Does the Flow Coefficient Cv have any units?
The flow coefficient Cv in valves is primarily a unitless number, used to express the capacity of a valve to carry fluid. For instance, a valve with Cv=20 can carry 20 US gallons per minute at a pressure drop of 1 p.s.i., while a valve with Cv=10 carries 10 US gallons per minute under the same conditions. Although Cv can theoretically have units, it is commonly presented as a dimensionless coefficient for practical applications. In Europe, the Kv value is used instead, which is based on SI units.
  • Understanding of flow dynamics in fluid mechanics
  • Familiarity with valve specifications and performance metrics
  • Knowledge of pressure drop calculations in hydraulic systems
  • Basic grasp of unit conversions between US and SI units
  • Research the differences between Cv and Kv flow coefficients
  • Explore the Darcy-Weisbach equation for pressure loss in pipes
  • Learn about the implications of using unitless coefficients in engineering
  • Investigate the role of resistance coefficients in fluid dynamics
Engineers, valve manufacturers, and fluid dynamics professionals seeking to optimize valve selection and understand flow characteristics in hydraulic systems.
Rahul Baro
TL;DR
Why Flow coefficient doesn't have any unit ?
Flow coefficient in valves doesn't have any units. why?
In practical terms, the coefficient is expressed only as a number.
For example, the manufacturer of a valve tells an engineer that he offers two valves, one with Cv=20 and another one with Cv=10.
Those numbers by themselves, help the engineer select the valve that best fits its system and/or control modulation.
The first valve is able to carry 20 US gallons per minute for a pressure drop of 1 p.s.i., while the second valve, for the same pressure drop, will carry 10 US gallons per minute.
o
okay! i understood the idea.. thanks a lot!
In Europe, they use the Kv instead (SI units).
You are welcome! :smile:
Likes Rahul Baro
To expand/generalize, by definition a coefficient is a unitless multiplication factor, like a percentage. For example, a friction coefficient is a percentage/fraction of normal force "converted" to friction. Similarly, a flow coefficient is a fraction of velocity pressure lost in a valve or other device. The way we often use it in IP units, I think it is a bastardization that includes some rolled-up constants.
So usually if you see units, it's for clarification; eg, N/N (friction).
Likes Rahul Baro and Lnewqban
Where Cv is 'expressed' as a unitless coefficient, imprecision is present. See post #2. Dimensions are a gift from God - respect them. Or else. There are cases where true coefficients exist (see post #7). Cv isn't one of them.
Likes Rahul Baro
okay! thank you so much for the help :)
Careful. People say "flow coefficient" and this should mean "Cv" as used by valve manufacturers and discussed above. But sloppy people might mean "k" or "resistance coefficient" sometimes also called zeta. This goes into the Darcy equation as fL/D, a dimensionless multiplier on the velocity-squared term.
Likes Lnewqban
  • · Replies 21 ·
  • · Replies 34 ·
