Does the color of a laser affect its velocity of the light wave projected by it?
The discussion revolves around the question of whether the color of a laser affects the velocity of the light wave it projects. The context involves understanding the properties of light as electromagnetic waves and their behavior in different mediums.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the constancy of the speed of light across different wavelengths and question how this relates to the properties of lasers. Some express uncertainty about the equations needed to analyze the problem, while others reference the relationship between wavelength and frequency.
Some participants have provided insights regarding the speed of light being constant in a vacuum, while also noting that it can vary in different materials. There is an ongoing exploration of the implications of these concepts, with no explicit consensus reached on the original question.
One participant mentions a lack of access to physics textbooks and resources, which may impact their ability to engage fully with the problem. Additionally, there is a reference to a learning disability that affects written expression, highlighting the challenges faced in articulating the problem and seeking help.
Loneliheart
Thought Project 7 Skill Level III Problem
Laser, which use light rays of set wavelengths (colors), are in constant use in our world, in everything from surgery to supermarket checkout scanners.
Execute the necessary research to determine whether the color of a laser affects the velocity of the light wave projected by the laser.
Remember to cite the sources you used.
I do not have any equations. There was none give for this problem. But, skill level I and skill level II both us the distance=rate x Time formula. I might assume I will be using a variety of it again.
I cannot attempt to solve the problem because I do not know the equation or even where to begin. When we did Thought Project 5 Colors I use this pdf file to help on a skill level problem and I not sure if it help on this problem and it does have some equation that I not sure if is the one I need. http://www.physics.uc.edu/~sitko/ReflectanceSpectroscopy.pdf"
I post help in the wrong area my second night on this forum. And now it will be too late for anyone to help. My assignment in due Monday night. August 2, 2011 I now it is against the rules but I need help more than a normal person for I suffer from a Written Expression Learning Disability.
One of the basic ideas of modern physics is that the speed of light is constant, regardless of the wavelength. This should be easily found in any introductory physics textbook, even for non-science majors.
Thank you.
Are Strategies for Problem Solving Workbook is limited on information. I end up depending on Internet. Some question get no hits other give so much I do not know where to start. I personal only have one Pre-Algebra and one Algebra textbook. I have no Physics book. Which I did. Even the class workbook with a disc which also give me another Pre-Algebra book in pdf file format. I wish they had include a Physics book. Or ITT Tech campus only has a virtually library and extremely limit on any available books. I go check them and see if they have a physics book. I did see some science type magazines.
Indeed, the speed of any electro-magnetic wave, and all colors of light are electromagnetic wave, have the same speed in vacuum, in any frame of reference. However, the speed of light in air, water, glass, or other transparent substance is dependent on the frequency (which determines color).
the speed of light is the constant that allows the formula Wavelengthxfrequency= Velocity to work so well. If the wavelength lengthens the frequency must lessen proportionally. pretty cool IMO
thanks for the help
  • · Replies 105 ·
9K
20K
  • · Replies 51 ·
  • · Replies 25 ·
