Does the observer choose which state in Schrödinger's cat?
97 replies · 11K views
dbcoopersurviv
I am certain this has been asked before many times before since the cat in the box first did not come out, and I am just overlooking it. And I am using the cat in the box for the exact purpose it was orginally created as I understood, to simplify the concept to its very base pieces to allow quick and easy discussion and understanding. So cat in box both alive and dead till observed, then it assumes either one or the other state at the moment of observation. My question is, how is it that the observed which has multiple states available is what is assuming a state and not the observer with it's single perception that chooses a state to perceive? So basically how can you be sure that the cat isn't always both alive and dead and through what ever unknown factors a perception of a state is chosen.
Could this make the random seeming event of which state is chosen possibly predictable by switching the focus from the observed with all its quantum weirdness over to the observer and what is effecting the choice of perception. Could that then be taken from possibly predicting which perception is chosen and carry it on into controlling which perception is chosen? Would it even be relevant to be able to predict or choose which is precieved?
And back to the cat in his box, if the cat is always both alive and dead, should that be taken into account when calculating the actual mass of the cat? Instead of just calculating the mass of the cat in the precieved state, now that he is both alive and dead all the time, would the way his mass is actually calculated need to be changed to account for his existing in both States, simultaneously? To account for what is really there and not just what you precieved as being there?
And would it now be possible to get constantly changing result from the same cat in the same box opening and closing the box? Alive, dead, alive, dead.
To clarify, its original purpose was designed to refute the notion that quantum effects could scale up to macro effects.
We know that the cat really is either alive or dead, we're just trying to find the threshold between QM and the classical world.
In reality, a cat is an object composed of uncountable atoms, all of which interact, collapsing the superposed wave function, leaving a cat that is either alive or dead.
The cat is decohered by the environment to have definite position - like all everyday objects. The position of the constituent parts of an alive and dead cat are entirely different ie an alive cat's heart beats - a dead cat's heart doesn't. It is impossible, utterly impossible, for the cat to be alive an dead - end of story.
The only issue is why everyday objects have definite position. It turns out to be related to the radial symmetry of most interactions ie they do not have a preferred direction. You can find the detail here if it interests you:
https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20
If you want to disuses it, its a bit off this threads topic so start a new one.
Thanks
Bill
Quantum weirdness only happens when you are not observing. The cat is a living organism, so can be classed as an observer. Therefore, no quantum weirdness occurs.
This idea that a conscious observer is required was discarded many decades ago - it's a wrong turn that was taken early in the development of the theory. Unfortunately the idea was picked up by the popular press and has been repeated ever since, but it's not accurate.
You might want to give David Lindley's book "Where does the weirdness go?" a try.
[Edit: I had the author's name wrong. It's fixed now]
I'm sure that's what Jim Al Khalili said in his book?
I doubt it because its wrong. It must be said however that explaining QM at the lay level, and even in beginning textbooks, is difficult so some ideas may not be expressed 100% clearly.
Here is the skinny devoid of any possible confusion. QM is a theory about observations that appear in a common sense world that objectively exists independent of us. What is going on when not observed the theory is silent about - it may be weird, it may be common-sensical, it may be all sorts of things - we simply do not know - although interpretations have various takes.
Thanks
Bill
bhobba said:
QM is a theory about observations that appear in a common sense world that objectively exists independent of us. What is going on when not observed the theory is silent about...
I think you better clarify your definition of "observations" here, or the OP is going to be confused. Most of us laypeople use that word in the "participatory" sense, but I know that's not how you meant it.
It marks left in the world out there. That's as good as can be done at the beginner level.
Thanks
Bill
...So cat in box both alive and dead till observed, then it assumes either one or the other state at the moment of observation. My question is, how is it that the observed which has multiple states available is what is assuming a state and not the observer with it's single perception that chooses a state to perceive?
You've got to remember that as soon as the box is opened, the "observer" is part of the "system". So, theoretically, his/her perception would have "multiple states available" as well... all either perceiving a live cat or dead cat, and nothing in between.
The general concept of your question might seem reasonable to us curious laypeople. But, the technicalities of this thought experiment are complicated, and the mathematical formalism describing the evolution of the quantum state "mixture" is challenging (unless you can master density matrix transforms - which is well beyond my capabilities).
As the mentors explained, the quantum state evolution is limited by a process called "decoherence", and that prevents the evolution of observable "macroscopic" states where superposition is allowed. So, even in the closed box, the state of the cat is ALWAYS either dead OR alive.
But even without drowning in the math, you can get the basic idea by remembering the "triggering" mechanism of the potential feline termination. The quantum uncertainty lies in the state of the radioactive particle. Either the particle decays OR it doesn't decay. There is no in between. Therefore, the measurement made by the Geiger counter either releases the cyanide OR it doesn't... again no in between. From this point forward, the possible quantum states of the larger system (within the box) diverge (become decohered) in a similar either/or existence.
When you then consider an observer that opens the box, the observer is also included in the system. But, at that point the potential states of the observer have already been "diverged" (decohered) by the previous either/or event of the radioactive decay.
If we assume continuity of quantum state evolution, you can clearly understand that you can't go back and forth in the macroscopic state of the cat. Again, the "decohered" potential states of the cat permanently diverge as a result of the preceding "either/or" radioactive event.
For whatever it's worth, and while I don't believe Al Khalili is one of them, there are still some physicists that believe in the need for a "conscious" observer to "collapse" the quantum state... though my understanding is that they're becoming increasingly rare as the idea tends to suggest a panpsychism type of ontology to physical existence.
Regardless, that's an interpretational matter and has no direct bearing on the formalism of quantum theory. While it might make a great deal of difference from a philosophical/metaphysical perspective, it changes nothing from the "shut up and calculate" perspective. Whether consciousness has any fundamental role in Nature or not, it is not "necessary" for the purposes of quantum theory. So, the question can effectively be ignored... aside from the fact that pursuing the concept ultimately leads to overtly philosophical concerns that are not appropriate for this forum.
- just found this quote (is it about a panpsychism type of ontology?) :
To us ... the only acceptable point of view appears to be the one that recognizes both sides of reality - the quantitative and the qualitative, the physical and the psychical - as compatible with each other, and can embrace them simultaneously ... It would be most satisfactory of all if physis and psyche (i.e., matter and mind) could be seen as complementary aspects of the same reality.
Wolfgang Pauli
http://www.azquotes.com/quote/573538
( - that reminds of the ancient assertion, "Creation is twofold, one spiritual and one perceptible" . )
Wolfgang Pauli
:) Well, it suggests a dualistic description of ontology which is ultimately problematic for arguments that consciousness has any type of causal effect on a physical system. Panpsychism is one avenue to alleviate that problem in a monistic manner that might allow conscious observation to have a causal relationship to state reduction. But, as much as I'd like to, we better not head down that path. I'm pretty sure we wouldn't get too far before the philosophy police put the thread behind bars.
It's a little deviation from the OP's initial question, but maybe it would be enlightening if we asked for the professionals here to give us they're best arguments against the classical (if outdated) Copenhagen role of consciousness.
I should add... "It's not necessary" with regard to quantum theory formalism isn't really an argument for or against.
See my post here: https://www.physicsforums.com/threads/decoherence-clarification.828712/page-11#post-5434769 as well as page 241 of "Modern Physics and Ancient Faith" by Stephen M. Barr (publisher: University of Notre Dame Press).
A lot of water has passed under the bridge since Pauli's and other early pioneers time. Their views are now of rather dubious value. Conciousness, psyche, whatever you want to call such philosophical musings 100% for sure is no longer required - if ever it was.
Thanks
Bill
Feeble Wonk said:
:to give us they're best arguments against the classical (if outdated) Copenhagen role of consciousness.
Copenhagen never had any role for conciousness - it was introduced by the great polymath Von Neumann in his classical mathematical foundations of QM where QM was presented with full mathematical rigour for the first time - Dirac's approach used math that wasn't rigorously developed then - it now is. It was introduced for reasons not relevant these days with our current understanding of decoherence. The issue with Copenhagen is it was a theory about observations that appeared here in the classical world. The problem is, and this is the rock bottom essence of the difficulty with QM - not conciousness, particles being in two places at once etc etc - how does a theory that assumes a classical world from the start explain that world? Great progress has been made in resolving it, and more modern interceptions like Consistent Histories avoid it, but some issues still remain and research is ongoing.
Thanks
Bill
bhobba said:
Copenhagen never had any role for conciousness ... The problem is... not consciousness... how does a theory that assumes a classical world from the start explain that world?
“Natural science, does not simply describe and explain nature; it is part of the interplay between nature and ourselves.”
Werner Heisenberg
Therefore, as long as consciousness is considered beside the point, any explanation of the world is also entirely beside the point; - and what remains is, Shut up and calculate...
AlexCaledin said:
Therefore, if consciousness is considered beside the point, then explanation of the world must also be beside the point.
I think you need to stick to context. The context here is if its involved in QM observation - not that theories are the creation of conscious beings.
Thanks
Bill
Well, since modern QM observations are performed by computers, you may well say nowadays consciousness is not involved. But, then, you must be completely satisfied with the consistent histories approach and give up the goal of explaining the real world quantum-mechanically.
It's got nothing to do with computers, although it brings the issue out clearly. May I suggest you think about it a bit more carefully, for example a double slit where the photographic plate is developed later. Before going any further, in your own worlds, why would you think conciousness is involved in what appears on the photographic plate when developed.
I have issues with consistent histories (although I like the interpretation) but that is whole new thread. I hold to ignorance ensemble.
Thanks
Bill
I think consciousness is involved in every appearance... but this question is hardly very scientific.
Computers/robots are special things because they (in principle) can perform any technical act (including developing and observing a photo plate) - without asking for any explanation! So, if QM tells how to calculate probabilities for any situation with (imaginary) computers/robots instead of people, we must be completely satisfied, for all practical purposes.
Dear dbcoopersurviv,
As you know, was formulated in 1926 by Erwin Schroedinger a partial differencial equation that describes how the quantic state of a physical system changes with time. For it, in 1933, he received the Nobel Prize (together with Paul Dirac).
It contains the factor Ψ, referred somewhat improperly as "wave function". The significance of it was not understood, until Max Born interpreted it as defining the probability of finding a particle in a determinate position of space. He received the Nobel Prize for it in 1932. The possibility can be represented by a Gauss curve, with maximum in the center and coming asymptotically to zero in the extremities. The mathematical formalism adopted leaves clear that in the instant the location of the particle is made, all probabilities disappear. Strangely, since the formulation to this day, numerous discussions about the significance of this disappearance occur, maintaining that there is something misterious in it (Copenhagen interpretation). Nevertheless, when we have a dice in hand before we throw it the possibility of each face falling upside is one to six. In the moment it falls upon the table and immobilize, to me it's clear one can no more speak of probabilities, as one of the faces was defined. Its obvious, there is nothing misterious in it, as even Einstein and Niels Bohr concurred. A supposed “observator's influence” is therefore nonsense.
It's what occurs when one imagines that Physics necessarily must be described by mathematical formulas, even when they are not needed, as is the case. In this love by mistery, even today is frequent the understanding that the wave function signifies that the particle is in all places at the same time, and quantic theory would make possible the creation on a computer capable of realizing simultaneously infinite mathematical operations, a thing that would be useful, for instance, in breaking cryptographed texts.
Another common mistake that has the same origin consists in "multiple universes interpretation", that erroneously affirms the objective reality of the universal wave function.
Fernando Arthur Tollendal Pacheco - Brasilia \(DF) - Brazil
[emoji21]I'm reluctant to even get into this, but...
Could you make the argument that the information encoded on the photographic plate is in superposition until such time as it is developed and visualized by a "conscious" entity?
The point is it obviously isnt. It develops what's already there.
Thanks
Bill
I realize that this is a frustrating argument, but I don't see a logical flaw off the top of my head.
It seems like one could argue that IF conscious observation is required for "collapse", it is the act of that observation that is the actual "measurement". So, wouldn't all possible states of the photographic film be in superposition until it is visualized "consciously"? All the "observer" knows about "what's already there" is what is perceivable to his/her consciousness.
Again... I'm simply playing the devil's advocate here. I recognize that this is slippery ground.
I guess I should add that I'm guessing decoherence comes into play at some point here, but that's a little slippery too.
Absolute mystical nonsense which actually has no place in a physics forum.
I call for this thread to be closed.
I retract the question. Apologies to all offended. I was simply trying to follow a line of thought that I was already aware was very questionable. I'll drop the matter.
Feeble Wonk said:
ISo, wouldn't all possible states of the photographic film be in superposition until it is visualized "consciously"?
May I suggest you investigate how the photographic development process works? After doing that, in your own words, a quick explanation of exactly what would happen with some kind of superposition in the photographic plate would be illuminating. I think you will find it quickly degenerates into nonsense but if it doesn't I am all ears.
Thanks
Bill
The wave function is nothing but a prediction of the probabilities of outcomes when a measurement is made on some prepared quantum system.
If you believe otherwise you get caught by Schrodingers little joke.
Suppose we have an apparatus which produces electrons in a superposition of spin-up and spin-down ( in some basis) with equal probability.
The key to the thing is what you believe the italicised bit means. To me it means that half the electrons will be spin-up and half spin-down in a long run of identical repeats ( ensemble interpretation). There is no need to postulate special wave function to explain this.
If you think that there is a 'superposed' wave function that has to collapse to produce the outcome - you are in trouble.
Actually each electron produced is either spin-up or spin-down - but we don't know which until it is measured.
The same thing applies to cats. The apparatus will prepare the mixture, but each cat is already dead or alive before going in the box.
