Does the open area of my window make a difference?
The discussion revolves around the impact of the open area of a window on the influx of cold air into a room. Participants explore theoretical and practical implications of window openings, considering factors such as air flow, temperature distribution, and fluid dynamics.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants suggest that the amount of open area directly affects the volume of cold air entering a room, with larger openings allowing more air flow.
  • One participant proposes a proportional relationship between the surface area of the open window and the velocity of air entering the room, referencing the equation u=QA.
  • Another participant raises a scenario comparing a small opening to a fully open window, questioning whether a half-open window would significantly impact room temperature.
  • Some participants discuss the scattering of air molecules and how this affects volumetric flow, suggesting that a larger opening may facilitate quicker temperature equalization with the outside environment.
  • There is mention of thermodynamics and fluid dynamics as frameworks for understanding the phenomena, with references to Computational Fluid Dynamics (CFD) for simulating air flow and temperature distribution.
Participants generally agree that the open area of a window influences air flow and temperature dynamics, but there are competing views on the specifics of how different opening sizes affect these factors. The discussion remains unresolved regarding the precise effects of varying window openings.
Participants express uncertainty about the application of specific formulas or theories related to the temperature equalization process and the dynamics of air flow through windows.
Fodder
So I was wondering whether the amount of open area of my window would make a difference in how much cold air gets in?
Please tell me if I should provide more information, I'm pretty new to this.
Absolutely. If your window is 3 feet wide and you open it by 2 inches, you won't let in nearly as much air as you would if you opened it by 2 feet.
Well, let's take extremes and see what YOU think. Two scenarios: (1) You have a REALLY small opening. Second, you have a REALLY big window and it is all the way open.
What you do you expect to happen?
Hi and welcome to PF,
As long as you have another window/s open and there is air flow in the house/room, the flow of air into the house/room is approximately proportional to the surface area of the open window (u=QA, u: velocity of air, Q: volumetric flow of air, A: surface area of the open window.
If the other windows and doors are all closed, then some warm air from inside the house will go out of the window, but again the flow of air into the house/room will be proportional to the surface area of the opening.
My window looks like this, and the thing is I was wondering if I opened the one on the right to the max would it make a difference from opening it to the one on the middle
I would most likely choose the second one, but would it make a difference if my window was half open or fully open? like does it make the room colder if I choose the fully open one? ( Please watch the picture for reference, also thanks for commenting I thought nobody would answer this)
In this case, it has to do with the open surface area and the direction of the air.
Generally, in the middle window, the volumetric flow will be less (if you have the same opening area with the third window), because the molecules of air will be scattered in a bigger extent and most of them will return outside the house.
Anyway, if you let the window open for much time, the room temperature will be equal to Tout. However, the faster way to reach Tout is the third window (this way of opening).
Now this makes sense to me, I suck at physics and that's why I came here to ask this question. But is there any formula/theory for the last part "
if you let the window open for much time, the room temperature will be equal to Tout. However, the faster way to reach Tout is the third window (this way of opening).".
This specific phenomenon can be explained/analysed with the help of thermodynamics (fluid dynamics and heat transfer phenomena).
Computational Fluid Dynamics (CFD) is a very interesting field of thermodynamics. For example, you can simulate this situation in COMSOL Multiphysics, drawing a house exactly and setting which doors/windows are open and which are closed and you will get the temperature distribution in the house.
Right, thanks for answering, I will read a bit about fluid dynamics.
  • · Replies 19 ·
  • · Replies 42 ·
14K
