a tank with that, instead of a car, it would indeed "stop" the bullet, and the impact of the bullet could physically explode the tank. (So you have 2 ammo types: explosive for unarmoured targets, and slugs for armoured).
So what if:
(a) They depressurise the ship before combat, and get into space suits. No "explosions" from explosive decompression and no fires. Yes wearing space suits INSIDE a ship doesn't sound very scifi, but you wanted realism.
(b) The spacecraft is large, but with dispersed components? It might consist of a 100 meter long "ladder frame" with the components placed on the ladder at 10 meter intervals, and (depressurised) living areas between them. No armour at all.
Now any hit from a slug weapon, that did not hit and break the frame, would either only annihilate one module, or pass through the module, depending on the contents of the module. Sure you might a hit a reactor! But the ship has two! And if not a reactor, chances are you drill through an unused crew bunk and nothing else.
At this point you realize that you need explosives or a some kind of shotgun. Then you have to work out how to build a detonator, or a shotgun mechanism that can survive "impulsegun" velocities.
It's really not as simple as you think it is. Also weapons vs defences is a constantly evolving battle and you might be in a situation where you have 2 enemies each with a difference defence, and each requires a different weapon to counter.
Also I still want to know what you're going to do about people floating the armour in a cage around the ship, or people using decoys.
  • #99
Have you not read "The Gods Themselves" (1972) by Isaac Asimov?
You want to employ a mechanism whose conception is yet outside known science, so you need to refer your basis to an interpretation that comes from known science but is not yet known to be true or false.
The arguments against your idea are based on thermodynamics and conservation in a closed system... explore a way to employ the parallel worlds interpretation of QM to override these problems.
Your basis will then have plausible deniability for as long as it takes science to settle on one interpretation of QM...
  • #100
I would love to hear a physics abiding defense against a relativistic projective.
  • #101
I actually don't think that relativistic projectiles would be that effective for the reasons that rorix_bw gave above. Build a ship with redundant systems and fast repair robots; the slug goes right through and you patch the hole.
However, if you want something more exotic, then gravitational lensing could completely protect against all weapons which travel on geodesics. So that would include relativistic projectiles, lasers, and all other beam weapons. You would only be vulnerable to missiles and other self-propelled weapons.
  • #102
A relativistic projectile would initiate a fusion reaction on contact. It would literally hit with the force of a hydrogen bomb...
Your gravitation defense is an interesting angle though. I think the biggest problem I foresee is that most defensive systems seem to amount to a huge amount of of mass (armor/material/gravitation/etc), and in space, acceleration does not come easy(I do not see an inertial-less engine in the future), so the weight would come at a huge cost of energy and the telltale energy emissions. As a somewhat tangential corollary, I see no effective way to protect a planet; a planet is the last place you would want to be in the case of intergalactic war.
  • #103
I haven't, I'll take a look at The Gods Themselves, thanks.
  • #104
Yes, the energy and force is on the order of a nuclear weapon, but the momentum is vastly different. The point is that you are focusing on the former and neglecting the latter, which tends to decrease the effectiveness.
Deeviant said:
Your gravitation defense is an interesting angle though. I think the biggest problem I foresee is that most defensive systems seem to ...
That is an engineering problem. If future tech can be allowed to solve the engineering problems of offense then "what is different in defense"? Particularly considering that we can already build bunkers to withstand a nuclear attack.
  • #105
Clearly the best solution is not to be stupid enough to start a war in the first place.
edit: I actually think the future of this is a swarm of smaller drone-controlled units that can somehow co-ordinate their actions. I believe it's already a given that "human" pilots are history. This is however not fun to write about.
  • #106
I noticed wrong equation. KE=1/2mv**2 is classical physics. There's a different one for relativistic, but I do not recall it. Google or the other members here will know it. The actual energy is much higher as your mass increases as you approach light speed. For reference "1 megaton TNT equivalent blast" is 4.18 petajoules.
  • #107
You right, I redid the math with the relativistic kinetic equation. It would be 1503.3 megatons for a 1 kilogram at .9999C projectile and 128.9 megatons for a 1 kilogram at .99C.
But that is only the KE. The actual amount of energy released could be more. For one, the projectile could be made of anti-matter and it's density combined with it's velocity with guarantees high amount of particle-anti particle annihilation. 1 kilogram of matter turns into 21.481 megatons of energy, of course this is assuming a 100% annihilation figure which isn't even close to the actual, however, this energy would not be solely directed in path of the projectile, but radiate outward throughout the ship(in fact much of the KE energy would do this as well). If anybody is picturing such a projectile to simply knock a neat hole right through a ship, they would be horrible mistaken, there would be little left. In fact, it would not take many of such projectiles to render Earth inhabitable.
In effect, a relativistic mass-driver such as the .9999 C 1 kilo of antimatter design as outlined above would functionally be a laser that shoots planet killer level thermonuclear bombs. It is this fact, combined with that fact that a relativistic mass driver is on the lower end of the weapons theoretically possible that has led me to that classical sci-fi defensive mechanisms would be useless; armor isn't going to cut it, high maneuverability evasion of relativistic weapons doesn't seem likely at all without some sort of physics breaking propulsion engine(warp drive/higgs field blocker/etc) and there is no credible way to make a star-trek like shield with known physics(that I know of).
I will say that swarms of small expendable unmanned drones would certainly be effective, but than again, you certainly wouldn't want such a swarm to find your ship, would you...
  • #108
This is simply false and yet again shows that you are neglecting the momentum.
It is well known in PET imaging that matter antimatter annihilation conserves momentum. The result is that the photons released do not simply radiate outward, but are angled toward the direction of the momentum. In this case, because the momentum is so high, they would be tightly collimated, and any that did go radially would have quite low energy.
And I suppose that you have done some rigorous simulations (including momentum) of such a device that would support this extremely dubious claim?
  • #109
DaleSpam said:
3) Military ships could be equipped with a material of very high specific heat capacity which is actively cooled down to a few μK (requiring substantial work) during "off duty" times. Then during operations that material could be used as the cold reservoir and the hull kept at 2.7 K without radiating. That would limit the time that they could be stealthed by the amount of time that it would take to heat up the material.
Btw, I ran some math on this. It turns out that the time depends linearly on the mass of heat sink material and the specific heat capacity, and inversely on the power. For a 1 kg heat sink made from a 100 J/kgK material you get 42 min at 1 kW.
Interestingly, the dependence on the starting temperature of the heat sink is very non-linear. The above calculations are for 1. μK. For 2.7 K, a factor of ~3 million change, the time is 11 min, only a factor of ~4 change.
  • #110
As far as my best research can dig up, matter/antimatter annihilation does indeed conserve momentum but not in the way in which you describe. Any particle/anti-particle pair will have the exact behavior you describe but photon's conserve momentum in the form of photon pairs traveling in equal but opposite vectors, but in the end, it would not much matter, simple engineering could render the point moot; for instance the projectile could burst into a web of filaments after being launched, resulting in the ship being sliced into many different pieces, violently. And that is just one idea, but there would be a great many ways to tweak the projectile to get more of a "shotgun" effect.
As far as the launcher itself, it would be trivial; on a ship that is traveling at a relativistic speed(which is not trivial, but certainly possible, especially with the fact that the ship can take a long amount of time to accelerate). The ship could also be a kill vehicle and be consisting of independent highly modular autonomous vehicles that could break apart into many different guided sections and/or launch an almost arbitrary number of filament bombs. Such a weapon would not have any difficulty at all rendering a solar system uninhabitable and/or destroying any detectible structures/ships, and moreover, such a vehicle is not fantastical in the least within the realm of hard sci-fi. It just seems like the only defense in space would be stealth(or perhaps diplomacy, but we all know how well that works in today's world).
So a 1 kg 100 J/kgK heat sink at 1. μK. would absorb 1 kW for 42 before reaching 2.7k? If that is true I don't understand the second part in which assumes the heatsink starting at 2.7k.
My current best design uses heat pumps to pull heat from across the ship and concentrate, then use a black-body pumped laser to lase energy in a very focused direction that I hope nobody will be listening, in addional to using heat sinks as you have suggestion with standard black-body radiator design when not in "stealth mode".
  • #111
Then your best research isn't very good. Google the terms "relativistic beaming" and "relativistic aberration".
It absorbs heat for 42 min before reaching 1275 K, at which point the engine efficiency is 0 and no more work can be extracted.
Since you are using heat pumps work is being done and the second law of thermo should be OK. I don't know much about blackbody pumped lasers. I would be surprised if they cool the blackbody at all.
  • #112
With 10g of acceleration (too much for any humans), an acceleration to .1c requires ~4 days and ~500 million km. You would need the whole inner solar system to accelerate and break, and .1c is far away from any relativistic effects.
In addition, your system to accelerate the ship is a weapon of mass destruction on its own. And you probably want a really powerful energy source. Direct antimatter annihilation would have the capacity, but is hard to store and handle (and imagine your storage getting hit by anything!) and probably give an exhaust visible even from other stellar systems (while this is not an issue due to the delay, it means that it is easy to spot for everything in the same system). Hawking radiation might be useful but gives a lot of heat to radiate away, and it is tricky to accelerate the black hole with 10g.
Your current best design violates basic laws of physics.
  • #114
Deeviant was talking about a ship, not a projectile. As the ship should have its own railgun, I would assume that it is too large to be launched by regular railguns.
In addition, even with an insanely oversized railgun, capable of accelerating a whole spaceship with 2000g, and a spaceship which can handle this, the acceleration track would be more than 1 million km long. At this size and in the inner solar system, the inhomogeneous gravity from the sun becomes significant. And it cannot "catch" the spaceship afterwards.
  • #115
D'oh! I completely missed that. I was entirely focused on the projectile discussion.
  • #116
That is the ship. I don't know why you need a pilot? If it isn't the ship, then you [STRIKE]just re-invented[/STRIKE] are playing carrier war in space and my original post applies.
PS: If you think relativistic projectiles will induce fusion or antimatter reactions by virtue of the energy they deliver (which they might or might not do), then even one loose hydrogen atom, or one tiny grain of space dust, would cause detonation.
How to ensure the projectile does not go BOOM inside, or close to, the launcher? (Also a crop sprayer on the front of the ship would be an effective defence while closing...)
Also I think you really need to think about the engineering "difficultes" inherent with getting up to even 1/10th of light speed. Those are not simply going to go away with bigger drives. There is the Tsolikov Rocket Equation to consider.
http://en.wikipedia.org/wiki/Tsiolkovsky_rocket_equation
In laymans terms, top speed of a ship in space is proportional to the exhaust velocity of the drive, and the fuel system has to conserve momentum. Which means the ship is going to be like 99.99% fuel or something and you need a drive with relativistic exhaust velocity. (Which will of course explode unless you [STRIKE]concede[/STRIKE] say that relativistic mass driver weapons don't cause fusion by kinetic energy transfer)
edit: Actually i think that equation doesn't apply to relativistic speeds, upon reading further I see there is a relativistic version of it presented, however.
  • #117
It doesn't have to be manned(and in this case it would not be, considering it will turn itself into a projectile). Secondly, you are assuming that humans in the future will be like the humans of today, this is a bad assumption. There are no physical laws forbidding the complete resign of the human body and/or integration with technology, and even more so, we have every reason to believe that humans will continue to "improve" our design. If a human is re-engineered to live in liquid for example, the possible acceleration could be enormous as accelerating the whole tank would not put a lot of strain of the person inside, since the force would be evenly distributed as a pressure gradient in the liquid. A complete redesign of the human body using genetic code like we use software code today plus integration of technology is already part of the world I am building. Also, it does not break, it collides, the whole thing is a projectile
There are no laws forbidding a ship traveling at sub-light speed, it is well accepted in the hard sci-fi canon, and really nothing to be gained by trying to argue against it. It is an engineering problem, I have my own ways I will theorize how they can be solve and many others have their own, but it is truly irrelevant to this discussion. The ship could start acceleration far out-system and "Buzz" by, destroying everything in sight.
It is perfectly compatible with physics. I use a heat pump, which takes energy to move heat and concentrate it into a black-body chamber, the photons are then used to pump a laser(remember I could just radiate the heat right into space via black-body if I wanted, the only thing that is different is that I want to do so in a focused beam to reduce detection) Here is a patent for a black-body pumped laser with a good description of it's operation http://www.freepatentsonline.com/3614663.html
The ship accelerates itself to high relativistic speed out-system, undetectably. It then fires it's projectiles in intercept vectors when it nears or enters the system, it is almost moving at relativistic speeds the only thing the launcher would have to do is set the projectiles into intercept vectors, for added effect the entire ship can collide into a planet to sterilize it or it could split up into independent vehicles (a la MIRV) and spread the destruction
Once again, these are all arguments for why it is difficult to get a ship up to relativistic speed, in hard sci-fi, it can be assumed this enormously complex but theoretically possible feat has be achieved.
_____
  • #118
I didn't see anywhere in the patent that the lasing would cool the blackbody. On the contrary, they had to use a coolant to keep the lasing material cooler than the blackbody cavity.
However, you could just use mirrors and optics to radiate the heat in a focused beam. So that isn't an "in principle" problem, just a "best practice" problem.
  • #119
Yes, it wouldn't be coherent but it would at least be directional, somewhat controlled and far more efficient...
  • #120
Focusing the beam in this case may be difficult even in principle. The radiation is initially incoherent. The radiation is initially not uncollimated. There are several laws of physics that would prevent this chaotic radiation from being collimated over large distances.
Let us start with the laws thermodynamics. Initially, the radiation is incoherent and nearly isotropic. There are many degrees of freedom in this radiation. Therefore, the radiation has a large entropy content. When you collimate the beam, you are reducing the degrees of freedom. Therefore, in order to collimate the radiation completely you would have to destroy entropy. Therefore, there is no way to collimate a beam into a small area. The second law of thermodynamics places a limit on how tightly one can collimate a beam.
It turns out that even if you collimated the beam, you would need a large area to dissipate the energy. The thermal radiation would have to be collected over a large area before you collimated it. Otherwise, you would violate the second law of thermodynamics.
Now let us look at the problem from the point of imaging optics. The radiation from the hot object is incoherent. Therefore, the light coming from the hot object acts like an image. The imaging laws for lenses applies to all curved mirrors and curved lenses that are used to collimate the light. According to the laws of lenses, the image can't be shrunk to nothing. All you could do is make a smaller real image. Again, there is only a portion of the thermal radiation that can go into making a smaller image.
You could do this in terms of diffraction. The thermal radiation has a black body spectrum. Therefore, it has a spread of wavelengths. Therefore, diffraction effects prevent one from focusing or collimating the beam. There is an uncertainty relation here that may help.
A young man that I knew suggested making a death ray out of a flashlight and a large array of lenses. He suggested taking a large number of lenses to focus and collimate the beam from the flash light into a very small area. The beam would remain in a small area over a long distance. Within that area, material would be vaporized. One could then cut tanks and airplanes to pieces using this flashlight. I explained that it would not work due to the Second Law of Thermodynamics. The beam would spread out two quickly from the focal point.
He then asked me whether I ever tried it. The answer, of course, was yes. In the course of my work, I have often had a needed for a tightly focuses and tightly collimated beam of thermal radiation. I had tried many times to use lenses (refractive and reflective) to focus such radiation. It wasn't until I did some calculations using the Second Law that I gave up.
I have often wondered what would have happened if I was wrong. Suppose this young man had decided not to listen. Suppose three were a team of rebellious teenagers who didn't listen to mainstream scientists. They went ahead and made these death rays out of flashlight batteries.
Each one could split mountains in half on two Ever Ready batteries! Each one could destroy cities using one single candle!
They would also be able to cure the worlds energy woes. Using such an array of lenses, they could make perpetual motion machines that destroy entropy.
Maybe that would make a good science fiction story. Someone comes up with that hidden combination of lenses that break the Second Law of Thermodynamics.
  • · Replies 17 ·
13K
  • · Replies 19 ·
