What happens when the observer hears sounds from a super sonic source?
The discussion focuses on the effects of a supersonic source on sound perception by an observer. When the observer moves away from the source at a speed greater than sound, the apparent frequency becomes negative, resulting in the sound being perceived in reverse order. Conversely, if the source moves faster than sound towards a stationary observer, the sound waves reach the observer in the correct order but at a reduced frequency due to the increased distance traveled. The formulas used include ##f_{observer} = f_{source} (\frac{v_{sound} - v_{observer}}{v_{sound}})## and ##f_{observer} = f_{source} (\frac{v_{sound}}{v_{sound} - v_{source}})##, highlighting the complex interaction between speed and sound perception.
  • Understanding of sound wave propagation and frequency
  • Familiarity with the Doppler effect
  • Knowledge of basic physics concepts such as velocity and pressure waves
  • Mathematical skills to interpret and manipulate formulas
  • Study the Doppler effect in detail, focusing on its mathematical derivation and applications
  • Explore sound wave behavior in different mediums beyond air
  • Investigate the implications of supersonic travel on sound perception in aviation
  • Learn about the physics of shock waves and their relationship to supersonic speeds
Physics students, sound engineers, and professionals in aerospace industries who seek to understand the implications of supersonic travel on sound perception and wave behavior.
arpon
As we know, when the observer is moving away from the source, then the apparent frequency is,
But, if ##v_{observer} > v_{sound}## , ##f_{observer}## becomes negative.
With sound waves being vibrations in air, if you move faster than sound away from the source, those pressure waves hit your eardrums in the reverse order. Windiness aside, the sound would be heard as being played backwards.
And what it would be, if the observer is stationary and the source is moving faster than sound, i.e.
##f_{observer} = f_{source} (\frac {v_{sound}}{v_{sound} - v_{source}})## , and ##v_{source} > v_{sound}## ;
you would hear the sound in regular order:
The first pressure wave the source emitted would be the first thing that hits your eardrum, and the second would be the second, and so on
However, the sound would be slowed down:
The pressure waves would hit your eardrum less often because each time the wave has to travel a longer distance from the source at the same speed.
When the source is moving faster than sound and moving towards the observer, the source has to go ahead of the observer to reach sound to the observer. So, in this case, I think, the formula for the source coming to the observer is not applicable. Only, when the source is moving away the observer, the sound can be heard.
Right, and after the super sonic source passed the stationary observer he would hear the previously played sounds in reverse order.
Why not?
Why not?
I think, the observer will hear two sounds, one coming from in front of him and the other coming from behind him.
Sound coming from in front of the observer (frequency ##f_1##) will be fast but played backward. And sound coming from behind the observer (frequency ##f_2##) will be slow but played in regular order.
##f_1 = f_{source} (\frac {v_{sound}}{v_{source} - v_{sound}})##
##f_2 = f_{source} (\frac {v_{sound}}{v_{source} + v_{sound}})##
And, look, for sufficient velocity of the source,##f_1## may be less than ##f_{source}## !
  • · Replies 17 ·
